Old Jan 10, 2013, 06:43 PM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
Direct Drive Tail Mod
I proudly announce another Mini-How-To:
The Direct Drive Tail Mod
And yes, it SOLVES these 9116 tail problems - authority and durability at the same price of a stock tail.
Have fun!
-mike-
mikefromgermany is offline Find More Posts by mikefromgermany
Old Jan 10, 2013, 09:31 PM
Sipple31 is offline
Find More Posts by Sipple31
Sipple31's Avatar
United States, WI, River Falls
Joined Jan 2013
Alright guys I got one for ya... I have the chopper hovering well. I'm getting the hang of it. But, for some reason my aileron movements to the left are much more pronounced than to the right. If I'm hovering and try to float the heli right it moves ever so slowly. If I do it to the left, it darts as I'd expect it to. Do I have a servo issue? Maybe the left servo arm is hitting the canopy when it tries to push upward...
Sipple31 is offline Find More Posts by Sipple31
Old Jan 10, 2013, 09:42 PM
Pa flyer is offline
Find More Posts by Pa flyer
Joined Aug 2012
Check your tx
Make sure the epa settings for aileron aren't messed up in your tx. Hold the stick to the left and set it, then hold the stick to the right and set it. You have a range of up to 120% each way.
Pa flyer is offline Find More Posts by Pa flyer
Old Jan 10, 2013, 11:38 PM
Laidback_racer is offline
Find More Posts by Laidback_racer
Build the Weapon....
Australia, VIC, Berwick
Joined Jan 2013
Thanks Steve_ and Pa, I probably have a defective swashplate.
I have looked at the ZR Z101 (9116 clone) vids on youtube and the heli looks totally more stable than my 9116. I may have had a broken lug on the main shaft (both broken now) that would explain my probs, but I am unsure. I noticed the head parts of the ZR z101 are subtly different (swashplate very different) so I have ordered a full head. I will post back the results.
The swashplate is more like the V911, so I will have to jerry rig the offset vertical placeholder
Laidback_racer is offline Find More Posts by Laidback_racer
Old Jan 11, 2013, 12:45 AM
simz is offline
Find More Posts by simz
enter a new realm.....
simz's Avatar
Joined Dec 2012
slipper clutch??
I was at my local hobby store ( he only deals with e-flight and blade stuff) and a rotor blade for a blade SR caught my eye so I bought it ($1.89).....
I had an old broken 9116 blade (yes I keep all the parts even if there broke)
and with a razor and a #2 1/2 long wood srew and some washers, came up with this settup.....
I set it up on the bench and gave it full rudder and with a glove on my hand, I grabbed the rotor (dont try this at home)
motor and gears were turning but the blade was slippin,,when I let go ---it went back to normal,,
will try it this weekend at the park and from a hover ,hit back cyclic untill the tail sticks in the ground
the way I figure if it slips with no breakage--great--if the blade snaps,,,well its cheaper than a new tail unit...cant wait to fly it in the slop..
BTW I make my own tail booms so if that bends its not so bad..
simz is offline Find More Posts by simz
Old Jan 11, 2013, 05:26 AM
Rajah235 is offline
Find More Posts by Rajah235
Just a 9116 flyer.
Rajah235's Avatar
Australia, NSW, Wollongong
Joined Dec 2012
slipper clutch??
I like.
What a great idea. Thanks.
Only thing I would worry about is the extra current drawn by the tail motor.
Might not be all that much though. Just thinking "electrically".
L..
ps. You might like to try a felt washer in there as well.
Rajah235 is offline Find More Posts by Rajah235
Old Jan 11, 2013, 08:04 AM
Pa flyer is offline
Joined Aug 2012
It never ends, does it?
Have fun!
-mike-
Back on 11/23/12 I posted all the mods that I made on my 9116. At the time I thought that there really wasn't anything else that I could change on it to improve it's performance. Yeah, right.
Since then I've trimmed the blades, put heavier wire on the main motor, raised the battery, (thanks Steve), changed out the servos, put ball links on the servo arms, lightened the flybar weights more and put a hybrid 9116/9104 swashplate on it.
Now I'm going to have to do the direct drive tail motor conversion eventually. Eventually because I have 9 spare stock tail motors to use up first. (Thanks, mikefromgermany).
So then I'll be all finished with it, right? RIGHT???
Old Jan 11, 2013, 08:23 AM
Rajah235 is offline
Just a 9116 flyer.
Rajah235's Avatar
Joined Dec 2012
Right, but you're having a lot of fun doing it, aren't you?
& that's part of this hobby.
Old Jan 11, 2013, 08:44 AM
Steve_ is offline
Find More Posts by Steve_
More Flights = Less Crashing
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Information removed.
Steve_ is offline Find More Posts by Steve_
Old Jan 11, 2013, 09:38 AM
Pa flyer is offline
Joined Aug 2012
Yes, it is fun
You're right. I have to admit that it's almost as much working on them and testing out the mods as it is flying them.(Almost!) What's really great about this bird is that there is plenty of room for improvement over stock and the parts are dirt cheap so it's no big deal if you ruin anything along the way.
I just read on another site and watched the Utube video of a great idea. The guy painted just the top of his main rotor florescent orange to help with determining which way it's banking when he loses orientation way out there.
I'm off to the store now for a can of spray paint for my next "last" improvement!
Old Jan 11, 2013, 09:43 AM
Germany, Berlin
Joined Jun 2012
Or do something like me - taking some luminescend paint and add some REAL dangerous UV-LEDs
http://www.rcgroups.com/forums/showthread.php?t=1733392
(There are some tests on my workbench with enlighted props and blades in such manner)
Should look like this when finished
SUPER MQX V929 QUADCOPTER HELICES LUMINEUSES NIGHT BLADE LIGHT LED (filmé du bas) (1 min 21 sec)
-mike-
Old Jan 11, 2013, 10:49 AM
simz is offline
simz's Avatar
Joined Dec 2012
R&d
well Im into the whole research and development thing--that slipper clutch was $ 1.89 for the blade and 3 cents worth of washers compared to $10 - $15 for a replacement tail section --$10 for the part and about $5 S/H,,,,I HATE waiting for stuff in the mail...
more so, I hate driving to the field to fly my planes and break a 2 cent part when I could have engineered something at the shop to prevent the downtime in the first place....
Im all about modding things up --but for near $0 cost..
I could make a gear drive or even a belt drive for this bird----but why??
it defeats the whole purpose--I want to fly and not be benched for it..while still having a fat wallet,,,Im just shareing low cost alternatives and ideas,,kinda the purpose of this thread......well back to the shop...keep the ideas flowing..
Old Jan 11, 2013, 11:08 AM
Rajah235 is offline
Just a 9116 flyer.
Rajah235's Avatar
Joined Dec 2012
simz,
Just in case you missed it...
[q]ps. You might like to try a felt washer in there as well.[/q]
It may save a little wear 'n tear on those expensive parts.
& We don't want that now, do we?
L..
ps. Have you run a check on how much current is drawn under the stall condition yet?
Old Jan 11, 2013, 03:12 PM
simz is offline
simz's Avatar
Joined Dec 2012
slipper clutch
expensive parts....HA....no I didnt do a amp draw reading as the slipper only engages it crash situation -btw I did see your post on using felt but like I said only severe trauma makes it engage in in effort it save motor, gears and maybe the PCB. so you can keep on flyin without having to go home to fix it or have a field service situation where parts are sure to be lost in the grass
Old Jan 11, 2013, 04:40 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 04:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 08:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 11:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 02:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 10:22 AM
