Old Nov 19, 2012, 02:19 PM
Benovitch is offline
Find More Posts by Benovitch
BelgiŽ, Vlaams Gewest, Temse
Joined Dec 2004
Minimosd
Hi,
Iím looking to get myself an Arduino APM 2.5 and the MinimOSD. Is it possible to configures the OSD trough the usb port of the APM? Or do I need a separate cable to do it.
Ben
Benovitch is offline Find More Posts by Benovitch
Old Nov 19, 2012, 02:43 PM
saeli is offline
Find More Posts by saeli
Joined Jan 2006
I think it's only possible with an ftdi cable
saeli is offline Find More Posts by saeli
Old Nov 19, 2012, 04:34 PM
Rogue.insight is offline
Find More Posts by Rogue.insight
Joined Jun 2012
That is correct. You need the connection directly from the MinimOSD to the computer to configure it. The serial connection between the APM and MinimOSD can only be used for flight data.
I found out last night that you can use an FTDI to the serial pins of the APM to connect to a computer. This was convenient b/c the usb port on my APM was covered. So I used this as a backup method to get connected to my computer.
Rogue.insight is offline Find More Posts by Rogue.insight
Old Nov 19, 2012, 09:55 PM
saeli is offline
Joined Jan 2006
Can you post more info?
Old Nov 19, 2012, 11:51 PM
typicalaimster is offline
Find More Posts by typicalaimster
typicalaimster's Avatar
United States, CA, San Diego
Joined Jan 2005
Correct since this is how you connect to the wireless telemetry. If you get the radio modems either off RCTimer or 3dr you can do almost everything but update the firmware.
typicalaimster is offline Find More Posts by typicalaimster
Old Nov 20, 2012, 07:50 PM
Joined Jun 2012
It's simply a matter of connecting the pins on the USB ftdi device to the telem pins on the apm. Since these pins are on top it was easier to get to than the USB port on the side.
Sold Complete New Kit! - ArduPilot Mega v2.4.1 with MinimOSD and ArduStation aviatorgeek FPV Equipment (FS/W) 8 Oct 08, 2012 02:11 PM
Sold Ardupilot Mega 2560/GPS/Mag/Sonar/MinimOSD/Case ppridday Aircraft - Electric - Multirotor (FS/W) 3 Sep 14, 2012 04:24 PM
For Sale ArduCopter APM2 + MinimOSD p0st4L Aircraft - Electric - Multirotor (FS/W) 3 Aug 30, 2012 09:08 PM
Discussion HoryzonHD v2 and MinimOSD Oso M FPV Talk 1 Aug 17, 2012 05:04 AM
Discussion MinimOSD on ground station. King_Ice_Flash FPV Talk 3 May 15, 2012 09:03 PM
