Old Jan 17, 2013, 02:37 PM
Steve_ is online now
Find More Posts by Steve_
More Flights = Less Crashing
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
DH9116 Weight reduction to 199 grams.
Information removed.
Steve_ is online now Find More Posts by Steve_
Old Jan 17, 2013, 02:53 PM
resago is offline
Find More Posts by resago
Joined Dec 2012
I wish I knew how much throttle I am giving, my throttle stick is hosed and I had to change the rates to get full throttle by half stick. Makes for an interesting experience. I have a fs9 on the way.
I've been reading the reviews on the 912 and want one now.
wish I had a mailing scale to weigh mine.
there is an area of metal below and toward the front of the tail block that could be drilled out to loose more weight.
resago is offline Find More Posts by resago
Old Jan 17, 2013, 03:03 PM
Steve_'s Avatar
Joined Nov 2012
Old Jan 17, 2013, 03:25 PM
Steve_'s Avatar
Joined Nov 2012
Old Jan 17, 2013, 03:32 PM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
Originally Posted by Steve_ View Post
There is a HUGE difference. When the plastics on a 9116 get cold,
they get very brittle.
45-50 degrees F is about as cold as you want to go without risking damage.
At freezing and below, the parts are a hard as a rock, and even just
barley clipping anything almost always results in a broken part.
I damaged a tail blade last week when it hit a tiny twig on the ground that
was about half the size of a cigarette butt.
As stated in the manual : you should not fly in temps below 40F (4.4c)
-mike-
mikefromgermany is offline Find More Posts by mikefromgermany
Old Jan 17, 2013, 03:43 PM
Steve_'s Avatar
Joined Nov 2012
Old Jan 17, 2013, 03:53 PM
jkoosh27 is offline
Find More Posts by jkoosh27
cut cut cut... ****!
jkoosh27's Avatar
United States, PA, Birdsboro
Joined Dec 2012
-mike-
I'll third that statement....I just got back in from a flight at 41F according to local weather and i managed to actually break a main blade on a fairly small twig (maybe 1/2 diameter) that i could see on the ground 30 yards away. I have also broken 2 inner shaft pieces and dogbones. DO NOT FLY IN COLD WEATHER, PERIOD. Not for lack of previous statements.
Steve I weighed mine out and have gotten to 205 without the canopy, and finally managed to get it trimmed to a hands free hover with all trims on the tx at 0. wow that only took 15 flights haha.
Side question. How have you guys removed the flybar weights to trim the weights down? haven't tried on my own but i didnt care to wait for new ones after i got careless.
John
Edit: I could not see the twig on the ground.....
jkoosh27 is offline Find More Posts by jkoosh27
Old Jan 17, 2013, 04:15 PM
Pa flyer is offline
Find More Posts by Pa flyer
Joined Aug 2012
And it's a tie!!! (Or pretty dang close!)
I just drilled some more holes, and removed the shrink
wrap and stickers from my battery. I finally got below 200 Grams.
199.1 grams, to be exact. This is without a canopy.
My Wasp V3 canopy weighs 13.3 grams, bringing total
flying weight to 212.4 grams.
My stock canopy weighs 15.3 grams, so it would weigh 214.4 grams
without the lighter Wasp V3 canopy (2 grams heavier).
There is plenty of room for improvement. Has anybody managed
to beat 212 grams?
200 gms with battery and no canopy
212 gms with battery and lightened stock canopy
209 gms with battery and home-made lightweight plastic canopy
Pa flyer is offline Find More Posts by Pa flyer
Old Jan 17, 2013, 04:30 PM
Fathead is offline
Find More Posts by Fathead
Joined Jan 2013
I agree its irresponsible to fly in cold temps, but ill risk it, parts are cheap.. I believe my tail motor is now gone. Flew it twice last night, first flight was great, but the second was terrible. Kept spinning counter-clockwise no matter how much trim i gave it. New tail assembly and stock main motor on the way as well as a better battery. Ill be upgrading to the honey bee dd tail soon, and a charger. Does anyone have experience flying with a dd tail? How well does it perform?
