This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Old Nov 20, 2012, 05:43 AM
Jack Crossfire is offline
Find More Posts by Jack Crossfire
Jack Crossfire's Avatar
Calif*
Joined Sep 2006
HS-785HB teardown
The answer is no. The motor in this $50 servo can't be pulled out without damaging it. Maybe the motor terminals can be soldered to some wire to apply more force to it. Those right angle traces are things you don't see every day.
Using the servo pots to detect where they're pointed would be nearly as accurate as an IMU for determining camera angle.
The IMU for camera pointing is a buster to implement & configure, but it is the most accurate measuring device. It would eliminate all methods besides PWM if it didn't improve the accuracy.
The process of integrating the IMU & ground station on the camera mount is long & hard. Future soldering & development has to be done on the floor, with a portable iron & laptop. The quest for an ideal bench has never yielded anything. Eevblog seems to have the ideal bench for electronics, but not for a computer.
Jack Crossfire is offline Find More Posts by Jack Crossfire
Sold HITEC HS-785HB Wench servo Slaphappysamy FPV Equipment (FS/W) 1 Jul 18, 2012 12:44 PM
For Sale HS-785HB winch servo Protocrash Aircraft - General - Radio Equipment (FS/W) 0 May 09, 2012 10:13 AM
Sold "Reduced" Brand New HS-785HB Winch Servo dae77 Boats (FS/W) 1 Nov 15, 2007 09:58 AM
Question HS-785HB rotation Kroony Radios 2 Oct 29, 2007 06:09 PM
HS-785HB winch diameter? justballast Hitec/Multiplex USA 4 Sep 13, 2005 04:57 PM
