Old Nov 19, 2012, 01:36 PM
Daytonarc is offline
Find More Posts by Daytonarc
United States, FL, Daytona Beach
Joined Sep 2012
Ultracoat vs Monocoat
I have built and repaired planes using Ultracoat and am pretty good at achieving a nice finished product. I will be using Monocoat for the first time on a project due to availability of what I need locally. What if any differences are there in the products, how they apply, shring etc?
Daytonarc is offline Find More Posts by Daytonarc
Old Nov 19, 2012, 01:56 PM
kimchiyuk is offline
Find More Posts by kimchiyuk
kimchiyuk's Avatar
United States, NY, Barryville
Joined Jun 2012
I am completely opposite. Just covered my first plane in monokote, next build going to do in ultracoat. I can't give you a comparison, but I personally did not find monokote difficult to work with. I was very pleased with my results. It easily shrank down drum tight with only a sealing iron. I do have a heat gun but didn't need it. I have 16 flights on the plane I covered and I clean it with paper towels and windex after each flight. It looks the same as when new. None of the edges are coming up...seems very durable. I had no problems stretching around corners etc. Most people I ask say monokote has changed over the years and don't like it. I'm going to use ultracoat next just for my own comparison. Also, there are many threads on this topic if you do a search.. Hope this helps.
kimchiyuk is offline Find More Posts by kimchiyuk
Old Nov 20, 2012, 09:15 AM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
I've done both. Started with Monocoat when it first came out. Much faster than doing a silk job on the old control liners. When I tried ultracoat I switched for good and never looked back. I find it goes around compound curves better, shrinks better, and just gives me better control. I've burned a hole in monocoat trying to get that last little wrinkle out. Here in central Texas there is no covering that will not wrinkle in the hot sun. General maintenance is to reshrink the covering every now and then. Over the years of doing that, monocoat reaches its limit before ultracoat does. I just wish UC didnt cost so much.
Edwin
edwin1 is offline Find More Posts by edwin1
Old Nov 21, 2012, 12:02 PM
UberZogster is offline
Find More Posts by UberZogster
Be the duck. Whaaaa?
UberZogster's Avatar
United States, CA, Guerneville
Joined Mar 2012
Everyone I talk to says that ultra is the way to go. I have only covered one plane and I used mono. I didn't have any problems with wrinkles or corners. Everyone in my club says that once you go ultra you don't go back.
UberZogster is offline Find More Posts by UberZogster
Old Nov 21, 2012, 12:34 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot, 100 yrs too late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
I have used mono for many years and everyone states they changed fhe "formula" or what have you. I have used Ultra for the last few years b/c mono is much thicker.. harder to apply, especially around compound curves and is much more difficult to get wrinkles out. Stay away from it if you can.
I like you needed a color and didnt want to wait and bought a role of mono again. My old fears soon were affirmed but but with much much much much much (i would keep going but you get the idea) patience and care... a good finish is possible. A very good finish with Ultra is more easily acheived without the experience required.
Thermalin is offline Find More Posts by Thermalin
Old Nov 21, 2012, 03:18 PM
ChrisS is offline
Find More Posts by ChrisS
Really?!?
ChrisS's Avatar
Lost ...on the 3rd rock out
Joined Sep 2001
I have used both for years. No doubt about it UltraCote is stronger and shrinks further. And it resists heat blow through much better.
That said, MonoCote is lighter, cheaper and requires a bit more skill to work with. I may be wrong about this, but I think there are more color choices in MonoCote as well. There is also a small amount of off the shelf paint (LusterCote) available to match some of the basic MonoCote colors, which can be a Godsend when you need to finish a canopy and pants as well.
Chris
ChrisS is offline Find More Posts by ChrisS
Old Nov 26, 2012, 11:19 PM
Crowfly is offline
Find More Posts by Crowfly
Crowfly's Avatar
United States, MO, Belton
In my opinion Ultracoat is way easier to work with,and I can't tell a whole lot of difference in color. Monocoat,some colors are pretty forgiving while others are a real pain. Like flourecent (which I don't think Ultracoat has).
But I quit buying Monocoat 3 or 4 years ago...
Fred
Crowfly is offline Find More Posts by Crowfly
Old Nov 27, 2012, 11:21 AM
machinate is offline
Find More Posts by machinate
machinate's Avatar
Joined Jan 2010
Old Monokote is pretty easy to work with, if you can dig up a 30-year old roll in grandpa's basement or whatever. The newer stuff is just awful - it barely shrinks at all, compared to Ultrakote or other options.
For small-to-midsize electrics I really like Solarfilm or Solite/Coverite Microlite. Those things shrink like mad and weigh almost nothing. Solarfilm also has some great color choices.
For larger planes or those which need to be fuelproof, I'd use Ultracote for sure. It's marginally heavier than Monokote and even though it shrinks more, I don't think it shrinks quite as tight. But it's way easier to work with.
machinate is offline Find More Posts by machinate
Old Nov 28, 2012, 01:39 AM
ChrisS is offline
Really?!?
