Old Nov 19, 2012, 10:06 AM
xfatdannx is offline
Find More Posts by xfatdannx
advanced n00b
xfatdannx's Avatar
United States, NE, Omaha
Joined Feb 2012
Help!
Power 10 - Prop shaft adjusment...
Is it possible to adjust the prop shaft on the power 10? I took the collar off the back and loosened the 2 grub screws up front, but no movement. I didn't want to smack it with a hammer or something stupid until i got some further information.
The problem i am having is my prop adapter is meeting the motor's "body," if you will, before the grub screw in the prop adapter can sit in the little groove on the prop shaft. In turn when i go to take off, no matter how tight i have the grub screw on the prop adapter, the spinner is just popping off.
This picture shows a Power 15 but i could not find a power 10 pic that illustrates the groove in the prop shaft i am referring to.
Is it possible to slide the shaft a little further out (towards the nose) so my grub screw can fit in this groove and have a flat surface to press against?
xfatdannx is offline Find More Posts by xfatdannx
Old Nov 19, 2012, 11:07 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
You can't slide the shaft forward any further 'cos the shaft will pull out of the rear bearing or, at least, not have enough sticking out the back to re-fit the collar. I'd get a Dremel and widen the groove.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Nov 20, 2012, 08:55 AM
advanced n00b
xfatdannx's Avatar
Joined Feb 2012
Any other input on this? I have 2 power 10's (one in each of my PZ Mustangs) and i looked at them...The prop shaft is different on each. Is that just "how they are made" or are they in fact adjustable?
Sold Prop Savers 1.5mm Motor Shaft to 4mm Prop Bore scharlach Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 7 Jun 18, 2012 04:24 PM
Found Micro Prop Adapters 1.4/1.5mm Shaft 3mm Prop Mount ShokWaveRider Aircraft - Electric - Power Systems (FS/W) 0 Jun 09, 2012 02:26 PM
Discussion Gemfan 5x3x3s on 2mm prop shafts require aftermarket prop adapters. Link anyone? daign Multirotor Talk 0 Mar 04, 2012 12:17 AM
Discussion folding props for a 3mm shaft, and 6 to 10 in. phil alvirez Power Systems 10 Aug 01, 2007 08:24 PM
FS: 7 GWS Props 1x 9x7, 3x 10x8, 2x 10x6 HD, 1x 11x4.7 FOR GWS EPS-400C Shaft $10! Nik-rc Aircraft - Electric - Airplanes (FS/W) 5 Jun 16, 2004 12:08 PM
