Old Feb 12, 2013, 11:02 AM
Steve_ is offline
Find More Posts by Steve_
More Flights = Less Crashing
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Content Removed due to the fact that I do not agree with forum policy
here, and do not want them generating profit with my content.
Steve_ is offline Find More Posts by Steve_
Old Feb 12, 2013, 11:05 AM
Rajah235 is offline
Find More Posts by Rajah235
Just a 9116 flyer.
Rajah235's Avatar
Australia, NSW, Wollongong
Joined Dec 2012
Voltage & current readings of both "A" & "B" 180 BB motors.
O.K.
"We just want the facts M'am." Dum dee dum dumm. (Dragnet theme.)
The "A" motor. C/W rotation from the pinion end.
Ticks over at .24 volt @ .42 Amps.
1.0 volt = .48 Amps.
1.5 volts = .5 Amps.
2.0 volts = .52 Amps.
2.5 volts = .55 Amps.
3.0 volts = .57 Amps.
3.5 volts = .57 Amps.
4.0 volts = .57 Amps.
4.5 volts = .57 Amps.
5.0 volts = .54 Amps.
6.0 volts = .53 Amps.
7.0 volts = .53 Amps.
Stalled current at 1 volt (running & manually stopped) = 2.4 Amps.
....".........."........."..2 volts......"................"............"........ = 3.2 Amps.
The "B" motor. CCW rotation from the pinion end.
Ticks over at .2 volt @ .40 Amps.
1.0 volt = .55 Amps.
1.5 volts = .60 Amps.
2.0 volts = .62 Amps.
2.5 volts = .65 Amps.
3.0 volts = .65 Amps.
3.5 volts = .66 Amps.
4.0 volts = .67 Amps.
4.5 volts = .67 Amps.
5.0 volts = .67 Amps.
6.0 volts = .69 Amps.
7.0 volts = .66 Amps.
Stalled current at 1 volt (running & manually stopped) = 2.25 Amps.
....".........."........."..2 volts.....".................."................"... . = 4.4 Amps.
& the relative RPM's of each?.......They sounded about the same.
(I'm not going to mention what voltage I got them up to though.)
Surprising results from the "A" motor. The "B" motor sounded so much sweeter at the (not posted)......"slightly" higher voltages.
I am not going to try to stop them at any higher voltages due to the fact that I value my fingers.
These are running fairly fast & I am not using anything that will damage the pinions.
Tacho? Where fore art thou?
Bloody slow boats.
Rajah235 is offline Find More Posts by Rajah235
Old Feb 12, 2013, 11:08 AM
aphex4000 is offline
Find More Posts by aphex4000
Joined Nov 2012
Originally Posted by Steve_ View Post
GOT IT !!!
I Have continuous forward flight !!!
Whoo! Nice work. Is it a result of the heavy modifications or a change in control inputs?
aphex4000 is offline Find More Posts by aphex4000
Old Feb 12, 2013, 11:24 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Feb 12, 2013, 11:31 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Feb 12, 2013, 11:33 AM
Nicke.a is offline
Find More Posts by Nicke.a
Nicke.a's Avatar
Sweden, Jönköping County, Gislaved
Joined Feb 2013
Originally Posted by Balr14 View Post
The V912 fits your criteria nicely. Just keep in mind it's not exactly a learning experience that will take you to the next level.
Yeah, I read a thread were you talked about that these 4ch birds aint suitable for taking the next step, I'm a quick learner and after about 20 flights with my v911 I can fly quick mode and do several "stunts" and acrobatics in my livingroom, not to brag but of course my aim is 6ch.
Should I then go directly to v922?
I also read your recomendation for quads, I totally understand why, but that in my opinion looses some of the charm...
I dont whant an "improved" 9116 if its not for my advantage.. Even though I will still continue modding my 9116 cuz I'm interested in the mechanics
I guess a small 6ch to start with? Which one?
Originally Posted by Rajah235 View Post
Yeah, I saw that one but I just can't "see" the damn small components/pads anymore.
& I don't have a small enough iron.
I got this one, cheap and veeeeeerry handy http://www.dx.com/p/55930
Originally Posted by Pa flyer View Post
As Bair 14 said, it won't teach you much
Yeah and thats a problem! hehe I'll keep my 9116 for modding and as a toy
And talking about that here is my latest mod: Z-stabs
Seem to work great indoors, and thats my next problem.. here its -10C out so no outdoor flight for now, waiting to get a chance in a warehouse.
