Old Feb 02, 2013, 05:53 PM
Steve_ is offline
Find More Posts by Steve_
More Flights = Less Crashing
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Content Deleted.
Steve_ is offline Find More Posts by Steve_
Old Feb 02, 2013, 05:58 PM
SysCrusher is offline
Find More Posts by SysCrusher
United States, FL, Jacksonville
Joined Jan 2013
Originally Posted by Steve_ View Post
Get out your soldering iron, and remove the leads from the motor, and
test it again. You might be measuring a short in the MOSFET or wiring.
Did you bypass the red loop on the board? Leaving that alone has
saved my PCB twice now when I had motors short out.
When I had it bypassed, if a motor shorted out, it took the PCB with it.
It's amazing how much magic smoke they put inside those transistor thingies.
Yup, I did that. Motor completely disconnected and it still measures out at 0.7 ohms. There is no red loop on the 9100. That seems to be a design flaw.
Guess I'm stuck with my boring modified S107G for awhile. I have plenty of soldering equipment. I build preamps, amplfiers for musical instruments; another one of my hobbies. At least that sort of pays for it self. lol
SysCrusher is offline Find More Posts by SysCrusher
Old Feb 02, 2013, 06:11 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Feb 02, 2013, 06:43 PM
curlyrocks is offline
Find More Posts by curlyrocks
Joined Jan 2013
Hello and help please
Have 9116 and have it leveled in, tx is set right but when I take off she drifts backwards and triming it does not help. Do I need to tape a nickel to the nose or can I reset something in the tx that will help me.
curlyrocks is offline Find More Posts by curlyrocks
Old Feb 02, 2013, 07:02 PM
Dweenie is offline
Find More Posts by Dweenie
Mr. Crash and Burn
Joined Jan 2013
Wow, a CP ducted fan... that would be incredible, I didn't know
anyone had done it.
Used along with thrust vectoring, you could make anything fly well,
and the stuff that already flies well would be unbelievable.
Talk about stopping on a dime...
That quad is sick. He was doing forward flips with no loss in altitude.
It also looks like all the blade tips are lit.
check out his youtube channel he has another video (daytime ) with a gopro on it doing flips its amazing
Dweenie is offline Find More Posts by Dweenie
Old Feb 02, 2013, 07:03 PM
Pa flyer is offline
Find More Posts by Pa flyer
Joined Aug 2012
__________________________________________________ ________
In an effort to stop momentary power loss to my 9116 (which turned out to be some sort of radio interference) I bypassed the MOPS. I don't want to pull the pcb out of the heli to undo the bypass. Can I splice a fuse or something into the wire to the main motor to protect the pcb in the event of a motor failure?
Pa flyer is offline Find More Posts by Pa flyer
Old Feb 02, 2013, 07:16 PM
Pa flyer is offline
Joined Aug 2012
If I decide to buy the brushless equipment to upgrade the 9116,
I found a use for the components if it does not work.
https://www.youtube.com/watch?v=vCxzFSr48z8
I was looking at my 9116 and trying to figure out where there would be room to mount a rx and two esc's. Judging by the size of those components on my Wasp X3V fbl (also a 250 class) and the sideplate configurations on the 9116, I don't see how it could be done. Are there miniature versions that I'm not aware of? I would be happy to be wrong!
Old Feb 02, 2013, 07:33 PM
Joined Jan 2013
Couldn't find any pcb and transmitter. Couldn't even find another 40mhz rx so that left to get another rx/tx in the 49mhz but the cost of that and shipping cost the same as another 9100.
But, I found another rx for the 9104 that would work just fine. Has the bigger mosfets with holes to mount heat sinks.
Old Feb 02, 2013, 07:43 PM
sixx4 is offline
Find More Posts by sixx4
Joined Dec 2012
Tail Motor stops spinning when left rudder is used (Double Horse 9116)
Hey Guys,
I'm a NEWBIE to RC Helis. I purchased a Double Horse 9116 for Christmas. Flown it a few times (lots of crashes but nothing major, except for a burned tail motor) . I replaced the motor with a new tail motor (upgraded). After a few more flights (minor crashes) I noticed that when I would move the rudder to the left I had no control and the tail motor would stop spinning ( It works fine when rudder is to the right and at all stages of the throttle). Any help in what could be the problem and how to fix it would be GREATLY appreciated. I've learned a lot in just the month of reading the threads. Thanks
sixx4 is offline Find More Posts by sixx4
Old Feb 02, 2013, 07:46 PM
HPCR is offline
Find More Posts by HPCR
San Mateo, CA
HPCR's Avatar
United States, CA, San Mateo
Joined Dec 2012
Originally Posted by sixx4 View Post
Hey Guys,
I am interested in hearing more on this. I also posted a few messages in the last few days. I have a different problem but I bet you it going to be the same components that are dying ( or are dead)
HPCR is offline Find More Posts by HPCR
Old Feb 02, 2013, 08:45 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Feb 02, 2013, 08:51 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Feb 02, 2013, 08:57 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Feb 02, 2013, 09:05 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Feb 02, 2013, 09:12 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
