Old Feb 04, 2013, 04:53 PM
Steve_ is online now
Find More Posts by Steve_
More Flights = Less Crashing
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Content Deleted.
Steve_ is online now Find More Posts by Steve_
Old Feb 04, 2013, 05:25 PM
Laidback_racer is offline
Find More Posts by Laidback_racer
Build the Weapon....
Australia, VIC, Berwick
Joined Jan 2013
Originally Posted by Steve_ View Post
Dang, what are your rates set to?
My EPA's are all at 100, and I can max out my swashplate
movement (the point where it begins to bind up) with my
rates set to 90%.
And I am using the hole on the arm next from last, so it isn't
even using all of the available movement.
Also, my new ball joints on the swashplate mount further from
the shaft, limiting travel even further.
(yes, I know they are crooked, I drilled them under a magnifier)
My rates are at 100%, so something is wrong.
The ELEV movement looks about the same as I remember with the stock servo, maybe I have a prob with the Tx, it was delivered in Mode 1 and I changed the pot positions. I have tried both vertical pots without noticing any difference. What servo are you using for ELEV?
Laidback_racer is offline Find More Posts by Laidback_racer
Old Feb 04, 2013, 05:49 PM
HPCR is online now
Find More Posts by HPCR
San Mateo, CA
HPCR's Avatar
United States, CA, San Mateo
Joined Dec 2012
I got rid of her years ago. Some other sucker pays for her lipstick now.
I will die alone, and enjoy every peaceful second of it.
The wind chimes are a great idea. I also have a hardware store close by.
But.. you could find a rich woman . She might be able to "keep you" so you can continue your expensive hobby ad infinitum! LOL
HPCR is online now Find More Posts by HPCR
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Feb 04, 2013, 05:57 PM
Pa flyer is offline
Find More Posts by Pa flyer
Joined Aug 2012
rates set to 90%.
Wouldn't it be better for a quicker response to cyclic input to use the outermost hole and reduce the epa percentage to limit movement?
Pa flyer is offline Find More Posts by Pa flyer
Old Feb 04, 2013, 06:05 PM
Steve_'s Avatar
Joined Nov 2012
Content moved to a more suitable location.
Old Feb 04, 2013, 06:09 PM
Joined Jan 2013
The other side has the original stock servo. It also is using
the hole next to the end.
I plan on replacing it soon.
Maybe your alternative servo is different?
My ELEV servo arm is centered, trims set to 0, EPA 120% and rates at 100%. I get about 15-20 deg movement of the servo arm. What are other people getting?
I tried both pots with no change, there does not seem to be any slop in the pots. The plot thickens...
Old Feb 04, 2013, 06:15 PM
Steve_'s Avatar
Joined Nov 2012
Old Feb 04, 2013, 06:41 PM
Joined Jan 2013
I'm getting at least 45 degrees at 75% rates and 100 EPA's,
At 100% I'm getting at least 70 degrees, and maybe 80.
(think slightly less than 3:00 to 6:00)
That is full throw, from extreme to extreme, passing center
along the way.
I'm glad I looked, because I noticed I need to move to the outer
hole. I am not getting linear travel, because of the small
radius of the servo arm.
That is way different to me, with the stock servo and stock PCB I was running running 120% EPA and 100% rates also and do not remember maxing out the travel. Here is a pic of mine at full movement, I am cheating with extended arms (I know bad news) but you get an idea of the angle and throw. I also have some AIL dialed in as the V912 PCB does not servo mix.
Old Feb 04, 2013, 07:10 PM
Steve_'s Avatar
Joined Nov 2012
Content Removed due to the fact that I do not agree with forum policy
here, and do not want them generating profit with my content.
Old Feb 04, 2013, 07:22 PM
Steve_'s Avatar
Joined Nov 2012
Swashplate movement
Old Feb 04, 2013, 07:56 PM
Joined Jan 2013
Here is my swashplate at center, and forward at 75% rate.
The ball links have been moved to the outer-most holes
on the servo arms. One arm is stock, and the other is not
quite as long, but close.
EPA's are set to 100, as I can max out travel with rates alone.
With rates at 85% and above, things start to bend, and
it has reached mechanical limits.
With my rates and EPA set to max and the servo arm extension I am getting full extension on the swash (similar angle to you), so I am getting there but interesting to see the different ranges in our gear.
I am playing around with a flybar mod that might also have some potential for increasing cyclic. I am waiting on a motor but I was thinking of putting a flybar angle restricter to reduce the throw of the flybar but still allow it to work as standard within that range. So the flybar can work as std in hovering position with small adjustments taking place via the flybar but when full cyclic is applied the restricted movement transferres back into cyclic. Hopefully this might provide a stable at hover bird with less pendulum effect but a lot more cyclic when needed. I have the ZR Z101 top end which should allow a washer or similar to be fitted under the flybar at the correct spacing to restrict further movement (no more bar strikes also). Something similar could be setup with the std 9116 head no doubt.
I have also bitten the bullet and ordered an Xtreme Pro 180A motor which will pair with the V912 rear motor and PCB. It might be a waste of time, but what the heck.
Steve_'s Avatar
Joined Nov 2012
Old Feb 04, 2013, 11:59 PM
JMCarlson is offline
Find More Posts by JMCarlson
Jeff Carlson
St. Paul, Minnesota
Joined Apr 2008
Hello all.........
Mail came today and brought the 9116.....I had 2, 7.4v 900mAh lipos waiting......flew around inside, hovers and small circuits.......nice little heli.............but can someone please tell me how to get the radio into settings mode ?............I followed the manual and the blog here.........and I cannot get into the settings on the radio.............Comments please. Thanks so much, Jeff
JMCarlson is offline Find More Posts by JMCarlson
Old Feb 05, 2013, 12:00 AM
ajohnson677 is offline
Find More Posts by ajohnson677
Joined Jan 2013
Really digging into my bird today. Replaced the main shaft and that fixed the vibration as well as taking care of my loss of pitch issue. Working on lightening her up. Dumb question: can i mount the RX board vertically or will this fail because of the gyro? I cant remember if the 9116 has a tail gyro or a real gyro.
ajohnson677 is offline Find More Posts by ajohnson677
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