Nicke.a is offline Find More Posts by Nicke.a
Old Feb 12, 2013, 11:46 AM
Rajah235 is offline
Just a 9116 flyer.
Rajah235's Avatar
Joined Dec 2012
Thanks for thinking of me, Nicke.
I have 5 soldering irons ATM & don't really need another just for these SMD's.
Neat bending job there. Did you use "Bender" the robot from "Futurama"?
Old Feb 12, 2013, 11:48 AM
resago is offline
Find More Posts by resago
Joined Dec 2012
OK steve, we need to make a post of what got you there, It would be great to rule out the metal links, cause that may be out of most peoples skill set, but if someone were to do 2 or 3 mods, would it be:
1) move battery
2) trim flyweights
3) change mixing arms with (e-1003, v912, etc.. parts)
4) dd tail
5) 180 pro or other servicable motor.
once we get it nailed down we should make a new sticky/locked thread and/or have it added to the manual.
I wonder if someone could take a stock 9116 and just change out the mixing arms and get it to fly better than the f45
resago is offline Find More Posts by resago
Old Feb 12, 2013, 11:56 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Rajah235 is offline
Just a 9116 flyer.
Rajah235's Avatar
Joined Dec 2012
re; the serviceable motor/s...
These 180's are not fully serviceable. & the brush assy? Rubbish as well. IMHO.
They are crimped cans & you cannot change anything but the brushes.
No bushes, ball bearings, armatures, magnets.....nothing.
You cannot even find the bearings for them.
I have a stack of ball bearings coming for the S 16D's.
I just need a few other items & I'll start on the installation.
Steve... I just picked them at random. There are no figures or info on the package/s.
I took the pinion up the shaft to be the "A" motor.
"The "A" motor. C/W rotation from the pinion end."
It's no load figures look a lot better than the "B" motor.
The image on post #1748, shows both motors.
The "A" motor is the one with the pinion further on the motor shaft. AFAIK.
Not knowing the configuration of the heli they fit...I don't know which one drives what spur gear. ie; Upper or lower?
There are no arrows/marks etc on either.
The only differences are the pinion positions & the +ve & -ve are reversed.
Old Feb 12, 2013, 11:57 AM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
hmm sorry to repeat myself - but a decent quad will outfly a lot of CPs - ideal learning instrument.
Ugly? not necessarily - look at my avatar.
How this thing does in really windy conditions?
have a look:
hubsan x4 in wind (2 min 8 sec)
and also flyable in every room.
If you get a decent Devo TX, flashed with deviation FW you may also fly this beauty with a hobby grade TX to practise for your CP.
and maybe buy a MCPX or MCPX BL
Blade mCP X Brushless (BL) BNF New (2 min 51 sec)
(got one for one week now - serious practice was really needed for it... whoaaaa ) as a next step.
If you are capable of flying the double brushless MCPX, you will be able to fly every CP easy as anything.
-mike-
mikefromgermany is offline Find More Posts by mikefromgermany
Old Feb 12, 2013, 12:04 PM
rexless is offline
Find More Posts by rexless
Fly Fast, Fly Hard, Fly Fun
rexless's Avatar
Canada, BC
Joined Apr 2012
Thanks for the tip on the V912 pcb as a replacement for the POS DH 9116 PCB. I've ordered one from BG to try it out and see if that turns my DH9116's into something worth keeping. For a few bucks it's worth a try as currently my 2 9116's are paper weights. I have a box filled with tons of replacement parts - it would be sad to never use them!
rexless is offline Find More Posts by rexless
Old Feb 12, 2013, 12:06 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Feb 12, 2013, 12:18 PM
Balr14 is online now
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Balr14 is online now Find More Posts by Balr14
Old Feb 12, 2013, 12:40 PM
skyeblu is offline
Find More Posts by skyeblu
banging head on wall
skyeblu's Avatar
Joined Feb 2010
180 motor rotation
pinion closest to motor is the bottom blade = clockwise rotation. I looked at my cx3 these motors have been a popular upgrade for the CX3. If I remember right they have a set that are modified also. I haven't got the cx3 down for a year or two it has all the possible mods and now it's just a shelf queen looks good tho LOL
skyeblu is offline Find More Posts by skyeblu
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
