Old Feb 17, 2013, 01:13 AM
Steve_ is offline
Find More Posts by Steve_
More Flights = Less Crashing
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
HK250GT with 9116 head
Content Removed due to the fact that I do not agree with forum policy
here, and do not want them generating profit with my content.
Steve_ is offline Find More Posts by Steve_
Old Feb 17, 2013, 01:50 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Feb 17, 2013, 04:23 AM
Nicke.a is offline
Find More Posts by Nicke.a
Nicke.a's Avatar
Sweden, Jönköping County, Gislaved
Joined Feb 2013
Omg this thread is soo mutch fun!
I got a hard time keeping up searching info about possible part match for upgrade, work, family, reading this thread
About the "head" for $1 at BG that was only the blade holders right? not the complete head ass.?
I've done some tests to, one worked and one didn't :P
This one didn't...
Nicke.a is offline Find More Posts by Nicke.a
Old Feb 17, 2013, 04:26 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
9116 Swashplate with 9104 top and 250GT balls
Old Feb 17, 2013, 04:32 AM
Nicke.a is offline
Nicke.a's Avatar
Joined Feb 2013
But this one really did!
I had big truble with left aile, there was none... and some times the reaction on elev and aile was delaied (spelling is not my strong side..)
I noticed that the mainshaft had a rough surface and the swash plate had a hard time to travel.
So I polished the mainshaft with first 200 paper, then 400 and finally metal polish (Autosol)
Haven't had any chance to test outside cuz all the white stuff spread over hole sweden...
I also trimmed the ballancebar weights equal and also the blades, it made it mutch more stable
Old Feb 17, 2013, 04:36 AM
Nicke.a is offline
Nicke.a's Avatar
Joined Feb 2013
Originally Posted by Steve_ View Post
This is the 9104 / 9116 / HK250GT swash hybrid that goes
to my "good" 9116, not the 250 FP conversion.
You got metalballs? I must missed something, which one is it and what linkage do you use?
Old Feb 17, 2013, 04:37 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Feb 17, 2013, 04:41 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Feb 17, 2013, 05:16 AM
Nicke.a is offline
Nicke.a's Avatar
Joined Feb 2013
That swash goes to the 9116 chassis, not the FP conversion.
It uses HK250GT linkage and custom cut rods, some made from
long 1.5mm bolts. To mount the balls you drill the top swash
piece (pulled from a 9104) with a #55 drill bit, and just screw them on.
The 9104 swash uses a brass pivot bushing, reducing slop.
The stock one is plastic.
The FP conversion is actually just a HK250GT w/ a 9116 head, and
uses the HK250GT swashplate, which is 200% better
You got some interesting stuff going on m8
So if I got you right, your 9116 has a modded 9104 swash with metalballs and hk250gt linkage?
Is it possible to fit the 250gt swash to 9116 shaft?
Are you going to point out the mod that did work?
I did... :P
Yeah I bent the balancebar straight again and the shiny shaft was the thing that really worked!
Old Feb 17, 2013, 06:16 AM
Rajah235 is offline
Find More Posts by Rajah235
Just a 9116 flyer.
Rajah235's Avatar
Australia, NSW, Wollongong
Joined Dec 2012
Nicke, If you haven't already tried it, then you might try the Bull Horns approach to the flybar mod for reducing the canopy strikes.
See post #4.
> http://www.rcgroups.com/forums/showthread.php?t=1750650
Rajah235 is offline Find More Posts by Rajah235
Old Feb 17, 2013, 06:18 AM
Nicke.a is offline
Nicke.a's Avatar
Joined Feb 2013
Now I'm searching for upgrade servos, light/lighter, same size, same cc mount, stronger.
Any ideas anyone? Walkera, Skyartec?
I also wonder about the main blade trims some of you did, can you explain how you did?
Old Feb 17, 2013, 06:43 AM
Rajah235 is offline
Just a 9116 flyer.
Rajah235's Avatar
Joined Dec 2012
Nicke,
These are a direct replacement/upgrade...
> http://www.hobbyking.com/hobbyking/s...=1440A%20servo
Old Feb 17, 2013, 07:38 AM
Nicke.a is offline
Nicke.a's Avatar
Joined Feb 2013
See post #4.
Nicke,
Bull Horns it is, servos are ordered. Thanks M8!
Old Feb 17, 2013, 08:13 AM
Rajah235 is offline
Just a 9116 flyer.
Rajah235's Avatar
Joined Dec 2012
You're welcome Nicke.
Steve has the low-down on the trimmed blades.
They do not trim the ends, just the trailing edge but by how much?
I can't find the post where he added the details & pics.
He'll be along shortly.
Old Feb 17, 2013, 08:22 AM
simz is offline
Find More Posts by simz
enter a new realm.....
simz's Avatar
Joined Dec 2012
canopy save.
bent bars didnt work for me,,,so I took a piece of poly. (most things come packaged with this stuff) trimmed it to size, painted it and attached it with double sided tape,,
if it breaks--pull it off and replace with new one(it was a free upgade for me) and it keeps the original canopy in order........worked for me, results may vary, user assumes all risks, copyright 2013, member FDIC. <<--disclaimer
sorry---just having fun ..
this mod was for a stock flybar----I also have a shortened one with adj. collars (less prone to strikes)--depends on what kind of flying I want to do...
simz is offline Find More Posts by simz
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 04:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 08:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 11:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 02:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 10:22 AM
