Old Feb 23, 2013, 12:51 PM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
Originally Posted by Mdigiovabc View Post
I already have my 9x ...
I really like the 9x and it controls the WL products very well. The er9x firmware modification that I is a must (in my opinion). I have added a backlight to the 9x as well as a 2650mah 1c lipo for the transmitter (no longer buying batteries for Tx). I have purchased a 9-1 wireless adapter for the 9x where I'm able to use my 9x Tx on flight simulators. The device has a USB port that you plug into your computer and then you hook up a Turnigy receiver to it and you are no longer tethered to a a TX. The added advantage is that you get to use the 9x as your simulator Tx instead of a mickey mouse tethered Tx. I have already set it up and have tested it out on demo software. I have ordered Phoenix RC 4 and just have to go across the border into the USA to pick it up.
All useful transformations to the 9x in fact.
But sometimes you have to cut the expenses.
So the er9x mod isn't really a must as long as you stay with 4ch bricked RX / RTF models.
Backlight - nice but not necessary - I don't even look at the display when flying - there is simply no time to do that when flying a BL micro CP heli.
Only feature I found really useful and worth the money was the detachable module of a real TH9x as I use 3 different modules (and 4th on the way) for my different models.
-mike-
mikefromgermany is offline Find More Posts by mikefromgermany
Old Feb 23, 2013, 02:16 PM
Mdigiovabc is offline
Find More Posts by Mdigiovabc
Canada, BC, New Westminster
Joined Feb 2012
-mike-
The er9x mod is a must in my opinion for 2 reasons:
1) you can have it warn you that the Tx is still on - that way you won't kill your batteries. With the er9x firmware you can set the inactivity time before it warns you that the Tx is still on.
2) you can eliminate the annoying beep every time you press a key on the TX while you are setting it up. The beep is very loud and can be heard throughout the house.
I agree that backlight is not necessary when you are flying. However, I find it very handy when I'm in my home and I have to make some changes or do the initial setup and I can clearly see what I`m doing. Maybe you young fellows don`t need it as much as us but for me the $4.95 was worth it. NOTE: If you have the ability to flash the er9x, then you can do all of the configuration settings on your computer and you don`t need the backlight. However if you don`t have the er9x firmware then you are stuck using the unlit LCD display.
Mdigiovabc is offline Find More Posts by Mdigiovabc
Old Feb 23, 2013, 02:18 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Balr14 is offline Find More Posts by Balr14
Old Feb 23, 2013, 02:32 PM
Steve_ is offline
Find More Posts by Steve_
More Flights = Less Crashing
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Content Removed due to the fact that I do not agree with forum policy
here, and do not want them generating profit with my content.
Steve_ is offline Find More Posts by Steve_
Old Feb 23, 2013, 02:37 PM
Germany, Berlin
Joined Jun 2012
I didn't say the er9x isn't convenient or hasn't useful options.
I'm using these by myself.
-mike-
Old Feb 23, 2013, 05:20 PM
Dweenie is offline
Find More Posts by Dweenie
Mr. Crash and Burn
Joined Jan 2013
im about to the point of just sending my 9116 to the trash....The damn thing won't fly for crap...There is a light breeze i mean light the tree limbs arnt really moving..The 9116 will hover ok but soon as you give it input its all over the place backwards side to side some times nose down hauling ass.....Earlier i was so pissed at it i just let go of the sticks and let it fly backwards in a circle,well till it crashed into the side of our storage building..
Dweenie is offline Find More Posts by Dweenie
Old Feb 23, 2013, 07:20 PM
resago is offline
Find More Posts by resago
Joined Dec 2012
Heh I just stripped out all three of my no name servos that came in the hausler, guess they couldn't stand the strain of 3 blade fbl. :-)
No other damage when it ditched.
Are the henge md933 good?
resago is offline Find More Posts by resago
Old Feb 23, 2013, 07:42 PM
Gygax is offline
Find More Posts by Gygax
Slope Soaring Plank Scratcher
Gygax's Avatar
Australia, NSW, Keerrong
Joined Jan 2013
Originally Posted by Nicke.a View Post
What happends if I place the pcb behind the shaft, that would really help my ballancing..
from what i remember.. it reverses the reactions/effect of the gyro.. it would make the tail react back to front?
sorry i cant recall exactly.. its buried somewhere back in this thread
Gygax is offline Find More Posts by Gygax
Old Feb 23, 2013, 07:49 PM
Pa flyer is online now
Find More Posts by Pa flyer
Joined Aug 2012
If that's the case wouldn't you just have to reverse the rudder in the tx to get it to work right?
Pa flyer is online now Find More Posts by Pa flyer
Old Feb 23, 2013, 07:55 PM
Gygax is offline
Gygax's Avatar
Joined Jan 2013
thats what i was thinking as i wrote that..
cant remember the details, but at the time it seemed like a problem for whoever it was that tried it..
Old Feb 23, 2013, 09:52 PM
Nicke.a is offline
Find More Posts by Nicke.a
Nicke.a's Avatar
Sweden, Jönköping County, Gislaved
Joined Feb 2013
Originally Posted by Rajah235 View Post
Nicke, you will be fine using anything that supplies 4 or 6 Amps.
Most Li-Po battery's "normally recommended" charge rate, is just 1C.
Ok, thanks m8
Any stabilised supply that can hold 11-17V at 5 amps will do it.
With only a few small mini heli batts to charge you will not need the 5 amps, but trying to parallel charge 10 of 600mAH 1s batts limits it already.
-mike-
Do you mean I can charge several batteries with that Imax b6 charger?
Nah, the pcb still provides the servos with the same signals from the TX, so if you reverse them the heli will turn the wrong way and the gyro will still correct to the wrong way resulting in a endless spin?
You know what, I'll do a test tomorrow
You must be right though about gyro placed behind shaft will mess up everything.
Nicke.a is offline Find More Posts by Nicke.a
Old Feb 23, 2013, 10:38 PM
jkoosh27 is offline
Find More Posts by jkoosh27
cut cut cut... ****!
jkoosh27's Avatar
United States, PA, Birdsboro
Joined Dec 2012
I was one of those whose turned the Pcb around and in the process managed too get the gyro beyond the main shaft and as far as I remember nothing had to be changed on the tx.
I do remember posing that same set of questions though.
jkoosh27 is offline Find More Posts by jkoosh27
Old Feb 23, 2013, 10:52 PM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Old Feb 23, 2013, 10:55 PM
Dweenie is offline
Mr. Crash and Burn
Joined Jan 2013
Originally Posted by Balr14 View Post
Repositioning the gyro might have some effect on how it reacts, because you are changing the axis it's turning on, but it is still turning the same way, clockwise is still clockwise, etc. It's quite another matter if you turn it over or stand it on end, though.
hey balr can you do me a favor if you still have your cp heli could you take pics of the swash where it sets at low med and high stick in both norm and id mode i believe my radio went retarded....
Old Feb 24, 2013, 12:15 AM
gsking is offline
Find More Posts by gsking
SF Bay Area
Joined Jan 2013
Shouldn't make a difference.. Funny thing about moments (those things gyros measure)....they are the same regardless of the distance to the axis of rotation. It never quite squared with me in school, but that's how it works.
I'd think the thing to worry about would be vibration. That could affect the gyro, and it WILL vary with location.
gsking is offline Find More Posts by gsking
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 04:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 08:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 11:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 02:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 10:22 AM
