Old Dec 09, 2003, 11:26 PM
Foamphobic
doublesixes's Avatar
Laguna Beach, Ca
Joined Dec 2003
Help with Electrifly C-20 ESC
I got an Electrify C-20 ESC. I'm planning on using it on my Slow Stick. Could that ESC be used with a Kokam 2 cell 1500 Mah Lithium poly pack?
Thanks in advance
doublesixes is offline Find More Posts by doublesixes
Old Dec 09, 2003, 11:39 PM
MooseFlyR's Avatar
Slingerlands, NY
Joined Feb 2003
Yes, it will work fine. However, the LVC (low voltage cuttoff) is not set appropriately for lipolys. (many aren't) As soon as your power begins to sag, bring it down so as not to damage the cells by taking them to too low a voltage.
MooseFlyR is offline Find More Posts by MooseFlyR
Old Dec 10, 2003, 12:28 AM
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
This is good advice as the Electrifly controllers I have tested have a lower low voltage cutoff setting than most - below even 2.5V per cell for a 2s lithium pack.
So, land as soon as you feel the power sag noticeably. Do NOT wait for the LVC to tell you when to land.
BEC is offline Find More Posts by BEC
Old Dec 10, 2003, 12:41 AM
Foamphobic
Laguna Beach, Ca
Joined Dec 2003
Thanks guys! According to the specs, the lvc is set at the factory at 4.8 V. I wonder if that's to be trusted with the lipolys.
Old Dec 10, 2003, 10:44 AM
MooseFlyR's Avatar
Slingerlands, NY
Joined Feb 2003
No. Convention has it at 3V/cell. Many planes will not fly at such low voltages anyway, but a floater like the slowstick will allow pushing them too far.
Old Dec 10, 2003, 10:47 AM
Baltimore Bwi Rr Stn, Maryland, United States
Joined Oct 2003
Re: Help with Electrifly C-20 ESC
Thanks in advance
Read tis thread: http://www.rcgroups.com/forums/showt...hreadid=177435
whanderson is offline Find More Posts by whanderson
Question Can an Electrifly C-20 ESC be used with a 3c LiPo? Don H. Electric Plane Talk 0 Jun 09, 2007 06:48 PM
Electrifly C-20 ESC with more then 2 servos help rcman Power Systems 1 Dec 13, 2002 11:49 AM
FS: Great Planes Electrifly C-20 ESC NIB snoozer Aircraft - Electric - Airplanes (FS/W) 1 Sep 07, 2002 06:34 PM
Problems with my C-20 ESC please help Barrett Electric Plane Talk 2 Sep 04, 2002 11:52 AM
help with fma mini 20 esc yb2normal Power Systems 10 May 10, 2001 07:10 PM
