Old Nov 24, 2012, 12:43 AM
Steve_ is online now
Find More Posts by Steve_
Venting Nowlege
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
9116 and 9117 Radio Suprise
Content Removed due to the fact that I do not agree with forum policy
here, and do not want them generating profit with my content.
Steve_ is online now Find More Posts by Steve_
Old Nov 24, 2012, 10:13 AM
freezywilly is offline
Find More Posts by freezywilly
Joined Jan 2012
OT Post.
Bear with me for while I try to link some facts.
This info will affect you when you move on to other Heli's or quads.
Steve your info rang a bell. I have the 9x family of xmtrs along with
other turnigy xmtrs that just came on the market.
I, like others, have been flying the 9116 the V911 and other quads all with the same transmitter.
A Turnigy FS-T6. Now what I am leading up to is that there is a big change comming to the Heli and transmitter market. These transmitters of the Turnigy family, it seems, will no longer support the new Heli's and quads that are comming. The discussion on other threads seem to say there is a lot going on and not being told to the user.
So what I am leading up to is this: when you decide to move on be ready to not only buy a heli but a new xmtr. As parts for the older Helis go away so will their support.
This is what I have gotten out of many discussions. I welcome your comments. This is only going to grow.
freezywilly is offline Find More Posts by freezywilly
Old Nov 24, 2012, 01:34 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Balr14 is offline Find More Posts by Balr14
Old Nov 24, 2012, 02:12 PM
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
9116 Tail Mototr Upgrade
Old Nov 24, 2012, 02:18 PM
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Deleted
Old Nov 24, 2012, 02:48 PM
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Deleted
Old Nov 25, 2012, 02:14 AM
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Deleted
Old Nov 25, 2012, 03:28 AM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
Steve, I think you have some electronic knowledge - I would need some help:
I would like to hook some other LEDs to a heli (4V voltage)- but they have to be controlled by the signal of another LED (status SMD LED of PCB) - like in pic 1b. I thought of simply connecting Ue to the anode of the status-LED and Ub to anode of battery and earth to negative.
would that work?
-mike-
mikefromgermany is offline Find More Posts by mikefromgermany
Old Nov 25, 2012, 04:55 AM
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
9116 Tail Motor Upgrade Recorded Sound
Deleted
Old Nov 25, 2012, 05:13 AM
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Deleted
Old Nov 25, 2012, 06:15 AM
Germany, Berlin
Joined Jun 2012
Originally Posted by Steve_ View Post
Don't try to drive a bunch of LED's directly from the output of one, use a transistor to
switch them so it draws minimal current (a few mA) from the source.
That's exactly what I intend to do - just look at the diagram I attached to the previous post - Fig. 1b
It looks like you could adopt the drive circuit from this 40 LED bicycle light schematic
for your purpose (the 4th project listed).
http://www.qsl.net/yo5ofh/hobby%20ci...d_circuits.htm
Too big, too heavy - it's for a sub micro quad - the X4 - so weight counts more than usual.
Just curious, but why not just feed the LED's directly from battery voltage, and
regulate it down, or use resistors to current limit?
The LED on the PCB stays lit once it's running anyways. And there would be no risk of throwing the radio circuitry out of spec.
I do want to drive them direct from batt - using the right resistors.
The X4 has two blue status LEDs - mounted as eyes - that not only stay lit while bound but also start to blink alternating when voltage drops down for example and can signal some other circumstances. These eyes are too small and weak to recognise them flying more than 5m away or not facing to you.
I'd like to connect this signal to my navlights, which draw 160mA together, so a direct hookup to these tiny status SMDs is really too much.
-mike-
Old Nov 25, 2012, 07:29 AM
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
9116 Tail Heat Sink for Poor Folk
*This mod sucks, it won't stay on...
Old Nov 25, 2012, 07:57 AM
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Deleted
Old Nov 25, 2012, 08:03 PM
RCMad39 is offline
Find More Posts by RCMad39
RCMad39's Avatar
Australia, NSW, Armidale
Joined May 2012
Looks good mate, way better than the ugly stock canopy. And I love how light they are.
Nice work
As far as the flybar goes, I want to grind down the top and bottom so it is thinner.
Chopping off the ends sometimes involves extra work if you hit the bar itself.
I read of one guy having to solder the remaining weights in place.
Never thought of using balance paddles. Make sure you share your success or failure,
so if it does not work, it might save somebody some time and money.
Thanks for the post!
EDIT:
I just realized your canopy is up tight against the rotor. The motor won't get much cooling like that,
and it already runs hot enough. I made some mounting holes farther back on the canopy so it sits
farther forward. Not trying to criticize, I just don't want you to burn up your bird.
Steve
Hi Steve just had a second look at your pic of the canopy and know see what you mean about moving the holes back along the canopy for good ventalation , thanks for the insight it will save wear an tear on the motor . so it sounds like the syma tail motor might be a good upgrade , is it a straight plug in or does it need to be resoldered to the motor ??? will be seriously considering this upgrade while at work tonite
RCMad39 is offline Find More Posts by RCMad39
Old Nov 26, 2012, 04:17 PM
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Deleted
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
