Old Nov 19, 2012, 02:18 AM
Andy120 is offline
Find More Posts by Andy120
New Zealand, Waikato, Te Kauwhata
Joined Jul 2006
Odd Motocalc C rating opinions
Hi, Flopped over from batteries.
Im trying to understand why if i enter a lipo set at say 20C, motocalc will be happy temperature etc wise. If i change the cells to a higher C rating eg. 25C, motocalc returns temperature alerts. I would expect the opposite.
Andy
Andy120 is offline Find More Posts by Andy120
Old Nov 19, 2012, 03:09 AM
wizard of odd is offline
Find More Posts by wizard of odd
wizard of odd's Avatar
Australia, VIC, Sale
Joined Apr 2011
Higher C rated batteries will be able to deliver higher current flow to the motor, hence more wattage input, higher load on the motor and higher motor temperature.
wizard of odd is offline Find More Posts by wizard of odd
Old Nov 19, 2012, 05:04 AM
peterangus is offline
Find More Posts by peterangus
peterangus's Avatar
Blackpool, Great Britain (UK)
Joined Dec 2003
More-capable battery...........higher motor temperature.....................lower battery temperature.
peterangus is offline Find More Posts by peterangus
Old Nov 19, 2012, 03:32 PM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Andy
Just changing the C rating should have no effect. It is cell impedance which determines heating (according to the equation: Power = Current squared times Resistance).
When you changed to cells with higher C rating, did they also have lower impedance? They should have. If not then either one of the cells has inaccurate specs in Motocalc, or its C rating is suspect. In a marginal situation it might not take much to trigger the warning, but if one is OK and the other says 'greater than 200F' then its specs are probably wrong.
Real cell impedance varies with current, temperature and state of charge, so a single impedance number cannot be accurate in every situation. Modern High C Lipos can put out higher voltage under load. Manufacturers don't generally provide impedance specs, so where did Motocalc's numbers come from and how accurate are they? I ignore them, set the chemistry to custom (blank), change voltage to 3.85V per cell, and adjust cell impedance to get 3.5V out at the rated current (impedance = 0.35V / capacity * C rating). I also reduce the capacity to 90% (eg. 2000mAh for '2200mAh' cells) because the battery probably can't deliver that last 10%.
Motocalc's battery model is quite simplistic, so in reality the results could be quite different from what it predicts. Provided you keep well within the battery's C rating and keep it cool, it should be OK (assuming the battery is accurately rated!).
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Nov 19, 2012, 08:30 PM
Andy120 is offline
Joined Jul 2006
Got it. Thanks Bruce
Andy
Discussion Odd Motocalc C rating opinions Andy120 Batteries and Chargers 1 Nov 13, 2012 08:53 AM
Question Charging rates based on "C" rating jeb6684 Batteries and Chargers 6 Aug 22, 2012 09:31 AM
Help! Need help understanding Discharge rate/ Charge rates, C ratings fltekdiver Batteries and Chargers 10 Oct 02, 2010 09:29 AM
Discussion Lipo C-ratings puzzle: what's most important, C-rating or mAh capacity?? Merlin45 Batteries and Chargers 18 Apr 03, 2010 04:45 PM
Discussion What is the minimum C rating of this odd battery? Harrow Batteries and Chargers 12 Mar 16, 2009 08:20 AM
