Old Nov 04, 2013, 10:49 AM
bhoov128 is online now
Find More Posts by bhoov128
Genesis 50:20
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
Originally Posted by JenR View Post
I received my 6 channel ultra light receiver today (http://www.lemon-rx.com/shop/index.p...product_id=102). The website lists these have 1.5mm JST connectors.
I ordered these 1.5mm servo leads for this: http://www.micronradiocontrol.co.uk/conn_jstzh.html
I thought this would fit, but it doesn't!
The receiver seems to have different (smaller) connectors than listed on the website. Here is a photo:
What connector is this?
I'm willing to bet it's a Molex Picoblade 3 pin connector at 1.25mm pitch.
bhoov128 is online now Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Nov 04, 2013, 10:54 AM
dvogonen is offline
Find More Posts by dvogonen
Joined Jul 2005
Originally Posted by fmak2 View Post
Anyway this casing is likely to replace by a hard-cover casing next year. Any comments or feedback would be great in regards to this prototype casing!
Lemon Rx Officer
It is nice to see that you are making the casings tight. The small size of your receivers is one of the main attractions and you should try to make the casing as tight as possible
The prototype does not have any screws. Might I assume that you are contemplating using glue to hold the case together? It would be very good to be able to open the case and put it back together again. You could consider using the a product sticker as a wrap around tape. To open the case one would cut the sticker at the side of the case. To put it back together one would apply some clear tape on top of the cut sticker.
The OrangeRX receivers are all made in Orange color plastic. This is a distinguishing feature for them. You could consider using transparent yellow plastic for promoting your brand in the same way.
dvogonen is offline Find More Posts by dvogonen
Old Nov 04, 2013, 11:03 AM
Genesis 50:20
bhoov128's Avatar
Joined May 2012
Also, yours looks like this product:
http://www.lemon-rx.com/shop/index.p...product_id=104
and not the one you have linked in your prior post. In which case, if the description is correct, they are JST-SH connectors at 1.0mm. If you can check with a pair of calipers the spacing of the pins it'll tell you - I've been waiting on these rxs with 1.0 mm connector, as that's the connector that works with Spektrum linear ultra micro servos and the tiny rotary servo they offer.
Ben
Old Nov 04, 2013, 11:13 AM
JenR is offline
Find More Posts by JenR
Belgium, Flanders, Lochristi
Joined Aug 2013
You are right. I ordered them and at a later time checked what connectors are used. I must have checked the wrong product page... Stupid me.
JenR is offline Find More Posts by JenR
Old Nov 04, 2013, 11:53 AM
speedy01 is online now
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Spektrum has a tiny rotary servo?
If you mean HobbyKing, yes, the ultramicro linear servos fit the new Lemon (1.0mm pin spacing as the AR6400), but the 1.7g rotary servos need a new plug, having 1.25mm pin spacing. As an aside, I just noticed that the ultramicro linear servos are listed twice on the HK site: here(regular throw?) and here (long throw?).
Gene K
speedy01 is online now Find More Posts by speedy01
Old Nov 04, 2013, 12:26 PM
Genesis 50:20
bhoov128's Avatar
Joined May 2012
Gene K
They do! Pricey, but plug & play with AR6400 / AS6410 series boards
http://www.horizonhobby.com/products...ge-_-SPMSA2010
Old Nov 04, 2013, 03:03 PM
Gulf Breeze, FL
Joined Jul 2006
... plug & play with AR6400 / AS6410 series boards
Thanks, Ben, I obviously didn't know that .... Not too pricey, IMO, since they cut the price in half. I have no idea of how this Spektrum with its "0.18 kg-cm @ 4.8V" torque stacks up against the HK's "0.075kg @ 4.2v".
At any rate, good to know I have an alternate small rotary choice choice to plug into my Lemon.
Gene K
Old Nov 04, 2013, 03:07 PM
Genesis 50:20
bhoov128's Avatar
Joined May 2012
The real question is why are aircraft like the UMX Yak and UMX Beast not equipped with little rotaries.....
Can someone confirm that the little rx pictured earlier by JenR actually have the 1.0mm pitch JST-SHR connectors?
Old Nov 04, 2013, 03:28 PM
JenR is offline
Joined Aug 2013
The website says 1.0mm JST connectors: http://www.lemon-rx.com/shop/index.p...product_id=104
Old Nov 04, 2013, 03:34 PM
Gulf Breeze, FL
Joined Jul 2006
Yes, they do!(I have three of them and checked before my last post).
Gene K
jj604 is offline
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Just to clarify, Lemon currently make the 6 channel featherlight with both 1mm JST-SH connectors (the one shown in the picture and at the link below) AND with 1.5mm JST-ZH connectors (Spektrum AR6300 type).
This one.
We are hoping they will soon have a third variant with Molex Picoblade 1.25mm (HobbyKing 1.7g servos) as well.
jj604 is offline Find More Posts by jj604
Old Nov 04, 2013, 03:37 PM
Genesis 50:20
bhoov128's Avatar
Joined May 2012
Gene K
Awesome. I know a long time ago I had looked at the one which must have the 1.5mm pitch connectors and was disappointed that it wasn't the UMX compatible system that I had wanted. I failed to see these had been released. Very cool!
Thanks!
Ben
Old Nov 04, 2013, 04:27 PM
IceRain29 is offline
Find More Posts by IceRain29
IceRain29's Avatar
Canada, ON, Toronto
Joined Jun 2011
1.25 molex?
the one listed at lemon rx site is the 1.5 one...
hobbyking have lots of servo with this 1.25 molex
IceRain29 is offline Find More Posts by IceRain29
Old Nov 04, 2013, 05:30 PM
Genesis 50:20
bhoov128's Avatar
Joined May 2012
Originally Posted by IceRain29 View Post
1.25 molex?
I had thought so too but it's been confirmed they're JST-SHR 1.0mm pitch connectors
Old Nov 04, 2013, 07:04 PM
nom is online now
nom
Find More Posts by nom
nom
nom's Avatar
United States, ID, Boise
Joined Mar 2011
Ordered another set on Oct 25th, just received my package today. Shipping is still great!
nom is online now Find More Posts by nom
Discussion Hobby king LANCASTER LEMON Lord_Of_Fear HobbyKing 43 Mar 11, 2013 11:56 PM
Discussion When Life Hands You Lemons..... Real Ira Life, The Universe, and Politics 14 Nov 02, 2012 01:35 PM
Discussion Ever Buy A Lemon Car? A $1.7M Lemon? Big Foot 48 Life, The Universe, and Politics 15 Jun 24, 2006 03:41 PM
Lemon tree very pretty. But the fruit of the poor lemon is impossible to eat. gtstubbs Life, The Universe, and Politics 0 Jan 22, 2005 07:07 AM
Make the best lemonade with the lemons you have KDB@KAM Foamies (Kits) 0 Mar 21, 2003 07:54 PM
