Old Nov 19, 2012, 01:45 PM
ttucker is offline
Find More Posts by ttucker
FPV Pilot
ttucker's Avatar
United States, OR, Beaverton
Joined Mar 2008
New FPV Plane Recovery Method Needed
I've been seeing some cool places to fly my FPV FunJet lately, but many don't have a suitable landing area, like a grass strip which is ideal for a FunJet. This led me to start thinking of alternative methods for recovering an FPV plane outside of a normal belly down landing. I've seen some techniques used by the military like flying into a large net or using an arresting hook to catch a horizontal bungee cord up in the air 10 to 15 ft. Neither are ideal for me. But it would be cool so pull up somewhere, throw the FunJet up for some quick flights and then recover the FJ from flight without a landing strip, throw everything back into the car. Obviously a heli or quad would be good (I used to fly helis for years) for this application but want to stay with the FunJet platform. Anyone thought of this or have similar ideas? I guess I need an FPV Osprey
ttucker is offline Find More Posts by ttucker
Old Nov 19, 2012, 02:26 PM
aaronredbaron is offline
Find More Posts by aaronredbaron
Spektrum Dev Team
aaronredbaron's Avatar
United States, IL, Champaign
Joined Apr 2002
Hey Tom, you could try to build a Skyhook type of system like our buddies in the Gorge use...
Scan Eagle Landing (0 min 38 sec)
Basically just a hook on the wingtip, this design does rely on the sweep of the wing to make the rope slide to the wingtip for capture, so I don't know about your FJ, but it might work great on a Zephyr or similar...
aaronredbaron is offline Find More Posts by aaronredbaron
Old Nov 19, 2012, 03:45 PM
Snaydher is offline
Find More Posts by Snaydher
Goi‚nia - Brasil
Joined Jan 2009
I have the same problem here, my family have a farm in the mountains, very nice place, but each landing is a broken and unbalanced plane
Snaydher is offline Find More Posts by Snaydher
Old Nov 19, 2012, 07:40 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
What's wrong with a net? Something like a badminton net would be light and easy to transport, but large enough to fly the plane into. Keep the poles loose so the net catches the plane instead of the plane bouncing off.
I have a friend who flew at night and used christmas light nets to land.
ashdec87 is offline Find More Posts by ashdec87
Old Nov 19, 2012, 08:39 PM
ttucker is offline
FPV Pilot
ttucker's Avatar
Joined Mar 2008
Yea, the net idea is simple to try out. I guess there wouldn't be much chance of damage to the plane or external camera.
This is probably the least risky to try out. I've never tried finding a badminton net in the winter in the NW. That might be a challenge.
Old Nov 19, 2012, 08:40 PM
ttucker is offline
FPV Pilot
ttucker's Avatar
Joined Mar 2008
http://www.youtube.com/watch?v=w88uC...ed&safe=active
Hi Arron, if I go with an arrester hook concept I might try a small light hook that drops from the bottom of the plane? Would need all my fly skills to catch the arrester cord. Actually I don't know why those guys in Iraq don't have a nice long runway with all that desert. Probably issue for security.
Old Nov 19, 2012, 08:43 PM
ttucker is offline
FPV Pilot
ttucker's Avatar
Joined Mar 2008
You mean he used the light nets to trace out the landing space at night or he actually flew into it like a bird into a net?
Old Nov 19, 2012, 08:58 PM
benderfly is online now
Find More Posts by benderfly
benderfly's Avatar
Joined Sep 2007
parachute.
benderfly is online now Find More Posts by benderfly
Old Nov 19, 2012, 09:38 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
He flew it directly into the light net and used that to stop the plane. More expensive solution. You could also rig up a tarp if you cant find a badminton net.
Old Nov 20, 2012, 09:32 AM
omer921 is offline
Find More Posts by omer921
The trees are my hangar
omer921's Avatar
United States, NY, Queens County
Joined Dec 2010
Originally Posted by benderfly View Post
parachute.
I agree, parachute is also an option,
Flite Test - Parachute Plane - PROJECT (6 min 27 sec)
omer921 is offline Find More Posts by omer921
Old Nov 20, 2012, 12:52 PM
ttucker is offline
FPV Pilot
ttucker's Avatar
Joined Mar 2008
Originally Posted by omer921 View Post
I agree, parachute is also an option, http://www.youtube.com/watch?v=LOkfBGgrXoY
Yea, that works really well and simple release mechanism. I'd want to put inside my FJ and deploy through a hatch of some sort, I'll need to look at that. The only draw back would be controlling where everything is going to come down, hopefully not water or a tree top. If I had a wide open space for the drop then I could just as easily land normally, but still great idea.
Old Nov 20, 2012, 12:58 PM
LowlyElevated is online now
Find More Posts by LowlyElevated
Because I was INVERTED
LowlyElevated's Avatar
United States, FL, DeLand
Joined Sep 2012
You give it thrust vectoring, and then you do a line-of-sight harrier landing.
LowlyElevated is online now Find More Posts by LowlyElevated
Old Nov 20, 2012, 08:49 PM
omer921 is offline
omer921's Avatar
Joined Dec 2010
What you could do is check for wind direction, and if you dont make the parachute that big the rate of descent can give a an accurate estimation on the touchdown point and not deviate from from the point you deployed the chute. If the FJ is sturdy enough you won't damage it if it hits the ground with a bit of momentum.
Cool New Shipping Method: The Best Method Ever boredom.is.me Trader Talk 10 Jul 27, 2012 11:21 PM
Discussion Stalling a 2m full house glider, best recovery methods? SoarWest Electric Sailplanes 31 Jul 26, 2012 03:07 PM
Question Protecting paint job on a foam plane? Best methods? w1indse7 The Builders Workshop 8 Mar 13, 2012 04:46 PM
Discussion New recovery method TonyF Rocketry 3 Jan 05, 2010 12:17 AM
New method for 3D plane connect, Look my DIY 3D plane. UNIX 3D / Fun Fly Fuel Planes 4 Aug 20, 2004 10:19 AM
