Old Nov 19, 2012, 11:36 AM
KentF is offline
Find More Posts by KentF
FunkMaster
KentF's Avatar
United States, OH, Mason
Joined Jan 2011
Help!
Bouncing Text on OSD
I'm having an issue with all of the text coming from the OSD. When the ESC has the motor running, the text on my screen bounces up/down to the point where I can't read it. The video coming from the camera is fine and stable but not the text. At very low RPM it is very slight but as I increase the throttle, the bouncing gets worse. The strange thing is that at above 90% throttle (or so) the text stabilizes to almost normal although there is still some slight jumping.
I use the balance port on one of my batteries to power the video. I use a CC 10amp BEC to supply power to the electronics and I bypass the BEC supplied by the ESC.
Thoughts on what I can do about this would be greatly appreciated.
Kent
KentF is offline Find More Posts by KentF
Old Nov 19, 2012, 07:53 PM
KentF is offline
FunkMaster
KentF's Avatar
Joined Jan 2011
Here is a video of the jumping text
IMG 0565 (0 min 32 sec)
Old Nov 20, 2012, 03:07 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi Kent,
Sorry for the jumping text issue.
We get occasional reports of this. I think they have all been solved by improving the ground connection between the camera, the OSD, and the video transmitter. Can you confirm how you have those wired? There needs to be a ground connection that goes directly to all 3 of them (the ground pins of the OSD are all connected together).
billpa is offline Find More Posts by billpa
Site Sponsor
Old Nov 20, 2012, 09:21 PM
KentF is offline
FunkMaster
KentF's Avatar
Joined Jan 2011
Originally Posted by billpa View Post
Hi Kent,
Bill....you da man!!
I didn't have a ground wire going to the OSD video IN. I added that ground and no more jitters.
Thanks for the assistance.
Kent
Discussion Dragon OSD Flickering text problems whitehawk80 FPV Talk 0 Jun 29, 2012 05:03 PM
Poll Do you think the text size on the DX18s larger screen should be smaller than the DX8? Victory Pete Radios 321 Jun 08, 2012 04:05 PM
Discussion Blackstork OSD - Left & Right text cutted jacky65 FPV Talk 30 Mar 20, 2009 12:06 PM
Discussion OSD customized text with progammable frequency! Canada Goose Aerial Photography 5 May 09, 2006 08:00 AM