ChrisS's Avatar
Joined Sep 2001
I prefer working with Ultracote when I have the chance, and I think my favorite color of all is the Ultracote "signal green" which is a neon yellow you can see from orbit. I bet I have put that at least partially on 20 planes. The metallic colors in Monocote are good too, deep/vibrant colors. Never put both on the same project, you can end up with a big mess.
I don't think I will ever again build a model that has to be covered in the solite stuff. I have nothing but bad luck with it, it sticks to itself with nothing more than body heat, blows through with a fart and is not opaque at all. I suppose you can paint it, but that's not what I want in a plastic/shrink film covering.
My $.02
Chris
Old Dec 02, 2012, 11:50 AM
No Step is offline
Find More Posts by No Step
My hangar is,... "almost" full
No Step's Avatar
United States, WA, Marysville
Joined May 2003
Ultracoat guy here. I stopped using Monokote years ago. I tried MK again recently purely for color choice (transparent green),... did not like working with it at all. MK does not shrink well for me. Some people still like MK. I guess the trick to getting a good MK application is to have it as tight as possible, w/o any wrinkles >before< any shrinking is done. I like perfect cover jobs. Some people are content with leaving a few wrinkles here and there on the finished model. Not an option for me. So I use Ultracoat, much easier to apply, shrinks better, easy to remove if needed. Having said that, I do like Monokotes' transparent colors way better than Ultracoats'. But it's not worth the frustration of applying Monokote. Everyone has a different opinion, but I bet you see more people happier with Ultracoat than Monokote.
Fred
https://home.comcast.net/~guilfoyle72/
No Step is offline Find More Posts by No Step
Old Feb 05, 2013, 11:11 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
Fred
have a buddy trying to cover his balsa electric glider with ultracoat and says he cant get it to stick. any tips on what he is doing wrong,using an iron to put it on.
fastfwd is offline Find More Posts by fastfwd
Old Feb 06, 2013, 02:42 AM
wizard of odd is offline
Find More Posts by wizard of odd
wizard of odd's Avatar
Australia, VIC, Sale
Joined Apr 2011
Ultracoat sticks really well, and at low temperatures, once you manage to get the fandangled backing off it!
Anyways, I too have found Ultra a lot easier to apply than MK, especially around compound curves. You can do it with MK, but it takes a lot more heat and tugging to get it just right.
Now let me throw the proverbial spanner in the works:
Ultra and MK are pretty expensive, so I started experimenting with the Hobby King covering- thinking that if it were rubbish, at least it would not be an expensive mistake. This stuff is cheap as chips, comes in a fair range of colours and applies as easy as Ultracoat (even around compound curves), and at very similar temperatures. Being pretty impressed at the ease of application, I thought it would sag to hell in our Australian summer temperatures (where I live up to 48 deg Celsius/118 Fahrenheit in summer). After 9 months, I've not needed to do a tightening job yet. I now own around 70m of the stuff in various colours....
PS: The backing on the Hobby King covering, like Ultracoat, is an unadultered PITA to remove
wizard of odd is offline Find More Posts by wizard of odd
Old Feb 06, 2013, 08:13 AM
fastfwd is offline
Joined Mar 2012
backing ?? LOL oh backing !
Old Feb 06, 2013, 08:46 AM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
+1 for Ultracote over Monocote. I switched YEARS ago as my Monocote would shatter after a year... Not so with Ultracote
Something I didn't see mentioned is to READ the directions. Ultracote's glue will set at a lower temperature than when it starts to shrink. If I remember correctly the amount of shrink is linear to the temperature (with in the range).
When I first started using Ultracote, I tried to apply it like Monocoate, and hated it....then I read the directions. I do keep two irons going. One set to the temperature where the glue sets, and the other for some shrinkage; adjust for how much shrink I am after.
rcav8r2 is offline Find More Posts by rcav8r2
Old Feb 06, 2013, 09:22 AM
No Step is offline
No Step's Avatar
Joined May 2003
Fastfwd,... I assume failure to remove the backing was your trouble, and all is well now.
I've never thought Ultracoat backing was difficult to peel off at all...... The backing on Solite a real bugger to peel off. I guess the trick with it is to use a bit of scotch tape to help pull it away. That might work good for anyone having trouble on Ultracoat blacking.
Fred
Wanted rolls of monocoat or ultracoat FIXXIN2FLY Aircraft - General - Miscellaneous (FS/W) 0 Sep 11, 2009 07:19 PM
UltraCoat vs. MonoKote vs. Econocoat ??? Gromer Slope 15 Sep 25, 2005 11:42 AM
Wing Covering: Black Baron vs. Ultracoat vs. ...? infopimp Slope 6 May 30, 2005 02:29 PM
Ultracoat/Monocoat together?? Rob Nelson Thermal 6 Mar 25, 2003 06:26 PM
Paint vs ultracoat? Russell2 Electric Plane Talk 2 Sep 20, 2002 07:43 AM
