Old Jan 18, 2013, 03:53 PM
Member of S.S.O.T.B.B.
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Information removed.
Steve_ is offline Find More Posts by Steve_
Old Jan 18, 2013, 04:30 PM
Joined Dec 2012
Originally Posted by Pa flyer View Post
If the pcb was turned around and mounted on the baseplate completely underneath the motor so that the battery could be mounted vertically in front of the motor do you think there would be any problems with radio reception? In the stock mounting position the antennae is way forward and clear of anything else. I think that would be the ultimate battery position for increased agility.
wouldn't that make the gyro bass ackward?
if you turned it around, the gyro would have to be past the main shaft. (toward the rear)
I know this, because I tried it last night and during my first spin up, the heli went skittering across the floor doing piros.
resago is offline Find More Posts by resago
Old Jan 18, 2013, 04:31 PM
San Mateo, CA
HPCR's Avatar
United States, CA, Foster City
Joined Dec 2012
Originally Posted by Steve_ View Post
I was in the UAW Local 95 for many years, and the only thing the Union ever did
for me was automatically deduct 2 hours pay every month.
I was at the top of the hourly wage scale at our plant, and I didn't get a raise for
the last 5 years I worked there, while everyone else was brought closer to my wage.
Operators that pressed buttons for a living were making $16 / Hr, and I was
repairing PLC's, robots, X-ray machines and vision systems for $21 / Hr.
My job was 1000 times more complex than any production job in the plant,
yet after 10 years of working in a maintenance electrician slot, I only made
a few dollars more than them, because the union agreed to a maximum
hourly wage cap. Production kept getting raises, while my pay stayed the same.
If you are an intelligent talented worker, the Union really does nothing but
take your money, while it fights to save the people that SHOULD be fired,
due to lack of talent, ambition, attendance or any other issue that would
normally get you canned.
Look what you started. Now I'm pissed off.
There you go.. A pissed-of disgruntled Union worker, I like it!. Time for some major re-adjustments in the USA. Suffices to say that I am dead against the stranglehold Unions and thus the Democratic party has.I just hope you did not vote for the cool guy!! He is eating us for breakfast.
HPCR is offline Find More Posts by HPCR
Old Jan 18, 2013, 04:43 PM
Steve_'s Avatar
Joined Nov 2012
Old Jan 18, 2013, 04:46 PM
Joined Dec 2012
as long as the gyro is behind the main shaft, it should be good.
Old Jan 18, 2013, 06:03 PM
Steve_'s Avatar
Joined Nov 2012
Old Jan 18, 2013, 06:38 PM
Joined Dec 2012
if you look at postings under the "no more smashed pcbs" thread,,,I posted pics. of the mods I did.
Out of logical sense, I put the pcb tucked away and had no ill gyro effects or r.f. interference at all,
many,many (a lot) of flights later, I still have the original pcb the old crow came with.
I you look at the batt mount system I made, I just mount the batt higher for more agressive flying, and lower it for more stability ( c.g. shifting)
aside from the tail motor mods I still need to do,I modded it up with scraps of stuff and hand fab. things and have a blast flyin it....-
note:all the wires were resoldered and are facing the front of the bird so the wires are away from the main gear...
simz is offline Find More Posts by simz
Old Jan 18, 2013, 07:18 PM
Born again flyer.
Laidback_racer's Avatar
Australia, VIC, Berwick
Joined Jan 2013
Looks good, I might adopt your design. I like the idea of being able to move cg as well as being able to mount the std nose cone. Interesting that the reversed gyro works good.
Did you reverse the rudder on the tx?
Laidback_racer is offline Find More Posts by Laidback_racer
Old Jan 18, 2013, 07:20 PM
Joined Aug 2012
Went and did it
Well I went and moved the pcb under the motor. The gyro is exactly 1/2" in front of the main shaft. It's a little further back and lower than the position simz has his mounted. The front edge (which was previously the back edge) of the pcb is in line with the front screw of the outer side plate.
I was a little worried that it might be tail heavy, but it's not. It had a heavy drift to the left that it didn't have before the mod, but I trimmed it out at the swashplate and it hovers fine.
Tomorrow I'll try it outside and take some pictures to post. I think probably the concerns over the gyro not working right due to repositioning are unfounded. At least I hope they are!
Pa flyer is offline Find More Posts by Pa flyer
Old Jan 18, 2013, 07:34 PM
Steve_'s Avatar
Joined Nov 2012
Old Jan 18, 2013, 07:48 PM
Steve_'s Avatar
Joined Nov 2012
Old Jan 18, 2013, 08:02 PM
Joined Dec 2012
lalalala
sorry steve I have not posted in awile been to busy flyin and tending to the frostbite on my fingers (they need to come up with heated sticks on the Tx. like having heated seats or steering wheels in cars)
like you said, I have more aggro. on the ailerons with the batt. mounted higher-
with it mounted lower, it has more weight forward and better forward flight and more stable.....it seems to be a trade off as to what kind of flyin your up for..
all mods I have made have no ill effects (i.e. tail wag ect. ect.)
and I still have the orig. main motor and tail motor and pcb. the bird came with still installed((((knock on wood---till my knuckles bleed))))
-I spent more on gas driving to parks to fly at than I spent on the mods I made..
will gladly share the other mods I have done as that this is what this thread is for.
--pooling our collective thoughts together for a better outcome..
Old Jan 18, 2013, 08:34 PM
Steve_'s Avatar
Joined Nov 2012
Old Jan 18, 2013, 08:41 PM
Joined Dec 2012
Got a good flight in. I really need to reduce the weights on the gyro. I could dip the nose and get a good run, but then it was swinging all over the place like it was on a string. I didn't crash, but I came close to some trees several times.
Old Jan 18, 2013, 08:44 PM
Steve_'s Avatar
Joined Nov 2012
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