Thanks for all the great info!
Fathead is offline Find More Posts by Fathead
Old Jan 17, 2013, 04:36 PM
Fathead is offline
Joined Jan 2013
Btw, is anyone familiar with radioshack xmods? I have a spare stock motor somewhere. Xmods run on 4aaa's and the stock motor has a max rpm rating of 25000. Idk what the voltage or amp ratings are but its a pretty powerful motor, and i think is about the same physical size.
Old Jan 17, 2013, 04:44 PM
Steve_'s Avatar
Joined Nov 2012
Old Jan 17, 2013, 04:50 PM
Steve_'s Avatar
Joined Nov 2012
Old Jan 17, 2013, 05:22 PM
Fathead is offline
Joined Jan 2013
Here is the link to the DD tail mod:
http://www.rcgroups.com/forums/showthread.php?t=1806445
This is pulled from my post in that thread:
Some other reasons to use this tail drive:
1) Lower rotating mass, allowing for quicker response and easier flying.
2) The direct drive allows lower motor RPM, giving longer bushing and brush life.
3) No gears to break or incorrectly mesh, and elimination of gear whine.
4) Elimination of the cheap plastic tail shaft bushings.
5) More efficient due to lower friction (no gear mesh or shaft bushings)
It costs roughly the same, but lasts over twice as long.
Mike said he has over 80 flights on his, with no loss of power.
I have had stock tail units noticeably start to lose power after 15-20 flights.
I've never squeezed more than 50 flights out of a stock tail.
Usually by 30 flights, the tail is no longer strong enough to keep up with
the main motor at 100% throttle, especially if your 9116 is modded.
If you fly as aggressively as I do, this causes big problems, because it will
spin out at the worst possible time, sometimes making me lose orientation.
Thanks, ill deffinately be doing this mod soon. Iv already had about a dozen flights so far so i think thats an alright amount of life from an overworked tiny motor. Just wish they would have spent the extra few bucks for higher quality motors and battery, id be willing to spend a whole $100 on one if the quality was there. But for $78 im satisfied. Hopefully i dont have to put more than another $100 into it for it to fly well. The modded heli's iv seen pics of are really nice, good work guys!
Old Jan 17, 2013, 05:40 PM
Steve_'s Avatar
Joined Nov 2012
Old Jan 17, 2013, 05:54 PM
HPCR is online now
Find More Posts by HPCR
San Mateo, CA
HPCR's Avatar
United States, CA, San Mateo
Joined Dec 2012
Usually by 25 flights, the stock tail motor is no longer strong enough to keep up with
The Syma S031 tail motor lasted about 40 flights before the tail would no
longer hold. It has slightly more power than a stock motor and holds the tail
like a rock, but does not seem to last any longer than the stock motor overall.
It does give you more power for more flights, but in the end, the brushes
end up giving out completely at 50 flights, same as a stock motor.
Once I get my DD tail parts, I'm pretty sure the tail will hold no matter how
hard I push it. It's a bigger motor from a bigger helicopter, and a 9116 won't even
begin to use all of the power it is capable of. Mike said it doesn't even need
a heatsink.
Since the output transistors for the main and tail motor are the same size,
the PCB should handle the larger tail motor with ease.
There is no doubt that the mfg could build these components with some more longevity in mind and frankly that would cost very little. The issue really is always around "how far can you go modding this thing" and "where do you stop" because there will always be one component that is the most likely to fail. I do think modding is a nice disease or illness to have and we all are learning more about what spares to stock, where to look for the parts so we can get our grubby little hands on these toys, and what to expect. Currently I have 2 of my DH9116's on the bench waiting for the rotor head/ inner shaft 9116-06 part number. Perhaps they also got a case of the cold because the pin that lock the blades into position just sheared off on both of them with a really mild bump on landing which tipped the helis over on a side - both with power cut -.
HPCR is online now Find More Posts by HPCR
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
