Old Nov 26, 2012, 04:28 PM
Whizgig is offline
Find More Posts by Whizgig
Eugene
Whizgig's Avatar
Australia, VIC, Delacombe
Joined Oct 2006
Good work Steve,
Me and mick discused this motor but we never got around to trying it as people were more interested to go for the 180 Pro setup with a matching tail motor, But I found the 180 Pro to be 1 expensive and drew to much power from the PCB that the tail motor and servo's ect would loose power and be nill effective.
Also you had to bypass the mops as it would continualy cut the power to the motor.
Whizgig is offline Find More Posts by Whizgig
Old Nov 26, 2012, 07:13 PM
Steve_ is offline
Find More Posts by Steve_
Venting Nowlege
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Deleted
Steve_ is offline Find More Posts by Steve_
Old Nov 27, 2012, 12:37 AM
Whizgig is offline
Eugene
Whizgig's Avatar
Joined Oct 2006
Originally Posted by Steve_ View Post
The S031 tail motor will probably burn out at close to the same rate as stock,
but $3.39 every month beats $5.00 every month, and you get more thrust
with roughly the same current draw. Cheaper AND more powerful. Hard to beat.
Plus, it's less likely to mess up the PCB. Those tail motor plugs are not very rugged, and are designed
only for occasional disconnects. I know they are not rated to handle the current that goes through them.
The less you mess with them, the better.
These may even be the solution for the Extreme 180 main motor users complaining about tail authority.
Someone try it, and post your adventure
I have ordered a few of them and I have a few new Xtream 180 pro motors so I will let you know how it goes, I have also ordered a couple of the main motors as well as they are rated the same as the 9116 stock 180's and will test them.
Old Nov 27, 2012, 02:25 AM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Deleted
Old Nov 27, 2012, 08:14 AM
Pa flyer is offline
Find More Posts by Pa flyer
Joined Aug 2012
A little info
I've found that the tension on the screws that hold the little levers on the blade grips is critical. A little too much tension and a hovering helicopter will seem to have a mind of it's own, especially if it's been lightened. It will affect a stock helicopter to a lesser degree, requiring constant stick input as it tries to move first in this direction, then that direction,etc. If you remove a screw and look at the area right under the head you will find that it's beveled and tightening it too much spreads the end of the post that it screws into, increasing turning resistance. I lubricate it very sparingly with Tri-flow and with the connect buckles detached slowly tighten the screws until I feel light resistance to rotation, then back off the screws slightly. Of course you don't want them too loose either as that would just make it's already inherent sloppy control worse.
Pa flyer is offline Find More Posts by Pa flyer
Old Nov 27, 2012, 03:32 PM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Deleted
Old Nov 27, 2012, 03:49 PM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Deleted
Old Nov 27, 2012, 08:49 PM
NeilGerrard is offline
Find More Posts by NeilGerrard
NeilGerrard's Avatar
United States, UT, Draper
Joined Sep 2012
Hi everyone,
Sorry to hear about Mick, He was the same age as me when I had my MI. He, Mike and the rest of you even Blair14 have help create a spark in me that in just these past few months I've gone from a Drift King, Syma S107g, two DH 9116's, two V911's and I'm in the middle of building my first 450. It all started here on this thread.
Thank you all.
P.S. Remember eat right and flight hard.
NeilGerrard is offline Find More Posts by NeilGerrard
Old Nov 28, 2012, 12:54 PM
Drudail is offline
Find More Posts by Drudail
New Aviator
United States, GA, Columbus
Joined Nov 2012
Unintended Mod
So I got my new DH 9116 yesterday. So excited that I couldn't wait for the rain to stop outside, I decided to try flying it in my kitchen. One of my kids ran directly in the flight path so I had to maneuver away to avoid getting yelled at by my wife for hitting them with the blades. Long story short, I had a BAD crash. I broke off the pegs on the inner shaft that hold the fan clips in place (is it just me or does a boken inner shaft sound more like a severe medical problem than just deadlining a helicopter?)
I decided that since I would have to wait for a new part to be delivered anyway I would try to repair it. Simple solution if anyone has a similar problem:
Drill a 1/16 inch hole through the inner shaft where the plastic pegs protrude. Take a 1/16 inch nail and grind it into two pieces small enough that they will meet against the main shaft and protrude to fit in the holes in the fan clips. bolt it back together and you're in business...at least I am. The benefit, other than not having to wait for a new part, is that I reinforced the original plastic (obviously rather fragile, since it sheared the ends off) with metal, and I can repair it as often as necessary now.
I took it out for a short test flight (outside this time, I learned my lesson) and it flies better than it did out of the box.
Incidentally, this is my first 4ch heli. Before I have flown an Airhogs 2ch and two 3.5ch. The rudder being on the left stick rather than the right has me all thrown off. Anyone have any recommendations for training programs to get me used to the new configuration?
Drudail is offline Find More Posts by Drudail
Old Nov 28, 2012, 05:35 PM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
Welcome Drudail!
You'll find some useful info in stormforce's tech manual here
Highly recommended to follow it before first use
If you encounter problems - have a look here first.
Theres no easy way getting used to the new stick settings coming from 3channel helis. Just take it easy and start ev. with rudds flight school.
have fun!
-mike-
mikefromgermany is offline Find More Posts by mikefromgermany
Old Nov 28, 2012, 11:54 PM
jonnewbie is offline
Find More Posts by jonnewbie
Joined Nov 2012
Hi all
I am sure someone has commented in the past about trimming but there are sooooo many pages to look through.
My question is my heli flys well but has a tendency for the tail to continually turn to the right. I have put the trim far over to the left almost at its full settings but it still slowly will turn right.
Any ideas or tips?
jonnewbie is offline Find More Posts by jonnewbie
Old Nov 29, 2012, 12:06 AM
Whizgig is offline
Eugene
Whizgig's Avatar
Joined Oct 2006
Originally Posted by NeilGerrard View Post
Hi everyone,
Thank you all.
Hi Neil,
How are ya haven't heard from you for a long time what have you been up to in the heli world.
Old Nov 29, 2012, 03:49 AM
Germany, Berlin
Joined Jun 2012
Originally Posted by jonnewbie View Post
Hi all
Any ideas or tips?
Have you done the trimming in the subtrim menu yet?
In general this behaviour means the tail motor is dying - get a replacement ready
-mike-
Old Nov 29, 2012, 05:25 AM
Joined Nov 2012
-mike-
Thanks mike,
Yup got a motor already on order
Will go into the subtrim menu and see how I go in the interim.
Is it still safe to fly like this?.....I have no prob controlling it atm but its not going to seize up mid flight is it?
Cheers
Old Nov 29, 2012, 05:55 AM
Pa flyer is offline
Joined Aug 2012
Typo?
Hi all
Any ideas or tips?
The trim controls the attitude of the nose, so if the tail is moving to the right you would want to move the trim to the right, not the left, to compensate. If it was just a typo and this is what you meant to ask, then it is almost certainly the tail motor dying. When I used to fly the heavy stock 9116 very aggressively I usually went through taill-motors inside of two weeks and sometimes within three days. On the other hand, my brother-in-law has been flying passively in slow mode for about three months now on the same tail-motor with no problem.
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
