Old Feb 06, 2013, 09:56 AM
resago is offline
Find More Posts by resago
Joined Dec 2012
I was flying my other heli last night in the fog, the E-1003 Comanche. the only mods I've done are I ripped off the stupid missile wings (Its a stealth Comanche, not an Apache!!), and I drilled out the flybar holder to allow more movement, oh and also put control rods on outmost servo holes.
I was banking turns in the fog and almost hit myself.
FUN!!
its gonna suck when the brushes wear out and I have to find a motor, the pcb does NOT have esc connectors like its cousin the f45. too bad. its 18 screws to open it up and get to the motor!!!
resago is offline Find More Posts by resago
Old Feb 06, 2013, 10:19 AM
Rajah235 is offline
Find More Posts by Rajah235
Just a 9116 flyer.
Rajah235's Avatar
Australia, NSW, Wollongong
Joined Dec 2012
My 1st delve into heli's was a similar model that had a marine hanging out the door with a damn great M/C gun.
It was on 27 MHz & when I turned it on, the thing took off & landed about 50 ft away in the grass.
I then did what I should've done before anything else.....& that is, a range check.
Power to both Tx & Rx, antenna not extended & walk away for about 60 ft or so.
When I did this, I didn't get any response from the heli after around 5 ft.
I then re-packed it, notified the dealer & sent it back. Got my $$ refunded.
It also had about 18 screws in the sides & no external access to anything.
A kids toy & very dangerous.
Oh yeah. & good luck finding a main motor for yours.
Feel like modding it?
Rajah235 is offline Find More Posts by Rajah235
Old Feb 06, 2013, 10:41 AM
resago is offline
Joined Dec 2012
I've heard it uses the same 370 as the f45.\
I guess I could get the f45 pcb and then get an esc and brushless motor for it.
or I might just put it on the shelf beside my hero 995
I have no complaints about how it flys now, range is beyond losing orientation.
Old Feb 06, 2013, 10:45 AM
Steve_ is offline
Find More Posts by Steve_
More Flights = Less Crashing
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Content Removed due to the fact that I do not agree with forum policy
here, and do not want them generating profit with my content.
Steve_ is offline Find More Posts by Steve_
Old Feb 06, 2013, 10:59 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Feb 06, 2013, 07:19 PM
JMCarlson is offline
Find More Posts by JMCarlson
Jeff Carlson
St. Paul, Minnesota
Joined Apr 2008
Hey Steve, yeah, you are probably right. Maybe It's just the size of it that I really like. To me it's the perfect size. And I do have an mSR and SR120 as well to fly inside, but the parts on those are SO small, they make it hard for these old eyes to work on. I have one of those magnifying lamps and without that wouldn't be able to work on em at all. Thanks again for the comments guys. It's good to be here and share the hobby
Regards,
JC
JMCarlson is offline Find More Posts by JMCarlson
Old Feb 06, 2013, 08:37 PM
jkoosh27 is offline
Find More Posts by jkoosh27
cut cut cut... ****!
jkoosh27's Avatar
United States, PA, Birdsboro
Joined Dec 2012
HOLY HECK is that new DD motor big..... I heard/saw pictures but they never did justice!
I need to get new blades.... my shorter blades are not cutting it anymore...(Balr14's prediction came true)ugh more time without flying, but the mod is in and I also need to get a better scale to figure out where I'm at....
But I actually got the bird in the air and am beginning to see some time in the air....If the blizzard doesn't hit Friday...
jkoosh27 is offline Find More Posts by jkoosh27
Old Feb 06, 2013, 10:01 PM
Ocoast is offline
Find More Posts by Ocoast
Ocoast's Avatar
United States, FL, New Port Richey
Joined Jan 2013
Servos
After about 70 flights, one servo died. Can anyone recommended a good after market replacement. Thanks.
Ocoast is offline Find More Posts by Ocoast
Old Feb 06, 2013, 11:52 PM
ajohnson677 is offline
Find More Posts by ajohnson677
Joined Jan 2013
Does anyone know the actual head speed of a stock 9116? Even a ball park range would be appreciated. And how many amps is the stock motor pulling during flight?
ajohnson677 is offline Find More Posts by ajohnson677
Old Feb 07, 2013, 12:15 AM
Gygax is offline
Find More Posts by Gygax
FPV Plank Scratcher
Gygax's Avatar
Australia, NSW, Keerrong
Joined Jan 2013
apparently the turnigy 1440a is the one to go for.
http://www.hobbyking.com/hobbyking/s...+1440a&x=0&y=0
Gygax is offline Find More Posts by Gygax
Old Feb 07, 2013, 06:15 AM
Rajah235 is offline
Just a 9116 flyer.
Rajah235's Avatar
Joined Dec 2012
For ajohnson677...
Current draw is "normally" in the 4 to 7 Amp range, according to Steve's figures.
Head RPM? Don't know just yet, coz my digital tacho hasn't arrived yet.
Hopefully, it shouldn't be tooooo much longer.
Keep watching.
Old Feb 07, 2013, 06:35 AM
Pa flyer is offline
Find More Posts by Pa flyer
Joined Aug 2012
Don't think they'll work
Originally Posted by Steve_ View Post
Here is an arm that is closer to the ratio of the F645.
These are from my thrashed HK250GT head.
There are four of them, and none of them appear to be damaged.
If you look at the design of the 9116 with the balls on the arms an equal distance from the pivot point both the blades and the balance bar meet the stops at the limit of their travel at the same time. If you increase the distance of the ball for the balance bar from the pivot point the balance bar will "bottom out" before the blades have reached their limit of movement. The result is going to be reduced cyclic response. I checked out my V911 with the unequal distance on the mixing arm and it is engineered so that both the blades and balance bar meet the stops at the same time.
If the purpose of unequal ball spacing is to reduce the balance bar's influence on the blades wouldn't we be essentially achieving the same goal by reducing the balance bar end weights anyway?
Pa flyer is offline Find More Posts by Pa flyer
Old Feb 07, 2013, 07:53 AM
Pa flyer is offline
Joined Aug 2012
I had the exact same reaction when I unpackaged it. I had to shorten the tail boom 3/4" to balance the heli out. I don't know if that is even going to be enough because I'm waiting on my Turnigy servos and don't have any mounted in the heli. Might have to move the battery forward.
Old Feb 07, 2013, 08:15 AM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Balr14 is offline Find More Posts by Balr14
Old Feb 07, 2013, 09:24 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
