Old Jan 23, 2013, 04:30 PM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
Originally Posted by Steve_ View Post
That was (I think) for a defective throttle potentiometer that had a dead spot.
I guess it's possible it's the pot, and will check it when I have time.
But why would it fail in the same spot for everyone?
I think it may be part of the strange PCB programming, such as the
drifting cyclic servo based on throttle input, where the designers were
trying to make it easier for beginners to fly.
I could be wrong, and as soon as I figure it out, I will post.
The fastest way to find out is to bind to a V911 and see if still appears.
Yupp - it was for the throttle pot - but may help for the other stick, too.
Imho it would be much more promising to work on the 9x-throttle problem.
-mike-
edit:
I have three 9116 TX left - none of them has a dead spot. Using 2 of them to handout to interested kids / my daughter already bound to a V911 or Xieda 9958
mikefromgermany is offline Find More Posts by mikefromgermany
Old Jan 23, 2013, 04:31 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Balr14 is offline Find More Posts by Balr14
Old Jan 23, 2013, 04:52 PM
Steve_ is offline
Find More Posts by Steve_
More Flights = Less Crashing
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Content Deleted.
Steve_ is offline Find More Posts by Steve_
Old Jan 23, 2013, 05:09 PM
Germany, Berlin
Joined Jun 2012
Like I said, I think it is programmed into the PCB.
If you can fly a V911 with the 9116 TX, with no dead spots, then it's
the PCB.
It's not really a dead spot, it's actually huge deadband, where small
stick movement results in zero servo movement.
And it only happens on forward cyclic. Both Pa Flyer and myself have
noticed it after increasing cyclic sensitivity.
Reverse cyclic does not show the same behavior, and you get servo
action as soon as you start to move the cyclic stick back.
Hm, you may be right.
I had experienced no dead spot with my stock TXes with my two 9116 also, but that may be because I keep my birds as stock as possible - only slight changes for 9116 #1 and no changes at all for #2.
So I'm no help solving this malfunction.
-mike-
Old Jan 23, 2013, 06:05 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 23, 2013, 06:30 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 23, 2013, 06:32 PM
Pa flyer is offline
Find More Posts by Pa flyer
Joined Aug 2012
V911 too
the PCB.
Both Pa Flyer and myself have noticed it after increasing cyclic sensitivity.
I use the 9116 tx with my V911's and they exhibit the dead spot also: that's why I think the problem is in the tx.
Pa flyer is offline Find More Posts by Pa flyer
Old Jan 23, 2013, 07:04 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 23, 2013, 07:34 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 23, 2013, 07:56 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 23, 2013, 07:57 PM
aphex4000 is offline
Find More Posts by aphex4000
Joined Nov 2012
Argh...I'm trying to get ahold of a Xtreme 180 (A) motor but they seem to be scarce, or just sold in matching sets. Does anyone have a recommendation for a retailer?
aphex4000 is offline Find More Posts by aphex4000
Old Jan 23, 2013, 08:33 PM
Laidback_racer is offline
Find More Posts by Laidback_racer
Build the Weapon....
Australia, VIC, Berwick
Joined Jan 2013
I just tested my servo movement on the V911 with the std Tx and the 9116 Tx. The std Tx had a slight lag in forward cyclic only, but returned to centre every time. The 9116 Tx had no lag in any direction, but the return to centre on the elevator was all over the place. I noticed this on the 9116 before it went on blocks. So with a loose head, Tx dramas and twitching servo's I had no hope of maintaining a stable hover. I might try swapping the elev and throttle pots to see if there is a change, I also have a V912 PCB on the way, but on the Banggood very slow boat.
My 9116 is dead but perhaps someone with the mid stick deadspot could try a V911 Tx on the 9116?
Laidback_racer is offline Find More Posts by Laidback_racer
Old Jan 23, 2013, 09:04 PM
jkoosh27 is offline
Find More Posts by jkoosh27
cut cut cut... ****!
jkoosh27's Avatar
United States, PA, Birdsboro
Joined Dec 2012
Originally Posted by Balr14 View Post
A word on trimming blades: reducing the length of the blades reduces stability because it decreases blade tip speed.
Yeah I figured it had as much of ill effects but I just wanted to have it able to lift off even if it was a little less stable. As it was it wobbled so bad I didn't wanna keep flying it that way.
As to the dead spot, I'm suffering from it too. Or at least I was until it started running its own dizzy race....
I wish I knew more about the electronics to help but I don't know quite as much as some others **cough steve cough**
jkoosh27 is offline Find More Posts by jkoosh27
Old Jan 23, 2013, 09:14 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 23, 2013, 09:16 PM
Sipple31 is offline
Find More Posts by Sipple31
Sipple31's Avatar
United States, WI, River Falls
Joined Jan 2013
I got mine from PowerHobby.com. Came quickly and was the correct one.
The 900mAh batt did fix my issues by the way.
What are guys doing for the canopy connections on the side? I hate the stock snap on/off things. Looking for something better as I have multiple batteries to be swapping in and out.
Thanks!
Sipple31 is offline Find More Posts by Sipple31
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 04:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 08:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 11:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 02:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 10:22 AM
