Old Dec 10, 2003, 04:00 AM
sbf
sbf
Guest
n/a Posts
Smallest possible helicopter?
Hi, I was wondering what the smallest possible electric helicopter size
would be,
I would really like to make a basic 2ch electric one using the electronics
from those minature rc cars, u know, the Tomy bit charg or the other 1:43
scale clones.
Is this possible??
I doubt it myself, but what do you all think? I woul like to go smaller than
the homemade pixel helicopter that someone made.
I want to use it indoors u c !
Scott
Old Dec 10, 2003, 07:01 PM
david
david
Guest
n/a Posts
Re: Smallest possible helicopter?
"sbf" <no@no.com> wrote in message
newsuuBb.2144$El5.677175@newsfep2-win.server.ntli.net...
> would be,
All cats are animals, but not all animals are cats.
I would think the smallest electric helicopter possible would be one of
those nano-bot things the Japs can produce. probably a few microns across
the rotors.
The smallest useable, r/c indoor helicopter though would likely use
technology "outside the box".
Why not use five or seven large feathers (or shaped Depron) as the rotors,
make them fixed pitch, and use two contrarotating heads to eliminate the
need for a tail rotor use a small motor driven from a large capacitor as
the source. Use the tiny r/c system used for paper planes as seen in RCMW
recently for control.
Or you could use depron and make a two rotored gyrocopter., driven rotors,
no tail needed.
I started to make an indoor gyroplane out of pikostik parts and depron
blades, but events over took me and it languishes on a shelf now.
GL
David
david
david
Guest
n/a Posts
> would be,
the rotors.
no tail needed.
GL
David
Beav
Beav
Guest
n/a Posts
> would be,
> scale clones.
> Is this possible??
Anything's possible, but flying a heli which requires a minimum of FOUR
channels with a 2 channel radio isn't likely to be an EASY possibility.
Beav
Please note my E-mail address is "beavis dot original at ntlworld dot com"
(with the obvious changes)
Beavisland now lives at
www.beavisoriginal.co.uk
Beav
Beav
Guest
n/a Posts
> would be,
> scale clones.
> Is this possible??
Beav
mememe
mememe
Guest
n/a Posts
someone here posted this about a month ago
http://www.epson.co.jp/e/newsroom/news_2003_11_18_2.htm
its pretty small
> would be,
> scale clones.
> Is this possible??
than
> Thanks
> Scott
mememe
mememe
Guest
n/a Posts
its pretty small
> would be,
> scale clones.
> Is this possible??
than
> Thanks
> Scott
Old Dec 11, 2003, 07:01 PM
H.J.
H.J.
Guest
n/a Posts
There is NO way to do it with 2 channels, mate. You can do an airplane with
2 channels, because it is always flying forward and therefore, you can get
by with controlling yaw (rudder) and throttle (up/ dn). The third axis,
forward/bak is set permanently to forward by the prop.
Hovering craft need constant correction in 4 axis and therefore need at
least 4 ch.
1 fr/bak
2 left/right
3 up/dn
4 spin (rudder yaw)
> would be,
> scale clones.
> Is this possible??
than
> Thanks
> Scott
H.J.
H.J.
Guest
n/a Posts
least 4 ch.
1 fr/bak
2 left/right
3 up/dn
4 spin (rudder yaw)
> would be,
> scale clones.
> Is this possible??
than
> Thanks
> Scott
Old Dec 11, 2003, 07:02 PM
sbf
sbf
Guest
n/a Posts
looks like i may have to try the 4ch approach then.
That bloke who made the pixel heli is inspiring!
48g is the weight of the pixel 2000!!!
Scott
"H.J." <wenonaliar@yahoo.com> wrote in message
news:vth3q8drcmjg1b@corp.supernews.com...
with
> least 4 ch.
> 1 fr/bak
> 2 left/right
> 3 up/dn
> 4 spin (rudder yaw)
> > would be,
electronics
1:43
> > scale clones.
> > Is this possible??
> than
> > Thanks
> > Scott
Old Dec 11, 2003, 07:03 PM
sbf
sbf
Guest
n/a Posts
Scott
with
> least 4 ch.
> 1 fr/bak
> 2 left/right
> 3 up/dn
> 4 spin (rudder yaw)
> > would be,
electronics
1:43
> > scale clones.
> > Is this possible??
> than
> > Thanks
> > Scott
Old Dec 18, 2003, 07:01 PM
Yankee
Yankee
Guest
n/a Posts
news:ld6Cb.2182$l3.1476130@newsfep2-win.server.ntli.net...
> Thanks
> Scott
> with
get
> > least 4 ch.
> > 1 fr/bak
> > 2 left/right
> > 3 up/dn
> > 4 spin (rudder yaw)
size
> > > would be,
> electronics
> 1:43
> > > scale clones.
> > > Is this possible??
smaller
> > than
> > > Thanks
> > > Scott
Check this out:
http://www.proxflyer.com/
Smallest there is i think :-)
Only 6,9 grams.
Yankee
Yankee
Guest
n/a Posts
> Thanks
> Scott
> with
get
> > least 4 ch.
> > 1 fr/bak
> > 2 left/right
> > 3 up/dn
> > 4 spin (rudder yaw)
size
> > > would be,
> electronics
> 1:43
> > > scale clones.
> > > Is this possible??
smaller
> > than
> > > Thanks
> > > Scott
Check this out:
Only 6,9 grams.
Andy Fell
Andy Fell
Guest
n/a Posts
GENIUS!
>> Thanks
>> Scott
>> with
>get
>> > least 4 ch.
>> > 1 fr/bak
>> > 2 left/right
>> > 3 up/dn
>> > 4 spin (rudder yaw)
>size
>> > > would be,
>> electronics
>> 1:43
>> > > scale clones.
>> > > Is this possible??
>smaller
>> > than
>> > > Thanks
>> > > Scott
>Check this out:
>Only 6,9 grams.
Andy Fell
Andy Fell
Guest
n/a Posts
GENIUS!
>> Thanks
>> Scott
>> with
>get
>> > least 4 ch.
>> > 1 fr/bak
>> > 2 left/right
>> > 3 up/dn
>> > 4 spin (rudder yaw)
>size
>> > > would be,
>> electronics
>> 1:43
>> > > scale clones.
>> > > Is this possible??
>smaller
>> > than
>> > > Thanks
>> > > Scott
>Check this out:
>Only 6,9 grams.
Yippee! Worlds Smallest RC Helicopter - Has Anyone Tried It Out? rcadvisor 3D Flying 4 Dec 03, 2005 09:11 PM
Smallest possible radius for turning romeylo Motorcycles 8 Apr 09, 2005 09:05 AM
