Old Jan 22, 2013, 09:45 PM
Steve_ is online now
Find More Posts by Steve_
Venting Nowlege
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Content Deleted.
Steve_ is online now Find More Posts by Steve_
Old Jan 22, 2013, 10:10 PM
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
9116 Aluminum Frame
Content Deleted.
Old Jan 22, 2013, 10:19 PM
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 22, 2013, 10:25 PM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
Originally Posted by aphex4000 View Post
Whoo, the new chassis finally came in! This little bird is definitely more responsive with the slight CG change.
one word: WOW!
-mike-
*jealous*
mikefromgermany is offline Find More Posts by mikefromgermany
Old Jan 22, 2013, 10:32 PM
aphex4000 is offline
Find More Posts by aphex4000
Joined Nov 2012
Steve_, thanks! There are a few issues. The screw holes furthest to the rear were misaligned by .73mm so I had to slot the holes in the side plates to get the screws in. I would also like to make the battery mounting plate longer so it can be screwed into the upper deck once it's flipped into position. Finally, the plate cost $8.55 to print which is ridiculously expensive considering the overall cost of our 9116s, right? Finally, I want to perform some more thorough testing on the possible issue with the revised gyro orientation. I'll take it out this weekend for a "spin"...har har
I want to trim my balance bar weights as well. It sure would be nice to improve response and not to have to worry about the canopy and tail boom taking a beating all the time. I like your trimmed side plate and have been thinking about building up the lower chassis and side plates(bowed outward to absorb crash impact) as a single piece, but it could get unjustifiably expensive.
Yes, the plastic can be dyed, but it can also be printed in a few other colors.
aphex4000 is offline Find More Posts by aphex4000
Old Jan 22, 2013, 10:33 PM
Joined Nov 2012
Danke, mike!
Old Jan 23, 2013, 01:48 AM
letsstart78 is offline
Find More Posts by letsstart78
Canada, BC, Vancouver
Joined Jul 2012
hello guys, I am having hard time to find battery for my 9116.I have this 1700 mah 2s1p batter but it is so heavy. can I separate two batteries and use each of them as 7.4v 850 mah battery? how can I do it? which cable must go where? I apriciate your help thank you http://www.dualsky.com/pro_list_for....lid=139&id=138
letsstart78 is offline Find More Posts by letsstart78
Old Jan 23, 2013, 02:17 AM
Joined Jul 2012
discard this msg please. I couldnt delete it.
Old Jan 23, 2013, 02:24 AM
Germany, Berlin
Joined Jun 2012
if you rip it apart you will get 2 batts 1s 1700mAh.
fitting batts:
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
-mike-
Old Jan 23, 2013, 07:10 AM
Pa flyer is offline
Find More Posts by Pa flyer
Joined Aug 2012
Will there be a problem with lightened flybar and dd tail?
[QUOTE=Steve
The amount of extra cyclic you are getting can double if you trim the
balance bar weights. I started with 2.2 grams, then moved to 1.1 grams.
The stock weights are 3.5 grams each, I believe.
My battery is also mounted slightly higher than yours.
Now it's so lively, it's almost like a CP.
Most people can't handle it. [/QUOTE]
The stock weights figure out to 3.66 grams. I have mine down to 9.5 grains and the blades are trimmed to 17 mm near the grips and 15.5 mm at the ends. It still hovers at or just slightly above half throttle. I may trim them just a leeetle more!
With the reduced torque acting on the tail motor from those two mods I had to program in 80 points of rudder trim or the tail motor overpowers the main motor. Now I'm wondering if I'll have enough trim left to compensate for the dd unit. Might wind up trimming down the tail rotor blades.
You're right about it being almost like a cp. It'll drift off in the direction of the last cyclic input and has much lessened self leveling tendencies. If we could find stiffer blades to eliminate the coning it would react just like a cp. And the increased head speed sounds more cp like. I'm also thinking that the reduced drag and load on the main motor may help it's longevity, since it revs higher at the same throttle setting.
Pa flyer is offline Find More Posts by Pa flyer
Old Jan 23, 2013, 07:28 AM
Pa flyer is offline
Joined Aug 2012
Unbelievable!
[QUOTE=aphex4000;23898579]Whoo, the new chassis finally came in! This little bird is definitely more responsive with the slight CG change.
I reversed the PCB in the design without giving gyro orientation any thought, but these posts about having to move the reversed gyro behind the axis of rotation make sense. The strange thing is, I don't have any spinning issue with the new layout. I don't get it...
Wow, you did a fantastic job! That's taking modding to a whole new level. I didn't even know that it was possible for the average Joe to have something like that done.
I also reversed mine without a thought to gyro placement. It's in front of the main shaft and works fine. In retrospect it sure does seem logical though that it would have to be behind the main shaft.
Old Jan 23, 2013, 08:22 AM
Germany, Berlin
Joined Jun 2012
If you are able to do the CAD part by yourself it is possible and not even expensive.
Still a real amazing piece of design, made with with Teutonic thoroughness
-mike-
Was just reminded on an old joke:
http://www.witze-witze.eu/sonstige-w...-der-welt.html
Old Jan 23, 2013, 08:56 AM
Rajah235 is offline
Find More Posts by Rajah235
An RC Yachtie.
Rajah235's Avatar
Australia, NSW, Wollongong
Joined Dec 2012
It's just a beautiful job though.
What colour are you getting Steve?
Mike... Ab Fab.
There's an old watch makers tale on a similar vein.
Well guys 'n' gals,
I still haven't received my "super light" 16D motor yet, so no progress to report.
It looks like I'll have to chop away....errr, modify the upper frame slightly, to accommodate the slightly larger girth of it. (or put it on a diet.)
Oh yeah. I bought 2 (4) of those ball bearing 180's, plus brushes as well, as a back-up plan.
Put your hand up if you want to "give one a whirl" & I'll send you one.
Will see if the S 16D carbon brushes fit the 180 motors, when they eventually fly in.
Rajah235 is offline Find More Posts by Rajah235
Old Jan 23, 2013, 09:55 AM
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 23, 2013, 10:00 AM
Rajah235 is offline
An RC Yachtie.
Rajah235's Avatar
Joined Dec 2012
How much for the 180 motor, Steve?
It's a Freebie.
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
