Old Dec 04, 2012, 04:32 AM
paulbw is offline
Find More Posts by paulbw
paulbw's Avatar
Gloucestershire, UK.
Joined May 2006
To continue the document laminating film discussion if I may, can anyone point me in the direction of a UK or European supplier of 28 micron matt film in 30m lengths? All I can find are the 38 micron/150m rolls which, for my purposes, is definitely overkill!
Paul W.
paulbw is offline Find More Posts by paulbw
Old Dec 05, 2012, 11:21 PM
colibriguitars is online now
Find More Posts by colibriguitars
Joined Mar 2011
Hi Guys!!
Still working on Tomtit!
After make some tests, (tissue over film) i choose polyurethane base coat water finish, it is an international trademark, so you can find it almost anywhere. in the test, once the dope and poly were coat, were hard to peal from the film, and most on the edges, once you peal the edge it just run, leaving the film clear with just a layer of finish. but, the bond between two techniques, have better results with poly.
colibriguitars is online now Find More Posts by colibriguitars
Old Dec 06, 2012, 02:38 AM
Sundancer is online now
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Looking really good CG. Have you decided on the colours yet??
Sundancer is online now Find More Posts by Sundancer
Old Dec 06, 2012, 02:42 AM
Joined Mar 2011
Hi George!!
i just finish to cover the upper wing with doculam, just add 7 grams.
about the colours... orange/black... What you think?
Do you think if i rubber the film with 000 steel wool it add some adhesion?
Old Dec 06, 2012, 02:45 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Hi Rodrigo
I don't know about the steel wool; on the Triplane I wiped the doculam down with a tissue pad moistened with methylated spirit to make sure there was no grease on the surface, that may help. I like the sound of your colours.
Old Dec 06, 2012, 04:50 AM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
Not long back I recovered a SIG cub that somebody had covered with laminating film and I was told that he had steel wooled it then wiped down with alcohol, well I will never do the same as the paint wich was a reputable model paint every time it was flown more paint flaked off ,it was turning my workshop floor into what looked like a yellow snowstorm had hit, ,and took forever to get rid of, it was very satisfying just doing a standard cub yellow film finish,
I know your trying for a lightweight durable finish but painting laminating film I would not recomend, Id rather silk except for the cost.
olmod is offline Find More Posts by olmod
Old Dec 06, 2012, 05:18 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
CG isn't going to paint the film, he is covering with tissue on top to produce an effect like that below. I don't know what brand of paint you used, but I sprayed a model covered in laminating film and de-greased with Flair Spectrum and when I sold it after five years of flying, it was still fine. The other model (Triplane) below is covered in tissue on top of doculam and sprayed, also with Flair Spectrum matt and is now 13 years plus old.
Old Dec 06, 2012, 03:19 PM
olmod is offline
olmod's Avatar
Joined Apr 2004
Sorry about the post I thought he was going to paint it
I did not paint that cub a prevous owner did ,I did not want to name the paint product as it was just heresay but it was a well known brand.
Old Dec 06, 2012, 04:13 PM
Sundancer's Avatar
South-west France
Joined Sep 2007
No worries olmod, since you thought he was going to paint it, it was nice of you to flag up the warning. I think maybe one of the deciding factors as to how well it paints is the doculam itself, I have always used matt finish which I think is perhaps better for paint adhesion. Most of my models are not painted as they are mostly vintage and I prefer the "tissue" look, and if using it on a scale model which does require painting, these days I would always cover it with tissue - or maybe silk if it was a WW1 type - anyway.
Old Dec 07, 2012, 12:50 AM
Joined Mar 2011
Hi Guys!!
The laminating covering is done, the main wing just gain 6 grams, the lower wing gained 4, and the rudder and elevator 4 grams. this is nice... and as a first time using "modern" materials, it nice and easy. i will try to rubber all the doculam.
so my next steps: wait for arrival from Hobbyking, make some color desaing on paper, start to cut tissue and it will be bond with water poly, and finished with dope.
Old Dec 07, 2012, 02:17 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
CG, have you tested the method of fixing with varnish and then doping over the top? I have never used this and there may be problems with applying the dope over the varnish, please do try it first. My Tom Tit is just finished with varnish, all my models use EITHER varnish OR dope, not both together. I THINK varnish over dope would be OK, but fear there may be problems with dope over varnish. I would'nt want you to spoil the model at this late stage!
Old Dec 07, 2012, 10:12 PM
Joined Mar 2011
Hi George!!
To many information just make me so confuse...
after wetting the tissue, just placed on position and still wet, apply dope?? so, i can apply dope over wet tissue?? how many coats?
Thanks for the support!
Old Dec 08, 2012, 03:01 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Yes, you can dope over wet tissue. OR you can use the varnish again over wet tissue. BUT I wouldn't recommend mixing varnish and dope - use one or the other.
There may be some "blushing" - white marks on the tissue - as it drys out when using dope, but this will disappear with the second coat of thinned dope.
There will be no blushing when using varnish.
But do try out on a test piece whatever you are going to use
Old Dec 08, 2012, 02:04 PM
sparks59 is offline
Find More Posts by sparks59
Sic itur ad Astra
sparks59's Avatar
United Arab Emirates, Abu Dhabi, Abu Dhabi
Joined Aug 2009
I'm late to join you on this one CG, but read the previous posts with much interest.
Great progress so far. Looking forward to seeing the final finishing.
sparks
sparks59 is offline Find More Posts by sparks59
Old Dec 08, 2012, 07:21 PM
Joined Mar 2011
Hi Sparks! Thanks!! i know you are a big fan of FROGīs, and your Ravenīs video is one i like to much!
Build Log FROG Raven @150% and Moth Minor @200% colibriguitars Vintage & Old-Timer Designs 6 Oct 15, 2012 11:57 PM
Help! Veron Hawker Tomtit written instructions Edubarca Vintage & Old-Timer Designs 5 Sep 17, 2012 10:44 AM
Discussion hawker tomtit stephen adams Vintage & Old-Timer Designs 1 May 18, 2012 08:26 AM
Build Log Frog Tomtit rk295 Free Flight 17 Jun 05, 2009 07:29 PM
Build Log Frog Tomtit conversion Ljotham Scratchbuilt Indoor and Micro Models 6 Oct 15, 2006 01:29 PM
