Old Feb 07, 2013, 05:04 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Balr14 is offline Find More Posts by Balr14
Old Feb 07, 2013, 05:05 PM
Steve_ is offline
Find More Posts by Steve_
More Flights = Less Crashing
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Content Removed due to the fact that I do not agree with forum policy
here, and do not want them generating profit with my content.
Steve_ is offline Find More Posts by Steve_
Old Feb 07, 2013, 05:12 PM
Ocoast is offline
Find More Posts by Ocoast
Ocoast's Avatar
United States, FL, New Port Richey
Joined Jan 2013
Battery
I went with a Turnigy 850mAh Nano-Tech from Hobby King. Weights 49 grams.
http://www.hobbyking.com/hobbyking/s...dProduct=20416
I only got a couple flights before my servo died. You have to trim the lower clamp bracket slightly to get it to fit. At $4.43, you cannot beat the price.
Ocoast is offline Find More Posts by Ocoast
Old Feb 07, 2013, 05:32 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Laidback_racer is offline
Find More Posts by Laidback_racer
Build the Weapon....
Australia, VIC, Berwick
Joined Jan 2013
Originally Posted by Pa flyer View Post
Check out the Skyartec Wasp X3V fbl. I really like mine and everybody that has one seems to like it also. It's a lot of helicopter for the money.
The Skyartec certainly does look good value for money, $150 with Tx is very reasonable. How do you find the 3 axis gyro, how different is it to flying the 9116? I am attracted to the Walkera 6 axis gyro because it comes close to a 4 ch setup, if you get disorientated you can let go of the sticks and have time to recover.
Laidback_racer is offline Find More Posts by Laidback_racer
Old Feb 07, 2013, 05:39 PM
Joined Jan 2013
Originally Posted by Steve_ View Post
It will get going super fast, and it does take a while to stop, but it
turns better than I thought it would. Of course to get it to turn you
need aileron as well as rudder input, to throw it into a bank,
Then you increase throttle and "pull" it around, exiting the turn
at warp speed. The first time I did it, I was so happy it brought
a tear to my eye.
Do you also give it some back ELEV through the turn?
Old Feb 07, 2013, 05:45 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Feb 07, 2013, 05:48 PM
Joined Jan 2013
Yup. I think so anyway. I don't really pay attention to where the sticks
are, I am so intent on watching the heli.
Back elev, hard aileron, slight rudder, and a throttle
increase if I remember correctly.
More back ELEV might pull you though the turn when you are at full tilt. Works on the sim
Old Feb 07, 2013, 05:58 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
Originally Posted by aphex4000 View Post
Steve_ & Balr14, your responses read like Jedi words of wisdom! Hilarious, and very true. Going the quad route sounds a bit more attractive to me than transitioning directly to a CP. Time to go figure out which quad!
lalalala, ask me
got more quads than helis already....
As this is not the right thread - PM.
-mike-
Edit:
Originally Posted by Balr14 View Post
My preferred path is an MQx to an MCPx to whatever your heart desires. It's not the cheapest path, but it's the path of least resistance, at least in the USA. Outside of the USA, Walkera or WL toys have similar paths, although a bit more rocky.
MQX +1 - it teaches you the right habits as it doesn't autolvel like the clone series.
mikefromgermany is offline Find More Posts by mikefromgermany
Old Feb 07, 2013, 05:59 PM
Pa flyer is offline
Find More Posts by Pa flyer
Joined Aug 2012
It will hover as well as or better than a stock 9116, but the difference in flying the two is like night and day.
If you let go of the stick on the Wasp it will continue in the direction of the last cyclic input. It doesn't self-level like the 9116 at all. If my understanding is correct all helis with 3 axis gyros behave this way.
Pa flyer is offline Find More Posts by Pa flyer
Old Feb 07, 2013, 06:10 PM
Joined Jan 2013
This is the advantage of the 6 axis, they say it is not too different to a 45deg flybar 4 ch without the pendulum effect and is very good in the wind. We will see, but it is available on Genius cp, V120D02s, Master cp, V450D03 and maybe a few others. I like the V120D02S option for durability, size and performance. Can fly indoors and very good outdoors.
Old Feb 07, 2013, 06:47 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Feb 07, 2013, 07:10 PM
JMCarlson is offline
Find More Posts by JMCarlson
Jeff Carlson
St. Paul, Minnesota
Joined Apr 2008
Questions for Steve..............
1. How long can I expect my stock motor/brushes to last
2. When the brushes finally do go, is it an absolute that it will fry the PCB
3. I've only been hovering/flying in the house (small area) Prehaps I should just trick it out, and put it on the shelf until spring when I can fly outside. (better cooling)
Jeff
JMCarlson is offline Find More Posts by JMCarlson
Old Feb 07, 2013, 07:24 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
