Old Jan 20, 2013, 05:29 AM
Born again flyer.
Laidback_racer's Avatar
Australia, VIC, Berwick
Joined Jan 2013
Originally Posted by camano27 View Post
Not sure how to accomplish that mod. Pry off plastic female connector from pcb??
I just melted the top section with the soldering iron to expose the two prongs.
Laidback_racer is offline Find More Posts by Laidback_racer
Old Jan 20, 2013, 06:23 AM
Joined Aug 2012
Yep
Originally Posted by Laidback_racer View Post
Do I see a modded swashplate?
Yes it's modified. I had a vendor send me the wrong swashplate for the 9116 and rather than pay the postage to send it back I just kept it. I'm not sure,but I think it may be for a 9104.
I took it apart and used the top section with the bronze bushing with the lower from a 9116 swashplate. The bushing has much less slop on the hollow pipe than the stock plastic upper. I don't know how much it actually helped, but I had it and had nothing to lose by using it.
Pa flyer is offline Find More Posts by Pa flyer
Old Jan 20, 2013, 06:58 AM
Joined Aug 2012
Be careful!
Originally Posted by Steve_ View Post
I got it down to 191 grams with battery (not including canopy).
If you lighten that thing much more it's liable to float away like a helium filled balloon! Better strap it down at night!
It's kind of hard to tell from your pictures: looks like you maybe drilled out the bottom plate?
Old Jan 20, 2013, 08:48 AM
Sipple31's Avatar
United States, WI, River Falls
Joined Jan 2013
Originally Posted by Rajah235 View Post
Sipple31 wrote,
That's the only way.
Try squeezing it back together a tad before replacing the bar.
Okay, thanks Rajah.
Sipple31 is offline Find More Posts by Sipple31
Old Jan 20, 2013, 09:16 AM
Ain't crashing often anymore
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
Originally Posted by Sipple31 View Post
What is the best way to remove the flybar? I don't like that it doesn't have a screw. I pried it apart and now the plastic seems to have some negative memory effects.
Best method working for me:
Get a hairdryer.
Heat the head up (but keep it safe away from melting point - so do NOT use a heat gun)
Pry it apart with your fingers - take balance bar out.
under regular circumstances the plastic is still hot enough to set itself back - if it does not - reheat and gently bend it back.
-mike-
mikefromgermany is offline Find More Posts by mikefromgermany
Old Jan 20, 2013, 09:48 AM
Member of S.S.O.T.B.B.
Rajah235's Avatar
Australia, NSW, Wollongong
Joined Dec 2012
Of course....it all depends on your ambient temperature, doesn't it?
Currently, it's still around 25 degs C & just a little hotter during the day, so I don't need any kind of heater.
Was 45 ℃ on Thursday.
Back on topic.
I changed my PCB to test a minor glitch I have, trying to control the tail's right drift. (Should say, nose to the left.)
Thought the gyro might have taken a hit but no, with the new board it does the same.
Maybe the tail motor is showing it's age?
Will check.
& I'm chasing a replacement 180 motor that is completely serviceable, but not having much luck.
Rajah235 is offline Find More Posts by Rajah235
Old Jan 20, 2013, 09:54 AM
Germany, Berlin
Joined Jun 2012
I was talking about temperatures around 100 deg C plus - so if that's your ambient temperature - you will need no hairdryer for sure.
-mike-
Old Jan 20, 2013, 10:11 AM
Rajah235's Avatar
Joined Dec 2012
I know Mike.
It's just that with the temp up over 30 ℃, the plastic is reasonably pliable.
It's just a tad scary when you first try to remove the bar by bending the plastic tabs.
Old Jan 20, 2013, 10:21 AM
Joined Dec 2012
Back on topic.
Will check.
Yeah I saw they had to add another color to the heat map for you blokes.
That's crazy hot.
resago is offline Find More Posts by resago
Old Jan 20, 2013, 10:25 AM
Joined Dec 2012
What model was it that had compatible parts for the 9116?
Also, might the coax blade have less lift so I could use as bolt on?
Old Jan 20, 2013, 11:12 AM
Rajah235's Avatar
Joined Dec 2012
I think Steve or Mike mentioned that "some of" the 9100/9104 parts are interchangeable, but not sure about which they were.
It's in this thread or the "old one"....... somewhere.
Tried a search for 9104? or compatible?
Old Jan 20, 2013, 11:50 AM
Germany, Berlin
Joined Jun 2012
No, it was in this thread also:
http://www.rcgroups.com/forums/showp...&postcount=704
All parts of the DH9100 but the swashplate and the PCB are identical to 9116 parts but a lot cheaper.
One 9116 part is actually cheaper than a 9100 part at banggood - the blue canopy (2USD shipped).
In fact I ike the 9100 canopy better, the blades also.
-mike-
Old Jan 20, 2013, 12:55 PM
Joined Jan 2013
Update
So I went ahead and installed a new oem main motor that I had, and the heli showed the same symptoms. With my tx tail rotor trim set at 120% the bird had a non rotating hover, without setting any sub trim in flight. So the oem motor seems to be slightly stronger than the xtreme I installed the day before.
I guess I am going to have to change out the pcb and cross my fingers that I don't have a hassle with binding to the new board. And hope my problem is a tweeked gyro. Because the old gyro does appear to be working when doing the hand test.
Ken
camano27 is offline Find More Posts by camano27
Old Jan 20, 2013, 12:59 PM
cut cut cut... ****!
jkoosh27's Avatar
United States, PA, Birdsboro
Joined Dec 2012
Alright so i trimmed the main blades after they broke thanks to the cold PA weather.
Now I'm looking to remove the flybar weights to trim them down, any suggestions on how to remove them?
Heat?
and I will also be working on the pcb and battery moves, so hopefully soon I will be able to hlp chip in on mod ideas...
John
jkoosh27 is offline Find More Posts by jkoosh27
Old Jan 20, 2013, 02:04 PM
Joined Aug 2012
Heat and twist
Now I'm looking to remove the flybar weights to trim them down, any suggestions on how to remove the.
John
Just heat them to soften the thread locking compound and screw them off while they're warm. Even a cigarette lighter will work. It doesn't take much heat.
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
