Nov 20, 2012, 03:09 AM
South-west France
Joined Sep 2007
That isn't so slow Rodrigo!
As this is my design, I feel I should comment on the thrustline question:
The plan shows no down or side thrust and that is the way my prototype is set up, I am quite happy with the way it flies. At full throttle it has a natural climb angle of about 20-25 degrees with the 140 watt motor I am using (8 x 4.3 prop). To cruise level, reduce throttle to about half. I can detect no need for side thrust.
If you wish, you could add 2 to 3 degrees of downthrust; this would just mean that the model would fly level at a higher throttle opening, but faster! My view of these free-flight-to-radio conversions is that they SHOULD naturally climb at full throttle, as the free-flight model would, you use the PROPORTIONAL throttle control to achieve the flight status you want - climbing, level or descending, just as you would with a full size aircraft - but if you prefer a more "radio" trim, then you can add the downthrust. However, be aware this is NOT intended to be an aerobatic model which will hurtle around level at full throttle - you could make it do that by thrustline, incidence and CG changes but it would lose much of it's charm to me. With regard to right thrust, I don't think the model needs it, there is no noticeable deviation between part and full throttle on mine. Again, if you wish, add a couple of degrees right thrust, I don't think it will make much difference one way or the other.
Perhaps the best thing to do would be to build it as per plan, but leave off the front cowling for now. Fly it, adjust the thrustline if you feel the need and then make and fit the cowling.
