Old Nov 19, 2012, 05:03 AM
ror is offline
ror
Find More Posts by ror
ror
France, Languedoc-Roussillon, Thuir
Joined Aug 2009
carbone rod
Hi,
I'm building a RC peanut. I'd like to know what diameter of carbon rod I have to use: 0,3 mm, 0,5mm, 0,8 mm ?
ror is offline Find More Posts by ror
Old Nov 19, 2012, 07:16 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
That will sort of depend on what you intend to use the carbon rod for and what the design is like. Just "peanut" says very little.
Steve
slipstick is offline Find More Posts by slipstick
Old Nov 19, 2012, 08:34 AM
ror is offline
ror
ror
Joined Aug 2009
Yes, off course, I didn indicate what was the use ! It's for doing linkage for rudder and elevator so approximatively 15 cm. Do I have to make some guide in the fuselage ?
Old Nov 20, 2012, 01:02 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
.030" rod makes good pushrods in combination with .8mm Heat shrink tubing and .020" music wire for for the Z-bends.
15cm would be OK for a pushrod, but putting something at the mid length of the pushrod can help reduce bowing during operation.
I have used a small piece of coffee stir straw or plastic tubing (1mm to 2mm long) fastened to the fuselage at the midpoint of the rod to keep the pushrod straight under compression.
UNGN is offline Find More Posts by UNGN
Old Nov 21, 2012, 06:41 AM
ror is offline
ror
ror
Joined Aug 2009
OK thanks, but don't you think it could be possible to use 0,5 mm carbone rod instead of ? and for Z bend, I thought 0,3 mm music wire or copper wire from a brushless motor ?
Old Nov 21, 2012, 06:51 AM
acheyj is offline
Find More Posts by acheyj
Joined Mar 2012
Where the heck can I get .8mm Heat shrink, been looking every where all I can get is 1.5mm ?
ron
acheyj is offline Find More Posts by acheyj
Old Nov 21, 2012, 09:02 AM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
ron
The best place is "dealextreme.com" Shipping takes a while but it is very cheap.
Old Nov 21, 2012, 09:08 AM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
.020" CF rod is a little too flexible, unless you are doing a 20g plane. You'll need multiple eyelets to reduce flex.
.015" music wire works at the servos (if you use HH linears), but is too small for the holes in most control horns and all HK servos. Copper wire makes poor Z-bends and it's too flexible. Its better for wrapping or doubled over U-bends.
Old Nov 24, 2012, 07:36 AM
RcAirplaneNoob is offline
Find More Posts by RcAirplaneNoob
I live on LiPos
RcAirplaneNoob's Avatar
United States, DE
Joined Jul 2012
it depends on the thickness of the wing you dont want to make the wing to thin where you plan on putting the spar.
RcAirplaneNoob is offline Find More Posts by RcAirplaneNoob
Question repair hollow carbon rod? getmeoutofiraq Sailplane Talk 0 Jun 17, 2012 12:26 AM
Wanted Carbon Fiber Rod (or tube?) 4mm and 5mm OD Twyl Aircraft - Sailplanes (FS/W) 14 Jun 15, 2012 12:33 PM
Help! Carbon Fiber rod Scooch Beginner Training Area (Aircraft-Electric) 8 Jun 01, 2012 07:25 AM
Discussion Best 10mm square carbon rods? iCrap Multirotor Talk 3 May 27, 2012 01:42 PM
Question Where and how to install Carbon Fiber Rods in Easystar easystarfpv4 Electric Plane Talk 2 May 09, 2012 10:00 AM
