Old Feb 23, 2013, 11:36 PM
Gygax is offline
Find More Posts by Gygax
FPV Plank Scratcher
Gygax's Avatar
Australia, NSW, Keerrong
Joined Jan 2013
gyro positioning -
http://www.rcgroups.com/forums/showt...d#post23855641
Gygax is offline Find More Posts by Gygax
Old Feb 24, 2013, 12:52 AM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Balr14 is offline Find More Posts by Balr14
Old Feb 24, 2013, 03:07 AM
Rajah235 is offline
Find More Posts by Rajah235
Just a 9116 flyer.
Rajah235's Avatar
Australia, NSW, Wollongong
Joined Dec 2012
Nicke wrote...
Do you mean I can charge several batteries with that Imax b6 charger?
Yes Nicke, but not at the same time, unless you use a parallel charging board.
> http://www.hobbyking.com/hobbyking/s..._6S_XT60_.html
A Google brings a few results.
> http://www.rchelicopterfun.com/paral...-charging.html
> https://sites.google.com/site/tjingu...allel-charging
> http://www.hobbyking.com/hobbyking/f...s.asp?TID=4534
> http://www.helifreak.com/showthread.php?t=353326
Confused yet?
I am.
Rajah235 is offline Find More Posts by Rajah235
Old Feb 24, 2013, 03:55 AM
Nicke.a is offline
Find More Posts by Nicke.a
Nicke.a's Avatar
Sweden, Jönköping County, Gislaved
Joined Feb 2013
Originally Posted by Rajah235 View Post
Nicke wrote...
Confused yet?
I am.
Haha no not more confused than before just a little embarressed
I'm a month behind the development, and trying to catch up...
Google is usually my friend and I should ask him first
this should work as a parallel charging board, right? http://www.banggood.com/Wholesale-Mc...x-p-64727.html
Nicke.a is offline Find More Posts by Nicke.a
Old Feb 24, 2013, 05:50 AM
Rajah235 is offline
Just a 9116 flyer.
Rajah235's Avatar
Joined Dec 2012
& this link is from my astronomy forum for those that are interested in &/or use 3D printing.
3D printing becomes a reality for the consumer (3 min 34 sec)
This one is ~$1000.00 Aus. from > http://store.3dprintingsystems.com/i...product_id=101
Nicke,
You have to use this as well or mod a balance board.
> http://www.progressiverc.com/paralle...rge-cable.html
Check the video at the bottom.
HK has them but on back order........as per usual.
> http://www.hobbyking.com/hobbyking/s...dproduct=14852
Old Feb 24, 2013, 07:52 AM
Dweenie is offline
Find More Posts by Dweenie
Mr. Crash and Burn
Joined Jan 2013
Originally Posted by Balr14 View Post
I have Thunder TIger Innovator helis, a completely different head design. You need to position your throttle in the center, with throttle trim all the way down, center all of your other trims, disconnect your motor, turn on the transmitter and connect the battery. Your rotor head should be in the center of it's vertical travel, your swashplate should be level, your servo arms should be level and your pitch should be zero. Adjust linkage for anything that needs it.
you see i did that and in norm mode the swash moves all the way down the shaft at low stick and if i flip to id mode the swash never goes to full neg pitch its like my tx is retarded and for some reason reversed the pitch for norm and id in the software some how
Dweenie is offline Find More Posts by Dweenie
Old Feb 24, 2013, 08:07 AM
Nicke.a is offline
Nicke.a's Avatar
Joined Feb 2013
I've tested positioning of the gyro, it doesn't matter where or how you put it, just not upsidedown, but it sure can be mounted a bit tilted, I have not yet tried flight characteristic, but will do soon.
The gyro is a fantastic little device
Old Feb 24, 2013, 09:02 AM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
nope.
with this balancing adapter you are able to hook 3 separate 2s batts on the charger and let them balance charge as a single 6s batt ( as long as you have the right JST charging adapter, too.)
You have to solder one - and are ready for 3 9116 batts at the same time
-mike-
mikefromgermany is offline Find More Posts by mikefromgermany
Old Feb 24, 2013, 10:46 AM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Old Feb 24, 2013, 10:47 AM
resago is offline
Find More Posts by resago
Joined Dec 2012
The v913 is out, look at the mixing arms!
http://www.rc711.com/shop/wltoys-v91...bo-p-7301.html
resago is offline Find More Posts by resago
hifinsword is offline
Find More Posts by hifinsword
Blue Skies
hifinsword's Avatar
United States, VA, Williamsburg
Joined May 2012
Mixing arms
[QUOTE=Steve_;24213576]
But yes, I undestand not everyone has the time and tools, so
there are a bunch of us looking for that perfect drop-in solution.
