Old Nov 19, 2012, 06:28 AM
Bariboy is offline
Find More Posts by Bariboy
United States, NY, Kingston
Joined Feb 2006
Start up
Anybody got a list of start up tools? Beyond the knife and sandpaper. Got some 1/4 ply I need to cut. Every one go small table saw/jig saw/hand cut? And what about sanding, by hand, belt sander etc??? Thanks. Scott
Bariboy is offline Find More Posts by Bariboy
Old Nov 19, 2012, 09:41 AM
JohnsPop is offline
Find More Posts by JohnsPop
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
You might check here Scott: http://www.rcgroups.com/forums/showthread.php?t=1752811
JohnsPop is offline Find More Posts by JohnsPop
Old Nov 20, 2012, 02:06 AM
lindart is offline
Find More Posts by lindart
Art Schmitz
United States, TN, Crossville
Joined Jan 2012
My power tools are a drill press, 18" jig saw, disc sander, cordless 3/8 drill, and a Dremel tool. A 5" vice is also handy.
Then there are several soldering irons and a propane torch.
lindart is offline Find More Posts by lindart
Old Nov 20, 2012, 06:16 AM
epoxyearl is offline
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
A 12 volt cordless drill is good,but I just replaced my worn out one with an 18 volt larger one....It's still easy to do model stuff,but it doubles for household chores also.
A band saw is never outdated,and a Ryobi is decent quality at $120.-Look for ball bearing "Guides" as a buying tool.
A jig saw is put to use around here for cutting 'inside' holes...
A dremel tool with sanding drums.
Make several sanding blocks...I fold sandpaper length wise twice,tear it,then cut blocks to fit,for shaping.
epoxyearl is offline Find More Posts by epoxyearl
Latest blog entry: AMA 'traditional' , once more ?
Old Nov 20, 2012, 08:19 AM
JohnsPop is offline
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
I use one of these a good bit too: http://www.harborfreight.com/power-t...ool-67537.html
But I build a lot of SPADs (airplanes built out of plastic downspout and corrugated plastic sign material) so I have a lot of big cuts. These oscillate instead of turn like a dremel so they don't throw up NEAR the dust a dremel does, but I couldn't live without my dremel. That's probably my #2 tool right behind my #11 xacto.
Earl, my 18V drill is big and clumsy for most of my model work. When the battery crapped out early on my 9.6V smaller drill, I made a pack out of those 2200mah LSD NiMH batteries. Brought the wiring out the side of the drill and put a Dean's connector in there. Now I just charge it on one of my airplane chargers and that has worked really well so far for me. I found another cheapy drill in my shop with no charger and I'm going to convert it too.
Old Nov 20, 2012, 08:20 AM
JohnsPop is offline
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
Oh yeah, they have a cordless model of that multifunction tool at Harbor Freight too.
Old Nov 20, 2012, 08:45 AM
epoxyearl's Avatar
Joined Oct 2011
Doggone it,John'spop, that's a good idea-you could put the battery in a belt hangar,if it needed to move around with you.
Good idea.
Old Nov 20, 2012, 05:11 PM
JohnsPop is offline
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
No it's self contained. I just soldered the batteries together and let the wire with charging connector hang outside. I did that because it I wasn't sure the charger that came with the drill would charge the batteries correctly without overloading them, so I just put the Dean's on there so I could charge it with my Accucell 6 charger. The batteries are the 2200 mah "low self discharge" type and last a surprisingly long time. I don't use it for driving screws or anything, mostly just drilling holes and it's plenty strong but much lighter than my 18V cordless. Oh yeah...... I use HO scale model railroad nickle silver track joiners as the jumpers for my battery packs. They take solder well are easy to hold in place with flux.
Old Nov 21, 2012, 08:41 AM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
A balsawood building board -
http://www3.towerhobbies.com/cgi-bin...?&I=LXVZ62&P=7
http://www.guillow.com/workboards.aspx
Though they are getting hard to get. I have the Guillows boards in 36" and 48" and dread them ever wearing out and not being able to replace them. As well as building 'flat' on them, I've hinged them to build dihedralled wings in one piece, starting from the dihedral braces in the centre.
Pins! Not very romantic, but unless you want to spend a staggering amount on a magnetic building system (I do, but I'm inherently very tight-fisted!), no-one's come up with a better way to hold balsa structures onto a building board.
http://www.guillow.com/100packoft-pins.aspx
D
Dereck is offline Find More Posts by Dereck
Question Turnigy TY-P1 25Amp HEXFET Start up totpic Power Systems 2 Jan 18, 2014 06:25 AM
Question EZ-Peak Plus fan noise @ start up Chairplane Batteries and Chargers 5 Mar 20, 2012 03:10 AM
Discussion It's starting to warm up ... but still ... drive safe everyone logan5 Life, The Universe, and Politics 6 Mar 08, 2012 02:40 PM
Discussion ESC start-up tones out of sync nathasm Multirotor Talk 4 Mar 05, 2012 10:30 PM
Discussion Main blade adjustment on Walkera V400D02 after start-up? MarathonRock Beginner Training Area (Heli-Electric) 4 Feb 24, 2012 09:58 AM
