Old Mar 10, 2013, 12:19 AM
Steve_ is online now
Find More Posts by Steve_
More Flights = Less Crashing
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
B6 Temp Probe for NiMh Packs
Content Removed due to the fact that I do not agree with forum policy
here, and do not want them generating profit with my content.
Steve_ is online now Find More Posts by Steve_
Old Mar 10, 2013, 12:24 AM
simz is offline
Find More Posts by simz
enter a new realm.....
simz's Avatar
Joined Dec 2012
head trip
Originally Posted by Steve_ View Post
That is a great idea, that never crossed my mind. I love this forum
Does it usually shear and protect the rest of the head?
This mod has the potential to save big bucks over time.
Yeah, I don't understand the naming at all, as far as how the shafts are named.
It's as funny as the broken English in the manuals.
I used a 3/32 drill bit to make the hole,,the pins are .725-.730 in length
abs plastic rod ($1.75 lhs) more flexable
fiber optic grade rod ($1.30 ish at lhs) very stiff
------both will sheer clean if impact is heavy (just like the stk setup does)
you can make dozens of pins with 2 rods,,,
the other pic. is somthing I do to shim the head gap around the pin area
--drill a 7/64 hole in the poly. and than punch it out(coloring it makes it easier to see) than slip them over the pins before reassembling (if you feel you need to shim)
this settup works great at least in my experiences with non movable objects
simz is offline Find More Posts by simz
Old Mar 10, 2013, 12:44 AM
Steve_'s Avatar
Joined Nov 2012
Old Mar 10, 2013, 01:25 AM
aphex4000 is offline
Find More Posts by aphex4000
Joined Nov 2012
Lots of you have a little 3 pin port on your chargers.
It's for a temperature probe, used when charging your NiMh
cells in your transmitters and other devices.
I found the "chip" on eBay for under $0.95 per unit, with 300+ sold
and 99.9% feedback.
http://www.ebay.com/itm/2-x-LM35-LM3...item20c11cc8df
_________________________________________________
Here is the thread about it, the photo is copied from it, courtesy of
Bruce Abbott.
http://www.rcgroups.com/forums/showthread.php?t=778508
This is a picture of a retail temperature sensor, with the heat-shrink
tubing removed, revealing the LM35.
Originally Posted by Gusanoloco:
The thermal probe for Duratrax ICE, G.Planes Triton, and Supernovas,
Robitronics and clones is based on the LM35 integrated circuit...
Thank you, Steve_!
aphex4000 is offline Find More Posts by aphex4000
Old Mar 10, 2013, 01:31 AM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
Or you get it ready to use, 1.93 USD shipped:
http://www.ebay.com/itm/Temperature-...item3f10feed0b
Bought it there half a year ago - reliable seller.
-mike-
edit:
forget it - no more free shipping
2nd edit: http://www.ebay.com/itm/NEW-Temperat...item53f08c7d48
3.27 USD shipped - with magnetic probe head
mikefromgermany is offline Find More Posts by mikefromgermany
Old Mar 10, 2013, 03:10 AM
Rajah235 is offline
Find More Posts by Rajah235
Just a 9116 flyer.
Rajah235's Avatar
Australia, NSW, Wollongong
Joined Dec 2012
^, Same here, Mike.
I have 2 sitting in the iMax box ATM.
The magnetic head feature is no good for the Li-Po's though, but you can get it close
& cuddly by careful positioning.
& HK has similar Nano Tech Li-Po's at a reasonable price.
Watch the shipping costs though.
> http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
& did anyone's "Time Zone" just change by one hour?
Mine did.
I posted this at 6.10 PM Sunday 10th my time & the forum displays it as 7.10 PM.
It is now 6.54 PM.
[edit]
It seems to have corrected itself, now.
[/edit]
Rajah235 is offline Find More Posts by Rajah235
Old Mar 10, 2013, 08:13 AM
Pa flyer is offline
Find More Posts by Pa flyer
Joined Aug 2012
Originally Posted by Mdigiovabc View Post
No a UBEC is not necessary and you are correct I just used it to provide a regulated power for the receiver. The battery out is higher than what a receiver needs and this particular one will work on batteries of 2 to 6 cells and will output either 5 V or 6 V. When you go brushless you would not use the UBEC but you would you the ESC to provide the voltage required by the receiver. I only used the UBEC because I had it for another project.
