At the end of the day this bird is probably only good for windless days and warehouse flying so I will probably leave it how it is, but will look at better motor options when I need to replace, I am waiting to see if anyone runs the 180A Pro or the V912 main (with chassis mods) with a larger tail motor. The 9116 is great work horse for some basic learning and is really helping me get ready for my Storm 450. I have set up the Storm with a pitch curve of +5 at the bottom and +10 at the top (almost an fp setup) so I can transition slowly and will gradually wind in more neg pitch as I go. |
I measured the 9116 and it comes out around +15 but as you said a much slower head speed. Theoretically if we got more head speed and a bit more cyclic the 9116 could be good. I did read Capt Jacks "dont touch the controls" and "3D is not for everybody" threads, some really helpful stuff in there. The 9116 had already taught me with all the indoor hovering not to lean on the sticks, instead just do lots of little short corrections, so one valuable lesson courtesy of the 9116. The V911 is so stable that skill is not necessary. UPDATE: Today I had an observation that may help you Steve, I am running the same tail engine as you and was also noticing the tail wag recently. You can hear the tail motor changing revs up and down and not holding a steady or linear spin. My main motor finally went today (luckily was only about 10 feet off soft ground) but now when holding the heli without a mains working the tail motors spins perfectly even without hesitation. I wonder if the bad brushes are creating interference through the PCB. I have observed this on the original PCB and the current V912 PCB I have in place. I also rewired the tail motor opposite and although it cant be used it did rev very nicely also. Do you know if the heli the tail motor came from has a reverse pitch rear blade compared with the 9116? |
Something strange with my Turnigy servo's today. After some use the range from the bump stops seems to have increased to about the same or more than the std servo. Maybe they need a little wearing in to achieve their full potential?
But the Tx or PCB is only allowing a fraction of the possible travel....might be something to work on. |
Canada, BC, New Westminster
Joined Feb 2012
9x
I have been trying to see how we can use the 9x and get around the rudder issue described in an earlier post this year ( I.e. mike from Germany). I was not able to figure out how to resold this and have reached out for help from the 9xforums specifically from the er9x group. I will let you know what progress I make.
This evening I read a post from the v912 forum where a user has successfully used the 9x running er9x firmware to control the v912. I believe that laidback_racer posted that he installed the v912 pcb in the 9116 and I'm assuming that it is working well. If this is true, then this is great because I found a user that has setup the 9x running er9x. Here is the link to the thread on the v912 forum and the fellow indicated he will provide me with the settings he used on the 9x running er9x firmware. http://www.rcgroups.com/forums/showt...5#post24027868 I will let you know how I make out with this but it looks promising! |
Joined Aug 2012
We have to realize too that when we take an overweight, highly stabilized bird with all that weight hanging under a sloppy head and start lightening and tightening things up that it's not going to fly itself anymore. But isn't that what we were working towards ?
Joined Jan 2013
Hey all,
As of recently my 9116 seems to be constantly leveling itself off and taking away all of my forward pitch. On top of that, there's a fairly nasty vibration coming from somewhere. The blades aren't perfectly balanced but the vibration seems to be more than that. I bought this bird off of a friend who sent it down HARD several times and gave up. Had to replace the canopy, blades, landing skid, and throw on a new tailset. Hasn't hit the ground since and it seemed to be flying a lot better before I replaced everything. Everything passes the eye test but I'm wondering if I have a bent main shaft. Any ideas? The vibration is annoying, but my forward pitch cutting out is a bigger concern. It's a pretty boring bird when it wants to stop itself every 20 feet. |
Joined Aug 2012
As far as losing forward pitch: If you take the head off to check the main shaft, spool it up and hold forward cyclic and looking from the rear of the bird, watch to see if the servo arms maintain position or if they drop down. If they're dropping I would suspect a damaged pcb. I can't think of anything else that would arrest forward movement without cyclic input. It's very unlikely that it would be a tx problem. I'm assuming that the swashplate is adjusted properly and that it will hover well without moving rearward. |
Laidback_racer wrote..
I just used the same length one as the stock but there is also a longer one. As for the end stops? was it? changing... I'd be checking your EPA's are not set too high. Start from scratch with no arm on the servo & centralise the trims etc, then replace the arm & see what happens. Maybe drop your %'s down a tad? As you know...the gearbox has mechanical stops in them. They will not go further than about 120/140 Degs full throw, normally. If you set them in-correctly, you'll strip gears or burn the tiny motor out. Oh yeah, I forgot to mention... I've joined the Fixed Wing Club as well. Bought myself a foamie electric glider. ![]() Has a brushless motor, ESC etc & is 4 channel. All this for $56.00 Aus. Had to buy some small 2S 500 mAh batteries coz the heli ones don't fit, plus a few spares I think I'll need. & the DD tail motors/props have finally arrived. A tight fit in the original mounting but after applying a little heat, the motor finally bedded down nicely. Not fitted yet coz I've only just replaced the tail assy. No more on the S 16D bits. Geez, they're slow. |
| Thread Tools | |
| Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro | thercguy | Electric Heli Talk | 4 | Apr 16, 2013 03:13 AM |
| Question Double horse 9116 Heli | capo58 | Beginner Training Area (Heli-Electric) | 3954 | Dec 26, 2012 07:40 AM |
| Discussion New to Heli's - Double Horse 9116 or 9118 | kamma1124 | Coaxial Helicopters | 19 | Sep 28, 2012 10:08 PM |
| Question Starting with a new Double Horse 9116 | Scotticism101 | Beginner Training Area (Heli-Electric) | 3 | May 15, 2012 01:36 PM |
| Discussion 9116 Double Horse | Daza1964 | Beginner Training Area (Heli-Electric) | 1 | Mar 26, 2012 09:22 AM |
