Old Dec 26, 2012, 10:44 PM
jimmy boo is offline
Find More Posts by jimmy boo
jimmy boo's Avatar
United States, WA, Mercer Island
Joined Dec 2012
^that is craze fast. I guess I could probably do that if mine wasn't one big piece of tape, rubber bands and worn pieces.
jimmy boo is offline Find More Posts by jimmy boo
Old Dec 26, 2012, 10:49 PM
Steve_ is offline
Find More Posts by Steve_
Venting Nowlege
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Deleted
Steve_ is offline Find More Posts by Steve_
Old Dec 26, 2012, 11:10 PM
karlik is offline
Find More Posts by karlik
Closed Account
Joined Apr 2010
Somebody might want to try the Airy Harden blades. They have been used on the CB-180 and the Ufly.
You would measure length on your existing blades and use the list halfway down this page..
http://www.helipal.com/airy-harden-b...cn952fvc9q3od3
The ones suggested for the ufly are a tiny bit shorter, narrower and have more pitch than the original. The original weigh 11.5 grams, airy harden weigh 10 grams.
I have no idea if any would fit the 9116 and what the difference would be.
Most are for coax so the down side would be get 4 and 2 would be throw aways.
karlik is offline Find More Posts by karlik
Old Dec 26, 2012, 11:43 PM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Deleted
Old Dec 27, 2012, 12:34 AM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Balr14 is offline Find More Posts by Balr14
Old Dec 27, 2012, 05:09 AM
Whizgig is offline
Find More Posts by Whizgig
Eugene
Whizgig's Avatar
Australia, VIC, Delacombe
Joined Oct 2006
Originally Posted by Sodbust View Post
For the crashes,, rolls and tumbles my old 9116 has done and came up flying again...I feel that its a darn good old bird.. I drilled holes in the side plates and removed a lot of weight.. Wish now I put the shavings on a gram scale to see how much but the bird flies better now..
What it boils down to is I have a $300 (nameless) heli,, that does not want to fly.. I have had it up a total of 10 minutes and repairs from minor crashes have cost me over $200.. and 100s of hours workbench time..
What the 9116 lacks is a better rotor head,, and linkage.. Brush-less motors and a better pcb as over all the chassis is near bullet proof and the heli fly's.. I'm no expert but hope to sell my high dollar heli and salvage some of my money to update my 9116... I personally feel its worth it as its given me the most air time for the less dollars.
Anyone in the world who could assemble a update kit for a 9116,, my pay pal is ready to buy..
Sodbust
What is the nameless heli ?
Instead of updating the 9116 why not get a new heli?
You could go for the MJX-F45 4ch fp which is a 300 size heli that I have and is very stable and flies very well and is very fast and can handle the wind ok and can be converted to BL very easily as it has the facility for it on the PCB.
You could go for the Skyartec WASP X3 V 6ch FBL BL 3D CCP 250 size heli which I own as well which will hover out of the box as it is fitted with a 3 axis gyro and can be flown in the wind etc, it comes with the new X303V receiver which can be changed from beginner mode to full on expert with a press of a button on the receiver. And it is fantastic.
It's up too you.
Whizgig is offline Find More Posts by Whizgig
Old Dec 27, 2012, 05:53 AM
Rajah235 is offline
Find More Posts by Rajah235
An RC Yachtie.
Rajah235's Avatar
Australia, NSW, Wollongong
Joined Dec 2012
Originally Posted by Steve_ View Post
........ (What does a stock 9116 weigh, anyway?)
Hi guys,
My "Blue Boy" finally arrived.
I haven't touched it yet so ......I'll weigh him when my digital scales arrive.
Steve, I know you've upped the servos & used captive lower ball sockets but is there a small B & S set available for the original servos?
The arms are so tiny & flexible.
(I do have 3 Turnigy? spare servos a'comin'.)
I have some small brass ball & nylon sockets that I may use.
Will see.
&.....I see what you mean about the main motors.
Cheap & very nasty.
Brushes? What darn brushes? Lucky to be 2 mm cubed.
Replace them? Hah! No way Jose.
Thankfully, I have a few of them on order too.
& all those loose wires floating around in/near the gear box.
Oh BTW, the supplier said that the Tx was only available in Aus as Mode 2.
Well guess what. Mine was Mode 1.
I had to change the return spring/bar assy from the left to the right & transfer the ratchet plate.
I also went through the whole set-up procedure & everything seems to function correctly.
I haven't done any re-soldering as yet but after charging it up & reading (or trying to) the manual, & checking a few basics, it looks O.K.
Now all I need is for some spares to arrive & off he goes.
L..
Rajah235 is offline Find More Posts by Rajah235
Old Dec 27, 2012, 08:01 AM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Deleted
Old Dec 27, 2012, 08:51 AM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Deleted
Old Dec 27, 2012, 08:52 AM
Rajah235 is offline
An RC Yachtie.
Rajah235's Avatar
Joined Dec 2012
Steve,
I'm 67 yo & been doing RC stuff since the mid 1970's.
Mainly water craft....A "Multi boat" with an OPS 45, OS 10 etc & a couple of electrics thrown in.
I've been sailing IOM & Marblehead yachts for the last 32 yrs.
Gee, time sure does fly.
Any ideas on the small captive ball & socket set for the original servos?
I've left the rates at default FTM..
I've also noticed a slight repositioning in the servos, going from "learner mode" to "maniac mode", but not sure if it will affect the stability or ?
Might just be a sticky Tx stick/pot assy.
Well, I've just finished ordering a heap of spares. ($100.00 odd.)
((I like spares.))
Hope I don't need them too soon.
L..
Old Dec 27, 2012, 09:00 AM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Deleted
Old Dec 27, 2012, 09:14 AM
jimmy boo's Avatar
Joined Dec 2012
sorry to take over the thread for a second,
does anybody know any ways of increasing the range of DH 9116 with everything stock. As you can see with my last video, there were a lot of problems with interference. I didn't even think it was that high, I.e. was not disoriented. I remember something about extending the antenna on the heli. thoughts?
Old Dec 27, 2012, 09:25 AM
Rajah235 is offline
An RC Yachtie.
Rajah235's Avatar
Joined Dec 2012
Thanks for the list., Steve.
Well, I ordered 2 PCB's, 3 Main motors, 2 Tail Assy's, 2 Main blades, (more in kits), 3 or 4 Tail blades, (in kits), along with 3 main drive shafts, 2 balance bars, swash plates, (in kits), top shafts, landing skids & 2 main bearings.
BTW, how does the balance bar come off?
Just prize the plastic top shaft apart?
Seems rather iffy.
L..
Old Dec 27, 2012, 10:00 AM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Deleted
Old Dec 27, 2012, 10:02 AM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Deleted
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
