Old Jan 23, 2013, 08:21 PM
Steve_ is offline
Find More Posts by Steve_
Venting Nowlege
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Content Deleted.
Steve_ is offline Find More Posts by Steve_
Old Jan 23, 2013, 08:57 PM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 23, 2013, 09:05 PM
jkoosh27 is offline
Find More Posts by jkoosh27
cut cut cut... ****!
jkoosh27's Avatar
United States, PA, Birdsboro
Joined Dec 2012
Originally Posted by Steve_ View Post
Found this little bit of information.
http://www.rcgroups.com/forums/showp...postcount=2792
"The problem is the encoding, not the potentiometer. The dead spot begins
and ends at the same value, it should be different. As if there is a severe
exponential at center stick which can only be done by the encoder." - Ribble
I should be able to verify this by checking the potentiometer.
If it has normal response, then this was done on purpose by the
radio designers, and would be difficult to overcome.
That is interesting....
As to the blades... I made an improvised balancing kit and I just finished the main blades... It is about as close as I can get it, and a roll test of the main shaft proved as close as I would dare take it...
Now the 9116 is spooled up as low as it can go, to drain the battery and its barely vibrating at low speed... I'm plenty happy, at least until the tail stuff finally gets in, at risk of being redundant
jkoosh27 is offline Find More Posts by jkoosh27
Old Jan 23, 2013, 09:25 PM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 23, 2013, 09:34 PM
jkoosh27 is offline
jkoosh27's Avatar
Joined Dec 2012
Do not drain the battery down! You will ruin it!
As soon as you see it start losing power, stop using it.
Li-Ion (stock 9116 pack) and LiPo (aftermarket) packs can only be discharged
to a certain point before permanent damage occurs.
I hope you didn't already damage it
You can run it down 30%, 50% or even 80% and charge it as many times
as you want. You can charge these at any discharge level.
But if you discharge to 100%, you will only do it once, and it could even start
a fire.
I only ever drain it till it cuts out.....if that was too far then uh woops?
haha its the stock battery and I knew I would end up getting the higher mah batteries anyway.....maybe I should have ordered them with everything else since bang good apparently takes forever.
but thanks for the warning steve
John
Old Jan 23, 2013, 09:49 PM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 23, 2013, 10:13 PM
aphex4000 is offline
Find More Posts by aphex4000
Joined Nov 2012
Originally Posted by Sipple31 View Post
I got mine from PowerHobby.com. Came quickly and was the correct one.
The 900mAh batt did fix my issues by the way.
What are guys doing for the canopy connections on the side? I hate the stock snap on/off things. Looking for something better as I have multiple batteries to be swapping in and out.
Thanks!
Thanks, Sipple31!
aphex4000 is offline Find More Posts by aphex4000
Old Jan 23, 2013, 10:54 PM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
9116 and 9117 Transmitter Dead Zones
Content Deleted.
Old Jan 23, 2013, 11:46 PM
simz is offline
Find More Posts by simz
enter a new realm.....
simz's Avatar
Joined Dec 2012
canopy mounts
alum. plate and a small alum screw facing outward..with a little piece of silicone tubing to dampen vibrations...it might weigh a tad more (not by much),,but if it is damaged, you can just bend it back..
the canopy kinda free floats on the set up..
hope this gives you some kind of idea..post is in response to sipple31 or for anyone else for that matter..
simz is offline Find More Posts by simz
Old Jan 24, 2013, 12:02 AM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
9116 9117 Transmitter Extra Cell
Content Deleted.
Old Jan 24, 2013, 05:13 AM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 24, 2013, 05:50 AM
Rajah235 is offline
Find More Posts by Rajah235
An RC Yachtie.
Rajah235's Avatar
Australia, NSW, Wollongong
Joined Dec 2012
Steve wrote...
But taking it this far is kind of silly for a $15 transmitter.
You got ripped off Steve. I only paid $7.00 for mine.
Rajah235 is offering some for pretty cheap....
Ummm, Yeah.
I will need your address............................ when they arrive.
I always run the cheapest alkaline batteries I can find & not bother with re-chargeables.
(I like to supply the rated voltage.)
A local hardware store has the "Varta" brand, Alkaline on sale for $8.90 for a pack of 30.
So, I bought a few.
I run these in my Spektrum Dx5e on my IOM yacht.
All this talk about the "dead band" on these Tx's made me think. (Hard to imagine, I know.)
I shall endeavour to check the new/spare Tx against the original.
I didn't see any great "play" in the sticks, shaft to pot region, but will investigate further.
After-all, the axis shaft is just pushed into the pot. It ain't a press fit.
(As Steve found out.)
On mine...There's a slight dead spot in the left aileron when first applied.
The right aileron works smoothly, with no hesitation.
I put this down to the mechanical set-up & not electrical. The pots measured O.K.
L..
Rajah235 is offline Find More Posts by Rajah235
Old Jan 24, 2013, 06:13 AM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 24, 2013, 06:44 AM
Rajah235 is offline
An RC Yachtie.
Rajah235's Avatar
Joined Dec 2012
For jkoosh27...
You can always use one of these..."Low Voltage Buzzers" as Mike posted in his blog.
> http://www.rcgroups.com/forums/showthread.php?t=1750650
Cheap as chips from eBay.
Search for > LIPO Battery Tester Low Voltage Buzzer Alarm Indicator RC 1S - 8S
Old Jan 24, 2013, 07:08 AM
Sipple31 is offline
Find More Posts by Sipple31
Sipple31's Avatar
United States, WI, River Falls
Joined Jan 2013
Interesting... thanks for the idea.
Sipple31 is offline Find More Posts by Sipple31
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
