Old Feb 07, 2013, 09:43 PM
Laidback_racer is offline
Find More Posts by Laidback_racer
Build the Weapon....
Australia, VIC, Berwick
Joined Jan 2013
Originally Posted by ajohnson677 View Post
Does anyone know if it is possible to disable the 9116 servo mixing? I assume it's done on the PCB but I have no clue how. I have a project in mind and I want to test it for free on my 9116 before sinking any cash into it. Problem is I need up-down and left-right to be independent channels. Any ideas?
The V912 PCB does this by default and so far is working with the 9116. But I have only done a few flights.
Laidback_racer is offline Find More Posts by Laidback_racer
Old Feb 07, 2013, 10:09 PM
JMCarlson is offline
Find More Posts by JMCarlson
Jeff Carlson
St. Paul, Minnesota
Joined Apr 2008
My guess would be that's all being handled on the PCB, where as in a 6ch heli and computer radio / rec, you can make those adjustments there
JMCarlson is offline Find More Posts by JMCarlson
Old Feb 07, 2013, 10:12 PM
ajohnson677 is offline
Find More Posts by ajohnson677
Joined Jan 2013
Great to know, I might try that out if there's no way to disable the original. What swashplate are you using with the unmixed servos?
ajohnson677 is offline Find More Posts by ajohnson677
Old Feb 07, 2013, 10:14 PM
Steve_ is offline
Find More Posts by Steve_
Venting Nowlege
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Content Removed due to the fact that I do not agree with forum policy
here, and do not want them generating profit with my content.
Steve_ is offline Find More Posts by Steve_
Old Feb 07, 2013, 10:15 PM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Old Feb 07, 2013, 10:22 PM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Old Feb 07, 2013, 10:50 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Balr14 is offline Find More Posts by Balr14
Old Feb 07, 2013, 10:59 PM
Joined Jan 2013
You can run the std swashplate, I run a ZR Z101 top with 9116 bottom so that I get the brass knuckle bearing which is essentially the same but less friction on the shaft.
The V912 PCB binds with the std 9116 Tx. Switch on the heli at the same time as as the Tx.
Old Feb 07, 2013, 11:45 PM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Old Feb 07, 2013, 11:47 PM
Joined Jan 2013
Originally Posted by Steve_ View Post
I think I may have found the problem on mine.
Is the balance bar supposed to be 45 degrees from the swashplate
balls EXACTLY, or is there a tolerance?
Mine is probably 35 degrees, as the lower links I made
appear to be slightly too long, due to the changed angles
from slightly different ball link locations.
Then I also assume that the main blades should be 90 degrees in
relation to the swashplate balls. Mine are at roughly 100.
(again, 10 degrees off).
This would totally explain the strange behavior I've been getting.
I thought it was a crooked custom blade grip locator pin, but I'm going to
try this first.
On the MJX, the flybar is almost exactly 45 degrees from the swashplate
balls, and the blades are 90.
The ZR Z101 head I have on mine at present has different angles to the 9116.
The flybar looks about 45 deg off the line of the blades (as in if it had a feathering shaft) but when I hold the old 9116 over the top of mine and line up the flybars I see the "feather shaft" angle is off by about 2 deg and the lower linkage guides are off by another 5 deg. My swashplate balls are also not 90 deg off the blades but the flybar is about 45 deg to the swashplate bales.
It will be interesting to see how the two heads compare once we have our motors and offset mixers in place.
The link with the fp conversion is interesting, but I am not sure why he bothered considering it is a 90 deg fly bar. I would have thought he could have just set a fixed pitch on the cp head and almost end with the same result, without spending well over $100? Unless he didnt get a cp head in his kit.
Old Feb 07, 2013, 11:57 PM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Old Feb 07, 2013, 11:59 PM
Dweenie is offline
Find More Posts by Dweenie
Mr. Crash and Burn
Joined Jan 2013
hope this puts you on the right path to what you want to do as of brushless set up on the 9116
http://youtu.be/5adi1H0vF0s?t=2m1
Dweenie is offline Find More Posts by Dweenie
Old Feb 08, 2013, 12:14 AM
Steve_ is offline
Venting Nowlege
Steve_'s Avatar
Joined Nov 2012
Old Feb 08, 2013, 12:16 AM
Joined Jan 2013
Maybe my flybar is not 45 deg to the swash balls. In the pic below both heli's have the swash balls at 90 deg to the tail shaft. Notice the different blade and flybar positions. The V911 at the moment is definitely the better performer and probably flys better in the wind.
The V912 PCB flys pretty much the same as the std PCB, although I am not getting as much forward angle unless I give it some aileron as well. Overall with my mods so far the heli is more stable in hover but not as good in forward flight. Hoping to change the forward flight. I have the 180A pro motor coming and a V912 tail motor which I am hoping will work better off the V912 PCB.
Old Feb 08, 2013, 12:19 AM
Dweenie is offline
Mr. Crash and Burn
Joined Jan 2013
She's a little small, and uses a 1S system.
This motor is 11,000KV because of the low supply voltage.
On a 9116, which is 2S, I'm thinking we will want a 3500-4500 KV motor.
The stock brushless motor in the Wasp V3 (2S) setup is 4500 KV.
To keep the price down, I'm looking for aftermarket motors.
OEM motors always cost more, the motor in the Walkera 180 series
(basically same size as the 9116) is $25, but a comparable
aftermarket motor is $10-15.
check out the walkera 180 it has all brushless setup and it runs off a 2s 1000 mah bat.those parts might interchange
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
