Old Nov 19, 2012, 11:20 AM
Ny-RC-Flyboy76 is offline
Find More Posts by Ny-RC-Flyboy76
Ny-RC-Flyboy76's Avatar
United States, NY, Cortland
Joined Mar 2009
Question
Rimfire 65cc problem
I have flown this set up for a little while
aeroworks 50cc ultimate
18lb with everything
Rimfire 65cc
cc160hv
3 blade biela 24x12
2 6s 5000mah
Ok now for the problem I bought a mejzlik 24x12 3 blade prop thinking I would get more out of a thinner blade !! Well I run the plane up and at 60% throttle it shuts off will not spool at 100 % I look at the data and it shows 9000 and 9500 rpm so I am guessing it is over spinning !! can I resolve this or should I look for a different prop any ideas or suggestions would help ! ps the 3 blade is for ground clearance had a 26x 13 2 blade to test had ground strike !
Ny-RC-Flyboy76 is offline Find More Posts by Ny-RC-Flyboy76
Old Nov 19, 2012, 12:39 PM
Doug Bartley is offline
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
You may want have another look at your data. 12s is about 44v under load, that x motor kv = 7040rpm. In fact my 6s x2 show 42v. If your using a tach, is it set for a 3 blade prop?
Two things to watch for here, the extra weight of the cf 3 blade could be loading the esc beyond it capacity. The other is the throttle endpoints, I don't rely on the auto set features, I use the set endpoints to ensure 100% travel thru the Tx throttle range.
Use a know n wattmeter to verify whats happening. A 24/12/3 blade may be beyond esc and motors capability. fwiw Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Nov 19, 2012, 01:09 PM
frank26all is offline
Find More Posts by frank26all
helicrazy
frank26all's Avatar
United States, AL, Robertsdale
Joined Nov 2009
I just completed a 50cc pitts using a suppo 5345/8 motor,castle 160hv castle 20a pro bec and a biella 20x10 3 bladed prop with awsome results on 12s. I guess it could be prop issues but im not a pro on these matters.
Brushless 50cc pitts (1 min 9 sec)
This is my setup
frank26all is offline Find More Posts by frank26all
Old Nov 19, 2012, 06:13 PM
Joined Mar 2009
the data I got was from the esc datalog I have run and flown it with a 24x12 3 blade these pics are from the neat fair this year I flew 10 or so flights . The problem came when I switched props same size just went from biela to mejzlic same size ! just trying to figure out the problem !! I put the biela prop back on and spun it up todat it ran fine and pulled well didnt fly but static test !!
Discussion ESM Fw-190 D9 65cc rimfire kahloq Glow to Electric Conversions 66 Apr 01, 2013 05:16 PM
Wanted Rimfire 65cc electric motor JBAZ4 Aircraft - Electric - Power Systems (FS/W) 0 Aug 22, 2012 04:50 PM
Discussion Rimfire 65cc, CC160 ans 12S 10000, is this a good 35% powerplant? meloni Giant Electric Planes 3 Aug 12, 2012 11:48 PM
Found rimfire 65cc or equivalent motor kremecheze Aircraft - Electric - Power Systems (FS/W) 0 Apr 09, 2012 09:11 PM
Question rimfire 65cc airshipguy Power Systems 10 Mar 27, 2012 01:44 PM
