Old Feb 14, 2013, 08:22 PM
Steve_ is offline
Find More Posts by Steve_
Venting Nowlege
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Content Removed due to the fact that I do not agree with forum policy
here, and do not want them generating profit with my content.
Steve_ is offline Find More Posts by Steve_
Old Feb 14, 2013, 08:27 PM
resago is offline
Find More Posts by resago
Joined Dec 2012
Oh, I forgot my point.
For someone that wants to just bolt on an improvement, the fx60 or e-1003 head is really good. At medium speed, pendulum effect is very subdued.
, and continuous ff is possible.
I'll try to get a video of it this weekend.
Oh the dd tail holds the 180 pro no problem.
resago is offline Find More Posts by resago
Old Feb 14, 2013, 08:34 PM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Old Feb 14, 2013, 08:38 PM
jkoosh27 is offline
Find More Posts by jkoosh27
cut cut cut... ****!
jkoosh27's Avatar
United States, PA, Birdsboro
Joined Dec 2012
alright so now I'm back from work and what parts to order for the "new" mod?
HK250gt linkage and which mixing arms.....
I am thinking its gonna be off of banggood? (mind wanders after typing that every time...)
jkoosh27 is offline Find More Posts by jkoosh27
Old Feb 14, 2013, 08:39 PM
resago is offline
Joined Dec 2012
We could also come up with some kind of follower for the swash so it doesn't rotate separate from the main shaft. Like on real helis
Old Feb 14, 2013, 08:50 PM
SysCrusher is offline
Find More Posts by SysCrusher
United States, FL, Jacksonville
Joined Jan 2013
Originally Posted by Steve_ View Post
On a CP, the anti-rotation pin just keeps the swash
in position, and doesn't really carry any load.
On a FP, it is a pivot point for the weight of the entire
helicopter.
Another servo there working in reverse of the rear servos would work, but probably way impracticable considering the limited space.
SysCrusher is offline Find More Posts by SysCrusher
Old Feb 14, 2013, 08:54 PM
resago is offline
Joined Dec 2012
Or stick a turnbuckle somewhere and use the same servo.
Actually, i think you could use a std double arm on the elevator servo and use a bent rod to attach to the front pivot arm.
Old Feb 15, 2013, 05:09 AM
Rajah235 is offline
Find More Posts by Rajah235
Just a 9116 flyer.
Rajah235's Avatar
Australia, NSW, Wollongong
Joined Dec 2012
^, You may have to perform a little mechanical magic to get the original servo to work with the extra load.
Suppose you could always upgrade the damn things, like Steve.
The 3 pack of 1800A's I bought are a little more beefy in the torque department but not by much.
Bit more mass & slightly larger as well.
& yet, another week has past & I await the arrival of my spare parts....
Rajah235 is offline Find More Posts by Rajah235
Old Feb 15, 2013, 06:33 AM
Pa flyer is online now
Find More Posts by Pa flyer
Joined Aug 2012
Yes, the more I think about it, the more people should skip the
linkage upgrade, and just see how it flies with new mixing arms.
The linkage is a pain, and had to be custom cut and the size modified.
Since my mixing arms use different size balls, it complicates everything.
Let's see what Pa Flyer did to his. He mentioned that his is now
a rocket too, and can do continuous forward flight at high speed.
I think the mixing arms and balance bar weights are the key to the continuous
forward flight, as mine lacked the ability with the metal linkage alone.
As far as handling wind, I think it is the trimmed blades and the solid,
slop-free metal linkage that makes it fly solid and stable.
Steve, you're right about skipping the linkage upgrade and the improvement being in the mixing arms. Mine showed the improved flight before I tightened the links. I just had to tighten them because like you, I'm a perfectionist.
You're also right about the trimmed blades as I found out the other day when comparing trimmed to stock in the wind. I think much of the detrimental effect is due to the lowered flying headspeed on our lightened birds with stock blades. The effect might not be noticeable with a less severley lightened heli and in fact the lift of the standard blades would be needed with a heavier bird. Trimmed blades on an unlightened bird would also probably have the motor running out of it's powerband with the resultant loss of flight time.
Pa flyer is online now Find More Posts by Pa flyer
Old Feb 15, 2013, 06:42 AM
Joined Aug 2012
Originally Posted by simz View Post
this is what I was trying to emulate,,,a raised tail rotor and a movable horiz. fin..
will have to wait to try it out,,,,if it does not work ,,it would be easy to remove back to normal..
http://youtu.be/PTsjURnLFKM for vid.
Simz, How did you make out with your moveable horizontal fin? Did it work as expected?
Old Feb 15, 2013, 07:07 AM
Gygax is offline
Find More Posts by Gygax
FPV Plank Scratcher
Gygax's Avatar
Australia, NSW, Keerrong
Joined Jan 2013
this sounds sooo promising.. i just ordered v912 and E-1003 mixing arms
i have an almost stock weight 9116, the only bits removed are the hor. stab and the dec bars..
should be interesting to see if it is just the mixing arms that make the bigger difference.. and which ones..
Gygax is offline Find More Posts by Gygax
Old Feb 15, 2013, 07:19 AM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Old Feb 15, 2013, 07:24 AM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Old Feb 15, 2013, 07:31 AM
Rajah235 is offline
Just a 9116 flyer.
Rajah235's Avatar
Joined Dec 2012
You'all might like to use this to improve your guidance system & steerability.
& mines still stock, other than those stupid dress rod thingys & horizontal bar.
Not quite ready to rip it apart just yet...
(Still awaiting parts.....)
Oh. I already said that, didn't I?
Steve...I just checked the main shaft/"hollow tube" top bearing & it's got a little all around play in it.
I intend to change that plastic "whatever it's called" when I start on the motor mods.
It's possible that if it wears a tad more, maybe a circular brass shim can be inserted to take out the play. (if one hasn't got a replacement.)
Old Feb 15, 2013, 07:37 AM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
