| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
Look! Up in the sky!
Where do I start?
Planes:
GWS Slowstick, SoarStar, and Wingo are the most commonly used planes for AP. For the SlowStick, you can get by with the stock 300 motor, but it won't last very long if you run it hard with 8 cells. A better bet is to upgrade to a speed 400 motor with an F or G gearbox, or a brushless motor. You can buy the S400 and gearbox here: http://www.allerc.com/EPS400C.htm Best bang for your buck has to be the Slow Stick. $35 and needs very little modification. Can haul cameras up to 5 or 6 oz, although 3 ounces is a reasonable limit without a brushless motor and reinforced wings. Cameras Aiptek mini pencam (1.3 Mega) Aiptek SD (1.3 Mega) accepts SD memory cards Mustek GSmart mini3 is 2 megapixels Pentax Optio S4 - 4 megapixel cam Nikon 3700 - great for stills or smooth video Check this thread for more about cams: Great cams for aerial photog Usually folks start off by fashioning a camera mount that allows the shutter to be pressed by a mini servo. Some simply glue a servo to the camera body. A better and increasingly common solution is an electronic switch that is soldered into the camera and plugged into the receiver. The Aiptek and Mustek can be fairly easily adapted to an electronic switch. Check these threads: Prism RC-CAM's switch Michele switch Switch by Smokey Rotor (no longer available Wild Moose's SMT Backpack switch) The Optio S4 can be triggered using an IR switch made by MX. Camera mounting options: Check these threads... Aiptek SD mount Optio S4 mount Mustek mini3 mount This is a fresh start on THIS THREAD. Last edited by RMihara; May 18, 2006 at 07:15 PM. |
#2 |
Aerial Shutterbug
Hi Steve,
Please add the following to the Aipteks Stats on your 'Great Cams' thread... Mini 1.3 Dimensions: 1.3" x 1.22" x 3.54" Image Capacity: 1248x960- up to 50 pictures 640x480- up to 160 pictures Recycle time (time between shots): approximately 2-3 seconds. SD Dimensions: 3.9" x 1.7" x 1.4" Image Capacity: 1280x1024 - up to 10 pictures with built-in 8 MB memory 640x480 - up to 40 pictures with built-in 8 MB memory 200-300 with a 128 MB SD disk. Recycle time (time between shots): approximately 0.5 seconds. Regards, Roger |
#3 |
Difference between the Aiptek mini pencam and the pencam mega?
http://www.rcgroups.com/forums/showt...hreadid=179106 Last edited by Steve Nolan (eBird); Dec 15, 2003 at 11:55 PM. |
#4 |
Should the camera be mounted away from the motor?
Will the motor mess up the signal? |
#5 |
That sickening crunch..
No, but the motor must be off when you take pictures (or severe image distortion will show up in your pictures)..
..a |
#6 | |
RCAirborne
-Dujara- |
#7 |
Gustavo Exel
Camera memory
Make sure you get a camera with lots of memory, or at least one that takes memory cards so you can buy a larger card later.
It's very frustrating to be limited to 20 or 30 pics per sortie, as even the pros here admit that the secret behind AP is to take lots of pics and sort out the better ones. Try to get enough memory to be able to hold at least 100 pics, and, obviously, use it! Take lots of pics... shoot several times aiming at each of your subjects to increase the chance of getting a really good pic of each one. Gustavo |
#8 |
Thanks Dad!
Mods?
#9 |
Is anyone using gas power for AP or is there just too much vibration? What acft models work best? Mounting systems?
#10 |
OK guys, I headed over to my LHS (Aeromicro) to get a Lite Stick. I am having trouble finding the mods for it on here though. Is it under foamies, AP, Park Fliers, or which?
Also, has anyone tried those pinhole video cams off ebay? Any good? |
#11 | |
SIU Aviation
#12 |
3D Flyer
How do I adjust the resolution on the camera it self i am running 1280x1024 because i can get 10 pictures on the built in memory. i was flying the cammera on my 3d foamy but the battery I was running was light so the weigt didn't bother me sincei run a 4 oz lithium anyway 3s 2p but my apl battey went out after just a could flights no big thing because we build are own batteries. but I can't get another cell to go with the other. Long story short I can't get another cell to fix the bad one. The small batt. was used for ap but lost the light one. So i ahve to use the 3s 2p batts. used for 3d. anyway the plane is to heavy now. So my main questions are how do change the resolution on the camera and How would you like to possibly see som beach pics of my possibly new Ap plane.
#13 |
Hey E-Bird, what prop would I use with that GWS speed 400 setup you mentioned? The stock one that comes with the 300 motor?
#14 |
Newflyer - depends on which gearbox you get. The "G" is 4.5:1, so an 11x8 would work fine. The "H" box will need a little larger prop, a 12 or 13".
#15 |
Shrug...
Steve--
With a GWS 400 and a "G" (4.5:1) box and 7-cell KANs, a GWS slowflyer prop 12x6 pulls 9A. and gives 11 oz thrust and a 13x6.5 prop pulls 11A. and gives 13 oz of thrust (all values measured and static). The higher current of the 13x6.5 prop is a tad over the recommended limit, but having extra thrust at takeoff is helpful and you can throttle back for cruising. The static "half throttle" current draw is about 2.5A. for either prop. "YMMV", but this is what my SS does. --Bill Last edited by Bill Harris; Jun 09, 2004 at 08:40 AM. Reason: corrected a number |
| Thread Tools | |
| Where do I start? (archive) | Ian Easton | Aerial Photography | 42 | Dec 08, 2003 11:17 AM |
| OK, Brushless SS where do I start? | Newberry | Parkflyers | 9 | Sep 03, 2003 07:16 AM |
| No really, where do I start? | Basil | Aerial Photography | 1 | Mar 05, 2003 10:24 PM |
| I want to build a foem body for my Ikarus Piccolo Heli but where do i start | Pablito | Foamies (Kits) | 1 | May 08, 2002 04:20 AM |
| Where do I start???? | danman | Parkflyers | 8 | Apr 30, 2002 01:45 PM |