Some had good luck with the E-1003 $1 head from BG, mine are
on the way.
http://www.banggood.com/Wholesale-Be...3-p-54024.html
Originally Posted by Steve_ View Post
Here are the arms you want, if you want ball bearings and have a set of small drill bits. $6 shipped to your door. I ordered one pair.
http://www.ebay.com/itm/111016005953...84.m1439.l2649
I'm thinking this will need a #54 drill bit, but I would start with a #55,
and a #53 will be plenty big for a 1.5mm bolt with a nut on the back.
I will probably try to thread the aluminum first, and if that does not
work then I will drill out the threads and use a nut to secure the bolt.
These are 2:1 not 1.5:1, and will be great after
drilling a few extra holes allowing adjustable ratios.
The ball centers are 6.5mm and 12mm from pivot center,
making the max ratio almost 2:1, which is too much according to
Pa Flyer, but it's nice to have the option. The possible ratios
are almost limitless if you stagger the mounting holes.
The stock arms are 6mm and 6mm (1 to 1)
________________________________________________
Check these out, $6 shipped to my door.
They look to be roughly 1.5 to 1, same ratio many of you are using.
These are actual Align parts, and should last a LONG time.
The Trex 250 heads spin at 4000 RPM, so a 9116 head should be no sweat.
Originally Posted by resago View Post
Oh crap I forgot to mention this cause I was taking parts off my own e-1003. You have to order the fly bar too. The pivot holes are slight bigger.
I guess you could put some tape on the 9116 part and make it work, or a brass collar to make it perfect.
If I'm reading this right, the first set of TREX 250 arms are 2:1 ratio and require some work to get the connecting link secured with nuts & bolts (Too hard for me). The second set of TREX arms appear to be the same as the first ones but with a 1.5:1 ratio. But it's unclear if they require the same amount of work to get the connecting rod attached to one end of the arm but I assume they do.
The BenMa E-1003 arms sound like a drop-in. But you have to get the balance bar because of the pivot hole being larger than stock? So it's about $3.90 ($2.90[inner shaft, main blade holder & mixing arms]+$1 [balance bar]) for the improved BenMa mod.
The price of the BenMa comes with a stock inner shaft, main blade grips and the mixing arms. Stock parts for those cost $1.70 - 9100-6 inner shaft, + $3.19 for the balance bar ,+ $1.86 for the main blade grip including the mixing arms or $6.75 total.
The BenMa E-1003 mixing arm replacement (w/inner shaft & main blade grips & bal.bar) sounds like better performance (I hope) at a cheaper cost than stock and about the same as the TREX 250 mixing arms alone! Sounds good. Soon as this is confirmed all you guys that put in the effort should be crowned - Royalty in the Double Horse or BenMa realm!
Don
hifinsword is offline Find More Posts by hifinsword
Old Feb 24, 2013, 10:59 AM
Blue Skies
hifinsword's Avatar
Joined May 2012
v913
At $75 and with the $50 shp, it's still $25 less than the $150 BG is charging but still beyond my budget. I can wait.
Old Feb 24, 2013, 12:06 PM
Germany, Berlin
Joined Jun 2012
for all who already have a 9x or any 6CH TX with trainer port and want to have a quad for a learner:
The HK micro Q-Bot
and later a decent 6CH CP 66USD to fly with the same TX/module combination
gives you 2 toys for the price of one (100USD) to step the ladder up.
Or you add the HK 6CH for 20sthing and are set with 125 USD including a programmable TX.
-mike-
Old Feb 24, 2013, 12:59 PM
Dweenie is offline
Mr. Crash and Burn
Joined Jan 2013
That means you need to adjust your pitch settings in the transmitter. Have you seen Finless Bob's Trex 450 setup videos over at Helifreak.com? You should, if you haven't.
some reason my id and norm mode switch in my tx the software and the tx don't match up....Also if i try to reverse two servos it messes up everything so my left and right are right and left cause i can't reverse or it messes up everything...how i found out what was going on i set all my pitch to 50 on both norm and id and then on the norm side of the switch i programed the pitch in but the tx didnt respond with the switch in the normal norm mode i had to switch it to id mode to get it to wrk....Guess ill just have to save up and get a good tx one that isnt backward junk lol
Old Feb 24, 2013, 01:49 PM
Nicke.a is offline
Nicke.a's Avatar
Joined Feb 2013
got the pcb in place and made a fix for the battery, the ballance in flight felt much better
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
