Old Feb 09, 2013, 05:57 PM
SysCrusher is offline
Find More Posts by SysCrusher
United States, FL, Jacksonville
Joined Jan 2013
Originally Posted by ajohnson677 View Post
My current bird. More mods to come. Just lightening her up and changing the COG made a world of difference. The tail has never been this responsive and it handled 15mph gusts like a champ.
That's a 3 legged horse!
SysCrusher is offline Find More Posts by SysCrusher
Old Feb 09, 2013, 07:10 PM
Joined Jan 2013
Finally got my 9100 back up in the air. The 9104 pcb works just fine except the mounting holes are an inch forward than the original pcb. Nothing a little plastic and velcro can't fix. So if you guys run out of pcb's for the 9116, I'm pretty sure the ones from the 9117 would work for you guys. Bigger mosfets that can handle the amp draw.
I had to get a new motor, pcb, eflite 2s 800mah 30c battery. Added a 15amp blade fuse. 9116 lower swash plate with upper 9104 swash with two turnigy 1440a servos. Flys great.
It took a dirt dive from 150ft up, I got to cocky and forgot about range. Nothing broke this time. Just a little dusty.
Old Feb 09, 2013, 09:30 PM
aphex4000 is offline
Find More Posts by aphex4000
Joined Nov 2012
Originally Posted by Steve_ View Post
It's Better !!
Forward flight is easier, and it has more cyclic, but it seems
smoother for some reason. The whole chassis does not swing
like it used to. That could be from the metal linkage.
And this is with a bad servo !!
I can't imagine what it will fly like with a good servo that does not
twitch all the time.
It still noses up on forward flight, but it's better, and seems to do it
less. There was 5 to 8 mph gusts, and it seems to have much more
"bite" when flying into the wind.
I made some beautiful banked turns, and they were way sweeter than
the F645 turns I was making the other night. My 9116 isn't as fast on
top speed, but it turns in 1/4 the radius.
When I was fighting a breeze to bring it back to me, and the breeze
shifted, it was not the end of the world, and it was not impossible
to fight the shifting wind patterns.
Also, the blades sound much meaner and louder now.
That makes no sense, as this mixing arm mod should reduce pitch.
But what is really happening is you are giving the pitch more force
to hold up against a breeze (such as forward flight).
At a hover, and lower speeds, the balance bar does not need much
torque on the blades to keep thinks in control.
But when you are going 15 Mph into a 5 Mph headwind, the head and
blades see 20 Mph.
Think of what a sudden 20 Mph gust would do if you were hovering,
and how much force it would put on the blades. Heck, a 20 Mph gust
would probably toss a 9116 or F645 into the next town.
_________________________________________________
Anyway, for having a bad servo, this thing flies like a dream
And that was with an unbalanced head. Since installing the new
head parts I still have yet to balance it, and will when I change
the servo. It will fly even more awesome with a functional servo,
and a balanced head that does not shake.
I think either 1.5:1 or 2:1 mixing arms will be perfect. The ones I'm
using now (Wasp V3) are just barely offset, and somewhere around
1.25:1 as there is under 2mm difference between sides.
You can barely see the offset, and I had to measure it to tell
the difference.
Good stuff. Too bad you're not working for DH, Steve_!
aphex4000 is offline Find More Posts by aphex4000
Old Feb 09, 2013, 10:12 PM
tada1096 is offline
Find More Posts by tada1096
Joined Jan 2013
Question about settings. When I'm in flight it doesn't want to drift left. When I'm testing it the servos are moving like they should but in flight it doesn't drift or drifts slowly. What do I need to adjust to fix this. In hover it does drift to the right so I adjusted the sub trim to help that.
tada1096 is offline Find More Posts by tada1096
Old Feb 09, 2013, 10:16 PM
Dweenie is offline
Find More Posts by Dweenie
Mr. Crash and Burn
Joined Jan 2013
took my ol 9116 out for a spin today didnt fly to bad. I was very sluggish after i tigtened up the head..I ended up breaking the landing skid clean off one side in a hard landing put a new one on.Went flying again till the second battery was dead then decided to mess with my 450...soooo long and behold my 450 kicked my butt the esc decided it wasnt going to give me throttle imput and opened up at 100 percent causing the heli to come at me and the tail blades chewed on my face and nose and thumb...
Dweenie is offline Find More Posts by Dweenie
Old Feb 09, 2013, 11:13 PM
resago is offline
Find More Posts by resago
Joined Dec 2012
Nice!
resago is offline Find More Posts by resago
Old Feb 10, 2013, 01:06 AM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
You're alright, mate? Nothing severe hurt?
-mike-
mikefromgermany is offline Find More Posts by mikefromgermany
Old Feb 10, 2013, 01:13 AM
Steve_ is offline
Find More Posts by Steve_
More Flights = Less Crashing
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Content Removed due to the fact that I do not agree with forum policy
here, and do not want them generating profit with my content.
Steve_ is offline Find More Posts by Steve_
Old Feb 10, 2013, 01:23 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Feb 10, 2013, 01:28 AM
TheSwing is offline
Find More Posts by TheSwing
Joined Jan 2013
is it possible to bind both 9116 helis to the same remote? I've tried and it doesn't seem to work... any advise? (If I buy another remote would that resolve the issue?)
TheSwing is offline Find More Posts by TheSwing
Old Feb 10, 2013, 01:31 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Gygax is offline
Find More Posts by Gygax
FPV Plank Scratcher
Gygax's Avatar
Australia, NSW, Keerrong
Joined Jan 2013
Originally Posted by Pa flyer View Post
the last few flights ive had random, fraction of a second engine cutouts in midair.. and since the big mod and pcb move this morning, its a lot worse.. actually led to it falling out of the sky completely.
i dont think its range.. maybe interference to the rx from being right under the main motor? it is quite random and intermittant
I was having the same motor cutout problem a few weeks back. I changed out all the electrical components and even did the MOPS bypass without any luck. Then I realized it only happened when I flew on one side of my house and near the neighbors house and a transformer on the pole. Someone on this thread mentioned that the neighbor could have a wireless router or phone near a window and it turned out that they did. That was my problem: outside interference. I don't fly in that area anymore and the problem went away.
Not saying that this is the cause of your problem, just that it's something to consider.
yeah i read your old posts about it with interest.. the problem sounded exactly the same..
turns out it was most likely a shonky solder though.
i removed the protective blutak layer from under the rx and on top of the gyro, (which i thought was a brilliant idea to cushion and anchor them).. and i also resoldered EVERY connection on the pcb till they were shiny and at least halfway neat.
now she rips
i HIGHLY recommend lowering the pcb and raising the battery onto a 'crashplate' at the front. the lifting of the centre of gravity gives it really good response and handling. im going back out now to tackle the 10-15 kmph wind
Gygax is offline Find More Posts by Gygax
Old Feb 10, 2013, 01:38 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
9116 Mixing Arm Upgrade
Old Feb 10, 2013, 02:09 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Feb 10, 2013, 02:21 AM
Gygax is offline
FPV Plank Scratcher
Gygax's Avatar
Joined Jan 2013
Where do I sign up?!?
I LOVE that sound.
For sheer eargasmic pleasure, my modded 9116 sounds way better and
meaner than the huge F645.
Pa knows
lmao..
steve i think you and pa are the co-founders.
yeah, its one of the finest sounds ive heard. i think mine cuts the air so sweetly, i can only imagine how it sounds with cropped blades.
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
