Old Nov 19, 2012, 09:09 AM
KenChoo is offline
Find More Posts by KenChoo
Joined Apr 2005
Rudd-Ail mix
Hi everyone, I have rud-ail mix (same dir, i.e. left rud - left ail) and during slow roll I find the roll rate speeds up in the second half because of the application of different rudder in the first vs second half...that is, rudder in first half has ail from the mix opposite to the roll direction so the roll is slower, then after that opposite rudder has ail in the same direction as the roll rate speeds up.
Any suggestions to manage that? Or is it just varying ail input?
KenChoo is offline Find More Posts by KenChoo
Old Nov 19, 2012, 03:07 PM
johncoulouris is offline
Find More Posts by johncoulouris
Ελλάδα, Δυτική Ελλάδα, Πάτρα
Joined Jun 2009
Personally, I use the stick position switch on my JR XG8 (logic switch on futaba) to turn off the mix when using very little aileron.
johncoulouris is offline Find More Posts by johncoulouris
Discussion Flying a Scale Cub/ mixing rud-ail? captscotty Scale Fuel Planes 31 Oct 15, 2012 03:19 PM
Discussion gaurdian : no more aile mix on wing nocomp Eagle Tree Systems 1 Jul 25, 2012 05:44 PM
Help! Evo 9 Dual Elev Servos-Mix w/rudd help Rishelman Radios 6 Feb 02, 2009 03:00 PM
Discussion mixing Rudd to Ail for Cam Pan JustinONE FPV Talk 5 Aug 25, 2008 10:23 AM
Question Futaba 9C Ail-Rudd mixing Problem Zevang Radios 4 Aug 09, 2004 05:04 PM
