Old Feb 08, 2013, 11:18 AM
Steve_ is offline
Find More Posts by Steve_
More Flights = Less Crashing
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Content Removed due to the fact that I do not agree with forum policy
here, and do not want them generating profit with my content.
Steve_ is offline Find More Posts by Steve_
Old Feb 08, 2013, 11:22 AM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Balr14 is offline Find More Posts by Balr14
Old Feb 08, 2013, 11:32 AM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Old Feb 08, 2013, 02:55 PM
Pa flyer is offline
Find More Posts by Pa flyer
Joined Aug 2012
Belt drive
Originally Posted by Steve_ View Post
Keep in mind, with a shaft or belt drive, you need to be a
good pilot.
I broke 3 belts learning to hover, and 2 tail blades.(
I would try to find a better quality belt that fits if I were you. I had numerous crashes with my Wasp, went through a lot of servos, but never hurt the belt even though I broke tail blades, tail blade holders and bent the tail blade shaft.
Pa flyer is offline Find More Posts by Pa flyer
Old Feb 08, 2013, 04:23 PM
resago is offline
Find More Posts by resago
Joined Dec 2012
well at least there's one lesson that carries over to a 450; Don't let it hit the ground!
resago is offline Find More Posts by resago
Old Feb 08, 2013, 04:37 PM
aphex4000 is offline
Find More Posts by aphex4000
Joined Nov 2012
Dug this from some forum, it's someone speaking about the CB180z
(or the Air Hawk) .
"By moving the flybar links to the outside holes on the BH mixing arms I got pretty good cyclic response...."
It sounds like just what we need.
The F645 might be a tank, but it still has far more cyclic than
a stock 9116, and balance bar leverage is one of the few
differences between them.
Nice find! That sounds very promising. I sent off some plans this afternoon to have mixing arms printed. The ball stud mounting holes on one end of the first set are in their original position, while the others are moved 25%,50% and 75% further away from the axis of rotation so we can test with all three. I'm guessing it will be one week for the 3.8mm ball studs to come from eBay and up to 2 weeks for the mixing arms to come in. I also ordered some 3mm Honey Bee mixing arm bearings from BangGood, but I do not have measurements for outer diameter or width so this design will only be supported by the 3mm plastic shaft like the original part.
In the meantime, more practice!
aphex4000 is offline Find More Posts by aphex4000
Old Feb 08, 2013, 05:00 PM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
Originally Posted by aphex4000 View Post
You are really lifting the level of "How to mod this ol' bird" to the limit.....
-mike-
impressed
mikefromgermany is offline Find More Posts by mikefromgermany
Old Feb 08, 2013, 05:04 PM
Joined Nov 2012
-mike-
impressed
Haha, let's see if these actually work first! I may have only succeeded in wasting some $$ a few bits of plastic.
Btw, saw your post about quads and PM sent!
Old Feb 08, 2013, 07:36 PM
jwarrior is offline
Find More Posts by jwarrior
Warrior
United States, AZ, Peoria
Joined Dec 2012
It spins CCW while looking down on it?
That would mean your tail does not have enough power.
Since it is a new tail, double-check your trims and sub-trims.
_________________________________________________
If the tail is overpowering the main motor, and on the ground it spins
CW, then it's either a failing main motor, binding in the gears or bearings,
or the PCB.
There are other obscure problems that could cause this, such as a
bad potentiometer in the transmitter. But 90% of the time it will be
either a bad main motor or a bad PCB.
While it's all powered up, try to spin the heli by hand, and see if the
tail motor responds to movement.
If the tail runs wide open as soon as you give it a little throttle then
there is either a shorted output transistor or a bad gyro, and both
require replacement of the PCB.
Did you crash? It does not take much to break a gyro, they are very
shock sensitive.
I changed the entire boom and motor so wire crossing was not an issue. I did crash and that started the problems. So, I changed the tail assembly again back to the old one just for kicks and whatever was causing the problem went away. Maybe a bad new motor. It's flying fine now. Maybe it's a female bird and just being tempermental...haha. Thanks to everyone for all of your input. You guys rock!
J
jwarrior is offline Find More Posts by jwarrior
Old Feb 08, 2013, 11:07 PM
Laidback_racer is offline
Find More Posts by Laidback_racer
Build the Weapon....
Australia, VIC, Berwick
Joined Jan 2013
This is taking modding to a new level. Awesome job.
Laidback_racer is offline Find More Posts by Laidback_racer
Old Feb 08, 2013, 11:15 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Feb 08, 2013, 11:26 PM
Dweenie is offline
Find More Posts by Dweenie
Mr. Crash and Burn
Joined Jan 2013
those are the mixing arms correct me if im wrong
Dweenie is offline Find More Posts by Dweenie
Old Feb 08, 2013, 11:46 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Feb 09, 2013, 03:52 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Feb 09, 2013, 04:03 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
