This thread is privately moderated by SkyCadet, who may elect to delete unwanted replies.
Old Nov 20, 2012, 12:14 AM
SkyCadet is offline
Find More Posts by SkyCadet
Segelfliegen bedeutet Freiheit
SkyCadet's Avatar
Canada, MB, Winnipeg
Joined May 2010
Canopy finishing and horizontal stabilizer mounted
My horizontal stabilizer is mounted on the fuselage (still drying, so pic later).
Elevator connecting wire is in as well. Test fitted system before mounting - excellent fit. The 2mm wire was redone as the stock one was a bit bent. I used white glue in lieu of CA or epoxy. My tail slides into the fuselage, and I had to ensure that it could be fitted and aligned properly. CA is pretty fast, and may not fill in enough to hold under more extreme landing or flight conditions. I did the same with my Pitts 12 15e, and it works fine.
During the fitting and clamping, the stabilizer main section was a bit off from alignement, slightly angled. I clamped the tail after applying a bit of opposite pressure to re-align the stab. Double-checked everything before final clamping. It's aligned with the wings (test fit and cheked for alignment with stab).
The canopy is a plain bubble type, so I added some black 3M vinyl cut 4mm wide to simulate the actual Yak 55 canopy. Pic shown below. The vinyl applied well, but the compound curve of the front of the canopy bubble is hard to get just so. But we got it pretty close!
Sdiebar: I was concerned about the kit gear struts. They are too narrow and not very high. I ordered a CF gear from HobbyKing, which should be PERFECT for this plane. HK280-148 is the stock number. Once it comes in, I'll fit it in lieu of the stock gear. Most Yak-55s I've seen online (scale planes) have a wider gear strut system than the kit has. This will look more proportional - should be awesome.
SkyCadet
SkyCadet is offline Find More Posts by SkyCadet
Help! Horizontal Stabilizer not so Horizontal ... dsaturday The Builders Workshop 14 Jun 27, 2012 10:41 AM
Discussion Horizontal Stabilizer mount supplier? donglass Hand Launch 6 Feb 27, 2011 09:07 AM
Help! Help! - Horizontal Stabilizer V Mount sailfree Thermal 2 May 02, 2008 08:40 PM
Help! Horizontal Stabilizer V Mount sailfree Sailplane Talk 3 May 02, 2008 08:35 PM
Sold gws-FW190 Main wing, horizontal, stabilizers, rudder, and canopy WWIrules Aircraft - Electric - Airplanes (FS/W) 2 Sep 18, 2007 05:11 PM