The green doughnut is part of the UBEC and is attached to the output wires. it is a ferrite ring and is used to decrease electromagnetic interference
Thanks for your answer, Mdigiovabc. I have a spare brushless 7.4v outrunner motor, main gears and 10 tooth pinions for my Wasps and I thought I'd try to use them if I'm going to add the extra weight of a second rx. HK has a cheap 3 ch rx that supposedly will work with the Flysky 9x (the rx that comes with it is too heavy). With that and a lightweight esc I should be able to make it work and keep the weight down.
Pa flyer is offline Find More Posts by Pa flyer
Old Mar 10, 2013, 11:07 AM
Steve_'s Avatar
Joined Nov 2012
Success !! The HK250GT FP Conversion Lives !!
Old Mar 10, 2013, 01:24 PM
Mdigiovabc is offline
Find More Posts by Mdigiovabc
Canada, BC, New Westminster
Joined Feb 2012
I took out the 9x receiver from it's hard plastic case and the weight of the 9x rx out of the case is within a gram of the 9116 board. I was planning on eliminating the v912 pcb completely and using just the 9x receiver. I have been looking at the skyartec wasp v3 since it runs off of a 900 mah battery and has a brushless 4500 kv main motor and a a 12A esc. Your wasp has a belt tail drive so I was thinking of seeing if i could retrofit the wasp tail drive. Since you have the wasp do you think that this is feasible? if this is not feasilble then i would have to look at a brushless tail motor and esc. i have been looking at the Turnigy 1230 motor with a 6A esc. I'm concerned about finding the right combination of tail motor and tail rotor though. I was planning on using the Skyartec head hold gyro.
Mdigiovabc is offline Find More Posts by Mdigiovabc
Old Mar 10, 2013, 01:25 PM
Steve_'s Avatar
Joined Nov 2012
Old Mar 10, 2013, 01:48 PM
tennvolsfan78 is offline
Find More Posts by tennvolsfan78
United States, IL, Morton
Joined Mar 2013
frustrated dh owner
hello and good day out there to all my fellow heli enthusiasts!..i am the owner of 4 d.h. helis..a 9100,9117 and two 9116. shew..i duno where to start..i am just to my ends with these buggers..well..mayb more the poor quality of parts. 3 days ago..i had 3 operational helis..today....ZERO!..i recieved my new (or what i thought was new) pcb boards the other day and i orderd 3 board along with sum other misc. parts..right from the get go..one board wood not bind..the other two..after installing them..i took flight..and no more than a minute er two..my helis proceeded to take a notion to start spinning round n round uncontrollably...i throttld down the stick..but they jus kept going..needless ta say..the outcome was not good. this was the third time ive orderd new boards...they jus keep frying out on me. !! i kno i hooked them up right..xheli nor think rc will take ny responsibility for my broken helis..even tho they sent me USED AND POORLY REFURBISHED boards...these things lookd like a two year old child had solderd them. im just sooo frustrated and i think i wanna get into planes..or switch to a mjx45.i posted in the classified under trade..idoes ther nyone out there that has eithr a decent little rtf learners plane..or an mjx-45 theyd be intersted in workin out a deal on for some dh parts and two functioning(minus the boards)9116 helis? have bunch..i mean evrything..ta build four helis ..just not havn luck with these suckersand im tired of waiting and waiting and waitng for parts to come only to get a couple of mins fly time with them, sumone please help! lol...thankyou and gooday
tennvolsfan78 is offline Find More Posts by tennvolsfan78
Old Mar 10, 2013, 02:08 PM
Steve_'s Avatar
Joined Nov 2012
Old Mar 10, 2013, 02:22 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Balr14 is offline Find More Posts by Balr14
Old Mar 10, 2013, 02:41 PM
Germany, Berlin
Joined Jun 2012
Originally Posted by Balr14 View Post
At this point in time, you are probably getting leftover components. I'm sure they aren't still making these models. That's not how the Chinese toy business works.
Not necessarily in this case, although the productions half-life period for the 9116 is long over.
DH is generally known for solder jobs that may teach you sth...
Just as an example - a PCB detail, ordered July, 2012:
http://www.rcgroups.com/forums/showt...3#post22515388
-mike-
Old Mar 10, 2013, 02:50 PM
Steve_'s Avatar
Joined Nov 2012
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 04:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 08:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 11:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 02:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 10:22 AM
