Old Jan 30, 2013, 01:57 AM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
Originally Posted by Gygax View Post
thanks mike.
ive levelled the swash and servo arms and whilst the heli is fairly stable, i have been trying to find ways to steady up its hover as much as i can. even indoors there is still a little drift. i often read folks here saying they setup the 9116, level everything and then it hovers 'hands-off' for 5-6 secs.. it wont do that for me
the throttle also seems really jumpy and cant keep the heli at a constant height. it either climbs or drops but never sits still.. is this normal (indoors even)?? i read that theres a dead spot in the stick.. maybe thats the problem?
It is a known bug - hard to keep it float - you have to counteract early on and play with the throttle - try fixing the dead spot like Steve mentioned - it will help a bit. This bird isn't built to do fine measured hover anyway. So don't expect too much in accuracy.
-mike-
mikefromgermany is offline Find More Posts by mikefromgermany
Old Jan 30, 2013, 03:43 AM
Gygax is offline
Find More Posts by Gygax
FPV Plank Scratcher
Gygax's Avatar
Australia, NSW, Keerrong
Joined Jan 2013
just been practicing outside again.. you have to FIGHT the wind, but man its a zippy little bird.. im getting better at tweaking the throttle and figure now i have it adjusted as neat and tidy as i can, ill start fooling around more with the tx trim and epa stuff
thanks for the help with the voltage buzzer mike.. got it going fine and man is it an asset. nice and loud. the way it measures both cells, it highlights the need for a balancer. i just have the stock DH charger and batteries
Gygax is offline Find More Posts by Gygax
Old Jan 30, 2013, 04:50 AM
Rajah235 is offline
Find More Posts by Rajah235
Just a 9116 flyer.
Rajah235's Avatar
Australia, NSW, Wollongong
Joined Dec 2012
Hi Gygax,
I'm not relying on the stock charger too much, even though it's supposed to be a balanced charger.
The "Screamer" voltage checker shows 1 cell @ 4.26 Volts & t'other @ 4.63 Volts.
Way too high.
My DMM says about the same.
Will wait till my iMax balanced charger arrives before any more attempts at flying.
I have 3 x 850mAh Li-Po's sitting in my tool box but I ain't letting them anywhere near that stock charger.
Be careful when you adjust the EPA's. Remove the servo arms & check the max travel first.
After re-connecting the push rods, start low & go up slowly.
L..
Rajah235 is offline Find More Posts by Rajah235
Old Jan 30, 2013, 05:19 AM
Steve_ is offline
Find More Posts by Steve_
More Flights = Less Crashing
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Content Deleted.
Steve_ is offline Find More Posts by Steve_
Old Jan 30, 2013, 05:35 AM
Rajah235 is offline
Just a 9116 flyer.
Rajah235's Avatar
Joined Dec 2012
Steve, Does the "burst into flames" ref; to the original Li-Ion as well?
All new to me.
& I've read that the "salt water disposal" is not really the way to go.
I've just got the yachties used to Ni-cads & Ni-Mh & now they're converting to Li-Po's.
They just chuck them on the top of their car engines & set the charger & continue sailing.
I at least, bought a supposedly, safe bag for charging them & I've got a "genuine" iMax B6 AC coming.
L..
Old Jan 30, 2013, 05:41 AM
Pa flyer is offline
Find More Posts by Pa flyer
Joined Aug 2012
Warning
Originally Posted by Steve_ View Post
The stock boom is 6 grams. If the direct drive tail mod works really good,
I'm going to get raw carbon fiber rod and make my own booms. That will help
offset the extra weight of the bigger motor, and I will be able to play around'
with boom length.
http://www.ebay.com/itm/6MM-X-4MM-X-...item337f3a85af
You probably already know this, but just in case you don't. Take precautions when cutting carbon fiber. The dust is really nasty and you definitely don't want to breathe any and get those little nasty shards in your lungs. I keep the hose of my shop vac right next to the cut-off wheel when cutting it.
Pa flyer is offline Find More Posts by Pa flyer
Old Jan 30, 2013, 06:05 AM
Germany, Berlin
Joined Jun 2012
My next recommendation:
Get a sim!
I'm playing a little around with phoenix 4 and my Th9X since yesterday - it is really great for heli flying.
-mike-
Old Jan 30, 2013, 10:18 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 30, 2013, 10:20 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 30, 2013, 10:26 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 30, 2013, 10:29 AM
Germany, Berlin
Joined Jun 2012
Just got my new motor, (that was around 4 days, WOW)
but the pinion gear is mashed up against the frame.
Have any of you gotten motors like this? Should I try to move the
pinion, or just leave it alone and see how it flies?
move it - heat up with a soldering iron and use pincers to shove it up a bit.
-mike-
Old Jan 30, 2013, 10:40 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 30, 2013, 10:46 AM
Rajah235 is offline
Just a 9116 flyer.
Rajah235's Avatar
Joined Dec 2012
There are lots of older threads on the Li-Po battery safety & disposal subject.
> http://www.rcgroups.com/forums/showp...3&postcount=27
Vicious beasties aren't they?
Wonder who thought that using lithium batteries in consumer products was a good idea?
L..
Old Jan 30, 2013, 10:54 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 30, 2013, 11:01 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Keeping this one, it's cool
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
