Old Jan 21, 2013, 11:59 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Innovators
Balr14 is offline Find More Posts by Balr14
Old Jan 22, 2013, 08:37 AM
Steve_ is offline
Find More Posts by Steve_
More Flights = Less Crashing
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
This is a really good deal for you electronics experts out there.
I'm certain the battery circuitry could be reverse engineered and cloned.
I don't have the time or resources for such a project, or I would be hocking
stuff to buy them.
For someone who is retired, has plenty of electronics knowledge, and a small
lathe and machining center (for part replication) these would be an awesome
project, and a cheap way to get started with the "good stuff".
These things even wag the tail when the battery gets low.
He gave me some equipment to get started in CP birds a few months ago,
and all of it was in great shape and well cared for. All of it looked brand new.
If the equipment he gives away is in such great shape, you can imagine how well
these have been cared for.
Thanks again Balr14 for getting me started with the "good stuff"
Steve_ is offline Find More Posts by Steve_
Old Jan 22, 2013, 09:11 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Moved
Old Jan 22, 2013, 09:24 AM
jkoosh27 is offline
Find More Posts by jkoosh27
cut cut cut... ****!
jkoosh27's Avatar
United States, PA, Birdsboro
Joined Dec 2012
Well those two look to be in great shape and I must say Balr14 your knowledge from this and the monster thread seemed to be endless....
If you caught me 2 years later after college I might have been buying those haha
And I think the tail wag has more to do with the tail motor than the gyro, I have both the DD mod and a new pcb on its way so when they come in I will be hopping in on testing them out, I think(90% sure) my tail is going bad.
Pa I don't think I'm anywhere near that good at flying yet to keep the flybar weightless, I was only managing to keep the bird in the air for about 10 seconds before it tore away in a direction I didn't give input for...
John
jkoosh27 is offline Find More Posts by jkoosh27
Old Jan 22, 2013, 09:44 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Content Deleted.
Old Jan 22, 2013, 10:20 AM
hawkfiend37 is offline
Find More Posts by hawkfiend37
Joined Nov 2012
hey steve and mike, can those upgraded batts you guys provided links for on page 54 be charged with the stock charger ? if not what would be a good charger to buy ?
hawkfiend37 is offline Find More Posts by hawkfiend37
Old Jan 22, 2013, 10:25 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Stock 9116 Battery Charger on LiPo's
Content Deleted.
Old Jan 22, 2013, 11:12 AM
Pa flyer is offline
Find More Posts by Pa flyer
Joined Aug 2012
[QUOTE=
John[/QUOTE]
I sure hope that you're right about the tail motor. I have some doubts though because both my main and tail motors are new. The pcb was replaced just a few weeks ago.
I have the dd tail ordered also. (Actually two of them because I screwed up the order.)
I just put the stock flybar weights back on to see if they made any difference in the tail twitching: they didn't. I messed up my 11 gr weights taking them off and made new ones that weigh 9.5 grs. It still hovers with them but is even more sensitive to cyclic now.
I trimmed the blades to 18mm, but it will still lift off at less that 50% throttle so I'm going to trim them some more.
Pa flyer is offline Find More Posts by Pa flyer
Old Jan 22, 2013, 11:24 AM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
As Steve said - let it charge in cool environment and drill holes in the case of the stock charger.
For a decent charger I can recommend only an Accucell6 - it is really well made, has accurate voltage readings and even a cooling fan built in - a feature none other of the clones offers.
OK, there are some REAL good chargers, too. but for 200 bucks +....
-mike-
mikefromgermany is offline Find More Posts by mikefromgermany
Old Jan 22, 2013, 12:00 PM
jkoosh27 is offline
jkoosh27's Avatar
Joined Dec 2012
Hey to those who turned the PCB around so the gyro is closer to the main shaft, did you guys move it closer to the main shaft or to the motor shaft? Right now i moved it so the gyro is a tad behind the motor shaft and in between the main and motor shafts.
I turned the pcb around and spooled up only to find it spinning in circles.... now I'm really thinking the tail motor is going bad, if not already past flyable condition.
But other than just moving the board was there anything else you guys did like on the transmitter to reverse anything?
John
Old Jan 22, 2013, 12:14 PM
resago is offline
Find More Posts by resago
Joined Dec 2012
John
if you turn it around but don't get the gyro past the main shaft toward the rear, the gyro signals will be backward causing the spinning.
resago is offline Find More Posts by resago
Old Jan 22, 2013, 12:25 PM
Pa flyer is offline
Joined Aug 2012
John
The gyro on mine is exactly 1/2" IN FRONT of the main shaft (not the motor shaft). Didn't have to change anything on the tx and it flies fine.
Old Jan 22, 2013, 01:14 PM
jkoosh27 is offline
jkoosh27's Avatar
Joined Dec 2012
Yeah i moved the pcb back to have it behind the main shaft, and it just barely made it but was still spinning in circles.....
jury is out tail motor is definitely shot so now I am just waiting for the DD mod to get here.....Should have ordered it earlier...
Old Jan 22, 2013, 06:13 PM
Pa flyer is offline
Joined Aug 2012
Something to try
Try going into the sub-trim menu. See whether the rudder setting is nor or rev and try the opposite of what it's set at. If changing that doesn't help then it is almost certainly the tail-motor.
Old Jan 22, 2013, 08:10 PM
aphex4000 is offline
Find More Posts by aphex4000
Joined Nov 2012
Whoo, the new chassis finally came in! This little bird is definitely more responsive with the slight CG change.
I reversed the PCB in the design without giving gyro orientation any thought, but these posts about having to move the reversed gyro behind the axis of rotation make sense. The strange thing is, I don't have any spinning issue with the new layout. I don't get it...
aphex4000 is offline Find More Posts by aphex4000
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
