Old Jan 21, 2013, 03:36 AM
Laidback_racer is offline
Find More Posts by Laidback_racer
Build the Weapon....
Australia, VIC, Berwick
Joined Jan 2013
Originally Posted by Steve_ View Post
[ EDIT ] Won't work. MCX2 shaft is 6mm. I guess you could use a sleeve.
I wonder what the shaft size is?
This is for a Blade MSR / MCX2.
The 9116 shaft is 4mm.
http://www.ebay.com/itm/Microheli-Co...item2a27aaed52
Looks a little expensive and heavy?
I have a feeling the std V912 swash will do the trick (has bushing) or another alternative is the ZR Z101 top with 9116 bottom. I had to file off the small retaining lip on the 9116 bottom then use CA to fix. Received my turnigy servo's today, now just waiting on the V912 PCB and I can test the new ZR Z101 head.
Laidback_racer is offline Find More Posts by Laidback_racer
Old Jan 21, 2013, 08:55 AM
Steve_ is offline
Find More Posts by Steve_
More Flights = Less Crashing
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Information removed.
Steve_ is offline Find More Posts by Steve_
Old Jan 21, 2013, 08:56 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
9116 Balance Bar Weights
Old Jan 21, 2013, 09:23 AM
Pa flyer is offline
Find More Posts by Pa flyer
Joined Aug 2012
You were right on
[QUOTE=Steve_
Mounted vertically, the balance center of the battery will be lower than
on my bird, so it won't match the aileron improvements I get.
But since it will be closer to the shaft, vertical mounting should have better
elevator response, which is much more useful
)[/QUOTE]
You were right about the elevator response being improved. I think aileron is just slightly better. The response is so quick: you can just flip the heli around like it weighs nothing. In another post I stated, for a lack of a better description, that it flies lighter. It's really unbelievable how much of a difference mounting the battery vertically made in the "feel" of the helicopter.
One negative thing that I noticed was when a sudden good gust of wind hit the heli it wasn't anywhere near as stable as it was when the battery was mounted lower: certainly not uncontrollable, just less stable. You have to keep in mind though that I'm only running 11 grain (not gram) flybar weights, which is less than 1/5 of the stock weight, with a resultant loss of gyroscopic stability. Much, much more challenging and fun to fly!
Steve, while I was typing this post up you entered post #918! I think we're on the same brain wave-length today!
Pa flyer is offline Find More Posts by Pa flyer
Old Jan 21, 2013, 09:41 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Jan 21, 2013, 09:44 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Jan 21, 2013, 10:19 AM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Balr14 is offline Find More Posts by Balr14
Old Jan 21, 2013, 11:07 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Jan 21, 2013, 11:27 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Jan 21, 2013, 11:54 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Jan 21, 2013, 11:59 AM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
My buddy finally showed up with his MJX-F45....
It's huge. Getting ready to trim it out.
He has not flown it yet.
But DO NOT TAKE ANY TOOLS WITH YOU!
Let it fly like it is - no removing weight, no changing swashplate, skids or similar to improve it
-mike-
mikefromgermany is offline Find More Posts by mikefromgermany
Old Jan 21, 2013, 12:33 PM
Pa flyer is offline
Joined Aug 2012
This is almost scary!
Pa Flyer, 11 grain is 0.71 grams, so yours are even smaller than
mine (1.1 grams).
But since I shortened my balance bar by removing the threaded ends,
our balance bars probably have similar response.
You and I really are on the same brain wave-length today! A little earlier today I calculated your flybar weights at 16.97 grains. I was also thinking that both helis probably fly very similarly. Someone once said something about great minds thinking alike!
Something else I wanted to mention. When I originally modded my 9116 I had moved the battery 3/4" more forward than stock. This made it nose heavy and it handled the wind very well, but I lost a lot of response to rear cyclic.
I just adjusted my swashplate so the heli has a forward movement bias and this also helps somewhat in the wind without really sacrificing anything.
I noticed my tail twitching. It isn't affecting the heading at all and holds well. I just wonder if it has something to do with the gyro placement? Both motors are new.
Old Jan 21, 2013, 12:46 PM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Old Jan 21, 2013, 01:51 PM
jkoosh27 is offline
Find More Posts by jkoosh27
cut cut cut... ****!
jkoosh27's Avatar
United States, PA, Birdsboro
Joined Dec 2012
Hey Pa I'm not so sure that the tail twitch is the placement of the gyro, as I am noticing the same thing on my bird, which hasn't had the board moved (planned project for tomorrow). Could it be the cold weather affecting it??
And yeah I must agree, I find the unweighted flybar a bit much to fly, granted I went from stock flybar to unweighted, as the weights came off yesterday in prep for the project day tomorrow, or when the DD tail stuff gets in...
jkoosh27 is offline Find More Posts by jkoosh27
Old Jan 21, 2013, 03:39 PM
resago is offline
Find More Posts by resago
Joined Dec 2012
Are the 9053 blades any stiffer or have less pitch? They look to be the same length.
resago is offline Find More Posts by resago
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
