Old Nov 19, 2012, 10:04 PM
Rhondas is offline
Find More Posts by Rhondas
Rhondas's Avatar
usa
Joined Dec 2004
how to paint over monokote scuff up grit
I have a film covered and do not know if its monokote or ultra coat 3D edge, and I want to paint it bottom dark top light in color, I have heard that you must scuff up the covering first to make the paint stick , what grit sand paper will do this unless not needed for electric type airplanes [no fuel?]
Rhondas is offline Find More Posts by Rhondas
Old Nov 20, 2012, 07:16 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
The plastic needs to be scuffed for paint adhesion, not because of the power source.
If it were me, I'd use OOOO# steel wool to scuff the plastic surface.
TomCrump is offline Find More Posts by TomCrump
Old Nov 20, 2012, 08:25 AM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
I have used Krylon Fusion (http://www.krylon.com/products/fusion_for_plastic/) on plastic covering, and didn't have to scuff it up. Sticks VERY well. I even had a place where I dented the covering pretty good. Some very light heat straitened it right out and the paint never knew it.
rcav8r2 is offline Find More Posts by rcav8r2
Old Nov 20, 2012, 09:06 AM
edwin1 is online now
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
I've had real good luck with Rustoleum, fuel proof up to 15%. But dont paint where you will have something touching the paint like the cowl or places like that. It rubs the paint off. The cowl area is covered with ultracoat red about 2" past the cowl. The rest of the covering is light grey and (except for insignia's) the rest is rustoleum.
Edwin
edwin1 is online now Find More Posts by edwin1
Old Nov 20, 2012, 10:29 AM
Rhondas is offline
Rhondas's Avatar
usa
Joined Dec 2004
I have a lot of fine grite from car painting, what is close to the 000 brillo or steel wool, can I use a 1500 sand paper grit
Old Nov 20, 2012, 10:42 AM
Rhondas is offline
Rhondas's Avatar
usa
Joined Dec 2004
sound s good but this is the prp procedure , is this necessary?
When working with plastic
For old plastic, use an ammonia-based cleaner and wipe down to clean surface. If the plastic is new, wipe down with paint thinner for best results. Lightly sand glossy surface if previously painted and remove dust with a tack cloth. When dry, apply KrylonŽ Fusion for Plastic according to the directions on t
Old Nov 20, 2012, 10:46 AM
Rhondas is offline
Rhondas's Avatar
usa
Joined Dec 2004
Edwin
did you mean luster coat spray paint or just rustoleum?
is that nice plane fully painted over the film covering
Old Nov 20, 2012, 10:48 AM
Rhondas is offline
Rhondas's Avatar
usa
Joined Dec 2004
do you think I should follow the prep ? its very shiny gloss ultra cote film
Old Nov 20, 2012, 11:38 AM
Joined Sep 2003
No lustercoat, I dont like that stuff. Its rattle can rustoleum from the hardware store. Yes, all that is painted on the ultracoat. The good thing is that when the mylar wrinkles, I can reshrink to tighten it up. But you must use something like a clean white T-shirt material and use your iron over that. Dont move the cloth, just the iron and it shrinks right up without hurting the paint. The rustoleum has stayed flexible for quite a while. DONT use a hot air gun, it will dry out.
Edwin
Old Nov 20, 2012, 12:26 PM
rcav8r2 is offline
rcav8r2's Avatar
Joined Sep 2001
I forget what I did, but I'm pretty sure all I did was wipe down with denatured alcohol, mask, and spray.
Oh yea, forgot to mention... Not sure if it is gas/glow proof (I'm guessing it is), but I know first hand it is spent electron proof
Old Nov 20, 2012, 12:52 PM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
I have never seen a Krylon product that was even mildly gas/fuel resistant.
Rustoleum seems to hold up well. I use it frequently.
Anything higher than 400 grit should work for scuffing the plastic.
Old Nov 20, 2012, 04:41 PM
Rhondas is offline
Rhondas's Avatar
usa
Joined Dec 2004
any thing 400grit or up 600 grit say its good to ruff up the monokote or any type film first before painting it?
Old Nov 20, 2012, 04:45 PM
Rhondas is offline
Rhondas's Avatar
usa
Joined Dec 2004
so you say no need to scuff up with Krylon fusion painted on a monokote type covering heat shrink film, if its OK that's what im doing no scuffing ?
Old Nov 21, 2012, 07:33 AM
rcav8r2 is offline
rcav8r2's Avatar
Joined Sep 2001
Up to you I didn't scuff but I wasn't using Monocoto, I used Ultracote. SHOULD be the same, but.... Stuck GREAT. Scuffing certainly can't hurt, but I had small areas masked off, and I was afraid scuffing the masked areas would peel back or tear the tape.
Try it on a mocked up test piece first.
Old Nov 21, 2012, 10:45 AM
Rhondas is offline
Rhondas's Avatar
usa
Joined Dec 2004
scuffing
Thanks for the tip
Discussion How do I apply trim over Monokote u2builder The Builders Workshop 4 Jun 03, 2015 04:57 PM
For Sale New! Monokote, paint, glues, motors, batteries etc. C_Heath Aircraft - General - Miscellaneous (FS/W) 1 Jul 02, 2012 07:25 PM
Discussion Painting over monokote? KMKAZE Painting and Finishing Tips 2 Nov 30, 2009 09:05 PM
Question Lustrekote Clean over Monokote - how to? TheSaint The Builders Workshop 2 Sep 21, 2006 03:23 PM
Discussion Painting over monokote? mystang97 The Builders Workshop 1 Feb 12, 2006 11:54 PM
