Old Feb 04, 2013, 11:01 AM
Steve_ is offline
Find More Posts by Steve_
More Flights = Less Crashing
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Content Deleted.
Steve_ is offline Find More Posts by Steve_
Old Feb 04, 2013, 11:08 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Feb 04, 2013, 11:14 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Feb 04, 2013, 11:37 AM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
Originally Posted by Steve_ View Post
The original stock tail motor has flat sides, and this motor is round.
I had to take a Dremel and a grinding wheel to the inside of the
motor mount and make it round.
I'm not sure if Mike put this information in the DD tail thread or not,
but it is required if you want the motor to seat without issues.
No, I didn't mention it. Nor even made any thoughts about this 'ickle flat spot inside the mount - it fitted well enough for me without grinding it away.
Plus I didn't want to mention a "HighTech-Tool" like a Dremel in my Mini How-To - it was designed for beginners that may not have such things.
Changed that
Thanks, Steve!
-mike-
mikefromgermany is offline Find More Posts by mikefromgermany
Old Feb 04, 2013, 12:03 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Feb 04, 2013, 12:12 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Feb 04, 2013, 12:24 PM
Rajah235 is offline
Find More Posts by Rajah235
Just a 9116 flyer.
Rajah235's Avatar
Australia, NSW, Wollongong
Joined Dec 2012
A little dip of the plastic mount in some boiling water allowed it to just pop in....no probs.
I should've used it to stir my coffee with.
Maybe, ^, they've hired trained gorillas?
or should that be "Untrained?"
Rajah235 is offline Find More Posts by Rajah235
Germany, Berlin
Joined Jun 2012
I like everything to be perfect.
On a 9116, that's kind of an oxymoron...
True words.
I just got my replacement stock motor, and the pinion is mounted exactly the same way.
What the hell is going on @ Double Horse?
This is getting ridiculous....
Hey... this is a good motor that passed the QC - it has the pinion NOT falling off....
back to serious: it is unbelievable how deep DH is sunk.
If DH would have built the Titanic it wouldn't even got to that iceberg....
-mike-
Old Feb 04, 2013, 12:36 PM
Rajah235 is offline
Just a 9116 flyer.
Rajah235's Avatar
Joined Dec 2012
Mike, That's a really "flash" avatar.
Has anyone paid the extra postage as a quicker way to receive stuff from China?
I'm getting really annoyed with this waiting.
I've got 2 iMax chargers on the way, a couple of heatsinks & those BB 180 motors plus lots of bits for the S 16D's.
Damn. That's enough to rot your socks, Steve. The 3 motors that I got a few weeks ago have the gear at the "correct" position.
L..
Old Feb 04, 2013, 12:48 PM
Germany, Berlin
Joined Jun 2012
L..
No - no need for me to pay extra - I'm ordering LOOOONG in advance and spares for a certain bird even before I'm ordering the bird itself.
German nature, I guess....
It all depends how you handle it.
In my experience you can have RC items
1. cheap
2. fast
3. in good quality
Unfortunately you can only choose 2 out of these three at the same time.....
-mike-
Edit: glad you like my avatar - even it shows no helo
Old Feb 04, 2013, 12:53 PM
Rajah235 is offline
Just a 9116 flyer.
Rajah235's Avatar
Joined Dec 2012
I'm just trying to stock up on spares though.
I've received a quite few but this last lot is getting b*$#@# ridiculous.
Old Feb 04, 2013, 01:18 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Feb 04, 2013, 02:00 PM
Rajah235 is offline
Just a 9116 flyer.
Rajah235's Avatar
Joined Dec 2012
Well, I got a refund for an iMax that hadn't arrived after 6 weeks, so I ordered another from a diff supplier & just because I added another couple of (out-of-stock) heatsinks to the order, they won't post until they re-stock. (They weren't o-o-s a few weeks ago.)
Can understand that they're saving me postage but I'm stuck without a good charger.
L..
Old Feb 04, 2013, 04:11 PM
Laidback_racer is offline
Find More Posts by Laidback_racer
Build the Weapon....
Australia, VIC, Berwick
Joined Jan 2013
Laidback_racer wrote..
The 1440's come with a selection of arms or at least, mine did.
I just used the same length one as the stock but there is also a longer one.
As for the end stops? was it? changing... I'd be checking your EPA's are not set too high.
Start from scratch with no arm on the servo & centralise the trims etc, then replace the arm
& see what happens. Maybe drop your %'s down a tad?
As you know...the gearbox has mechanical stops in them. They will not go further than about 120/140 Degs full throw, normally.
If you set them in-correctly, you'll strip gears or burn the tiny motor out.
Yes the end stops seem to have changed, I was using my thumb with the power off to check the full movement of the servo, when new the throw was half what it is now. Perhaps they are tight when new and only feel like they are coming up against the bump stops? The longest servo arm supplied with my Turnigy is the same length as stock.
My EPA's are set to 120%, I tried lower but that further reduced the travel. I am using a diff PCB which may be a factor although I suspect the Tx is not allowing full movement. If I hook up my std V911 Tx the movement is even less which shows the importance of how the Tx is programmed. Perhaps with my setup (V912 PCB) and a Turnigy 9x Tx the servo throw could be extended, but the cost is getting ridiculous of course. But more servo throw and a higher head speed from a better motor with perhaps less flybar weights could make this bird flyable in light wind conditions.
Laidback_racer is offline Find More Posts by Laidback_racer
Old Feb 04, 2013, 04:15 PM
Joined Jan 2013
I don't have any wag at all with the new Honey Bee CP3 direct
drive motor and prop. The only issue is a slight "bounce" if
you quickly reduce tail from a fast spin. If the rudder rate is set
to 35% or below I don't get any bounce at all, and 35% is more
than fast enough for any scale flying.
Sorry Steve, I meant the previous tail engine (syma if I recall?)
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
