Old Jan 31, 2013, 09:50 AM
Rajah235 is offline
Find More Posts by Rajah235
An RC Yachtie.
Rajah235's Avatar
Australia, NSW, Wollongong
Joined Dec 2012
Hi Dweenie,
Nope. Not installed yet. Still in the exploratory mode.
I'll have to remove a small portion from both the "angled side plates"
to accommodate the slightly wider girth of the S16D.
These S16D slot car motors are rated at 12 Volts & we supplied more at race time.
Running them on 8 Volts & with not much load, will wait 'n see but they should be a heap better & more reliable + they're serviceable.
That....is what I'm after.
In a previous post, I mentioned that the applied voltage (E) & current (I) readings of the stock & the S16D were very similar.
After running the brushes in, I expect the S16D to be better.
L..
Rajah235 is offline Find More Posts by Rajah235
Old Jan 31, 2013, 09:55 AM
Steve_ is offline
Find More Posts by Steve_
Venting Nowlege
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Content Deleted.
Steve_ is offline Find More Posts by Steve_
Old Jan 31, 2013, 10:01 AM
Rajah235 is offline
An RC Yachtie.
Rajah235's Avatar
Joined Dec 2012
Thing is though Steve....How much solder & insulation tape/heat shrink did you use?
Might have negated the whole exercise.
Old Jan 31, 2013, 10:13 AM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 31, 2013, 10:17 AM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 31, 2013, 10:28 AM
Rajah235 is offline
An RC Yachtie.
Rajah235's Avatar
Joined Dec 2012
The S 16D's will cost you $ 13.99.
Extra brushes & springs are $1.49 per 2 pack.
Plus postage.
Old Jan 31, 2013, 10:31 AM
Dweenie is offline
Find More Posts by Dweenie
Mr. Crash and Burn
Joined Jan 2013
Plus postage.
but the real question is wander what the flight record will be for those motors vs the steep 33 one time fee for the brushless setup
have you tried to even power up the s16d motor on the 9116's voltage to see if the rpms are going to be right
Dweenie is offline Find More Posts by Dweenie
Old Jan 31, 2013, 10:39 AM
Rajah235 is offline
An RC Yachtie.
Rajah235's Avatar
Joined Dec 2012
Dweenie,
If I had access to a tacho, then I'd do that check but seeing as I ain't......?
No way to test until it's installed.
But...I ran both motors at varying voltages & the stock motor was very happy at 12 Volts.
The current draw was the same with both.
The RPM's sounded similar but......(see the above.)
L..
For more details, see my previous post.
> http://www.rcgroups.com/forums/showt...7#post23830662
Old Jan 31, 2013, 10:59 AM
Dweenie is offline
Mr. Crash and Burn
Joined Jan 2013
Dweenie,
L..
its just that im not very smart with dc voltage but if you under volt a brushed ac motor it causes it to heat up and shut down and wear out quicker
Old Jan 31, 2013, 11:00 AM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 31, 2013, 11:21 AM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 31, 2013, 11:43 AM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 31, 2013, 11:48 AM
Rajah235 is offline
An RC Yachtie.
Rajah235's Avatar
Joined Dec 2012
.....^^....."Eggszactly".
I encountered a slight glitch.
One of the old 16D's that I picked up has an 8 tooth pinion, which I duly removed.
I tried it on the new S16D & oh horrors....it slid onto the shaft. (Well, it was a solder on type, after all. Strange but true.)
Naturally, you cannot solder to these shafts so what to do next?
I had another cuppa while fruitlessly searching on eBay & then it hit me......Why not try the original stock motor 8 tooth pinion?
I've got 3 new ones in my spares box.
After careful removal with my trusty old, home made gear puller, I approached the S 16D.
Yippee! It's a press fit.
Anyone got a small hammer? Just kidding.
I'm all set in the motor/pinion dept.
All I need now, is to dismantle the relevant sections & insert the new frame plate plus motor.
L..
Old Jan 31, 2013, 12:27 PM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 31, 2013, 01:05 PM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
