Old Nov 21, 2012, 09:39 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
I run aluminum dry.
gkamysz is offline Find More Posts by gkamysz
Old Nov 21, 2012, 11:32 PM
Rich Speroni is offline
Find More Posts by Rich Speroni
Joined Jun 2003
I would use carbide stub, double ended .125 dia 4 flute endmill. Four flutes are stronger than 2 flutes. Length of cut for stubs is .25-.375 inch long. The shorter the better. Only let the endmill protrude from the collet the length of cut. So clamp it real close right up to the end of cut of the cutting tool.
To get the chips to clear the cutter you're going to need an air/water spray mist. The water cools the cutting tool and the air spray clears the chips. You need the air velocity to be high with a little water volume. The spray has to set very close to the .125 end mill directed towards the bottom of the cutter.
The best way to cut the those arms is first rough saw them out with a band saw. Leave no more than a 1/32 oversize (less is better). now all you have to do is use the side of the cutter to clean to size. You should be able to go the full 1/8 depth of cut. 10,000 RPM, 5-10 inches per min on feed. Much less stress on the cutter.
Before you do any saw cut put some holes down the length of the arms. Very little clearance for 1/4 in. screws. Space them out 1 inch from each end and every 3 inches down the arm . Now get a 4 inch wide x (2 inches longer than arms) piece of Alum plate or bar 1/2 inch thick, now put in 1/4-20 threaded holes that are the same spaced as the arms. Now clamp down the plate to the the table and the arms to the plate using 1/4-20 socket head screws and steel washers. You could use 1/8 Aluminum sheet strips for washers. Now you've got a rigid setup that won't move when you cut the arms. Use the water spray and clamping of the 4 flute cutter as described above to get it done.
Good Luck.
Rich Speroni is offline Find More Posts by Rich Speroni
Old Nov 22, 2012, 08:25 AM
al010964 is offline
Find More Posts by al010964
Australia
Joined May 2010
A simple thing - but make sure your cutter is spinning in the right direction. I was cutting 6061-t6 when i was starting out .... They quite cut a fairway spinning in the wrong direction, before breaking.
Ask me how I know
Especially if using Mach3
Cheers,
.adrian
al010964 is offline Find More Posts by al010964
Old Nov 24, 2012, 01:32 PM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
http://www.tapmagic.com/TMaluminum.htm
Use something designed for the job-it'll pay for itself in savings on bits.
Stuart
Stuart A is offline Find More Posts by Stuart A
Old Nov 24, 2012, 04:17 PM
Ward Hagaman is offline
Find More Posts by Ward Hagaman
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
Someone might have suggested this already, but cli mb cutting vs. conventional cutting is important.
Ward Hagaman is offline Find More Posts by Ward Hagaman
Old Nov 25, 2012, 10:27 AM
Fubar 123 is offline
Find More Posts by Fubar 123
Fubar 123's Avatar
Whitchurch,Shropshire. UK
Joined Jul 2008
High rake angle tools with large flute clearance to get the swarf out and definatly a little cutting solution , weather it is parafin type or soluble oil is up to you.
A chip thickness of about 0.05 mm /tooth is about as low as you want to go as carbide likes to cut rather than let it 'rub'
You should be able to cut it like butter. Is your tool sharp ? any dinks on it ? take a look with a loupe!
Fubar 123 is offline Find More Posts by Fubar 123
Old Nov 25, 2012, 09:13 PM
MRM RCModels is offline
Find More Posts by MRM RCModels
United States, CA, California City
Joined Mar 2011
Shallow Fast Cuts are Key
I cut AL on my router almost everyday. the trick is to take shallow Depth of Cuts (DOC) with high feed rates. Try using a 3 flute carbide, with 0.011 DOC, at 75 Inches per Minute, and a spindle speed of 12285. A few squirts of WD-40 at 2-3 minute intervals will be enough to provide lubrication and cooling.
cheers
MRM RCModels is offline Find More Posts by MRM RCModels
Old Nov 27, 2012, 10:17 PM
CrashAffinity is offline
Find More Posts by CrashAffinity
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, AB, Calgary
Joined Nov 2012
Originally Posted by Lpbug View Post
Forgot to mention the type of Aluminum, which is 6061-T6.
I used to be a CNC operator for a number of years, when i cut this, on my machine it was like butter, but i had a 10HP motor.
Only thing that you have to keep in mind is to keep the bit lubricated the entire time. I had a spray mist on the head at all times spraying lubricant. If you're breaking a lot of bits your bit is likely overheating.
Edit: I should note i always used titanium coated carbide bits, it made all the difference.
CrashAffinity is offline Find More Posts by CrashAffinity
Help! Cannot keep my Tricopters YAW Servo centered & stable. AcroFPV Multirotor Talk 14 Apr 20, 2014 01:45 PM
Question laser cut aluminum mgivens The Builders Workshop 11 Oct 03, 2012 09:18 PM
Discussion APM2.0 AUTO RETURN HOME SUCCESS! But cannot get position hold. OPEN MY PIDs. votreami Multirotor Talk 2 Jun 08, 2012 06:04 AM
Discussion Cannot solder aluminum tab to nickel ones ?? khaled_abobakr Batteries and Chargers 10 Apr 12, 2010 12:11 PM
