Old Nov 19, 2012, 12:44 AM
bhchan is offline
Find More Posts by bhchan
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
Help!
Looking for brushed ESC
Hello,
I am looking for a brushed ESC with reverse for a pair of sp600, probably 30-40 amp 16V max. Could someone point me to a source?
Thanks.
Brian
bhchan is offline Find More Posts by bhchan
Old Nov 19, 2012, 02:10 PM
hotrodder is offline
Find More Posts by hotrodder
hotrodder's Avatar
United States, CT, Manchester
Joined Jan 2007
Try Mtroniks
hotrodder is offline Find More Posts by hotrodder
Old Nov 19, 2012, 04:29 PM
bhchan is offline
bhchan's Avatar
Joined Jun 2000
Hotrodder
Thanks, is there anyone on this side of the pond?
Brian
Old Nov 19, 2012, 10:09 PM
hotrodder's Avatar
Joined Jan 2007
might find someone on ebay. Or you can get traxxas marine esc brushed.
Old Nov 19, 2012, 11:49 PM
bhchan is offline
bhchan's Avatar
Joined Jun 2000
I might have to change out the sp600s to a small brushles motors. Brushed motors are history!
Need one inrunner with same mounting pattern as the sp600 and has a 1/8" shaft!
Brian
Old Nov 20, 2012, 02:53 AM
pompebled is online now
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Brian,
What boat are you going to power with two Speed 600 motors if I may ask?
If forward only is sufficient, I'd get two of these:
http://www.hobbyking.com/hobbyking/s...ushed_esc.html
Regards, Jan.
pompebled is online now Find More Posts by pompebled
Old Nov 20, 2012, 09:27 AM
bhchan is offline
bhchan's Avatar
Joined Jun 2000
Jan,
It is a barge! I am converting an old flat bottom boat to use as a retrieval boat for float flying. Use it to tow or push stranded planes to shore. So reverse is important to maneuver around the stuck aircraft. I can use the non-reverse ESC and add a DPDT relay to switch direction on the motors.
Brian
Old Nov 20, 2012, 11:36 AM
CornelP is offline
Find More Posts by CornelP
CornelP's Avatar
Bucharest, RO
Joined May 2009
I do not remember the bolt pattern on the Speed600, but I think it should be the standard 19mm. Go for a pair of inrunners around 3650 like:
http://www.hobbyking.com/hobbyking/s...ess_Motor.html
as it has the same size shaft and these ESCs:
http://www.hobbyking.com/hobbyking/s..._Boat_ESC.html
This particular series has reverse, so you're ok.
CornelP is offline Find More Posts by CornelP
Old Nov 20, 2012, 12:34 PM
bhchan is offline
bhchan's Avatar
Joined Jun 2000
Thanks, that all look good but another $200.00! I think I will stay with a cheap brushed ESC, and run the motors in series!
Brian
Old Nov 20, 2012, 04:20 PM
CornelP is offline
CornelP's Avatar
Bucharest, RO
Joined May 2009
Ok, if you stick to brushed, try to find this one:
http://www.aliexpress.com/item/Dual-...ck_to_detail_a
I have one on a scale boat and it performs really nice. Look for any crawler dual ESC, it has a very good low rev control.
PS: found one on ebay:
http://www.ebay.com/itm/Dual-Motor-S...item19cd3518b1
Old Nov 20, 2012, 05:41 PM
bhchan is offline
bhchan's Avatar
Joined Jun 2000
That's perfect. When I saw I have to buy 5 of them, hmmmm, but the ebay one is perfect. Even made for dual motors. Thanks
Brian
Old Nov 20, 2012, 06:40 PM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
The bolt pattern for the Speed-600 is the same as speed-500(25mm between M3 holes). 19mm was for the speed-400/480 size motors. The Proboats 40 A marine esc for brushed is still availlable:
http://www.greathobbies.com/producti...rod_id=PRB2314
coriolan is offline Find More Posts by coriolan
Old Nov 21, 2012, 03:01 AM
Sneek, Netherlands.
Joined May 2004
The Proboat ESC doesn't seem to work well at low revs, if I'm informed correctly.
If you can solder and want to pay the shipping accross the pond, two of these kits (either with or without BEC) will work a treat for a Speed 600:
http://www.modellbau-regler.de/shop/index.php?cPath=4
Regards, Jan.
For Sale JETI 012 ESC for brushed motors - ESC for sale pairadocs Aircraft - Electric - Power Systems (FS/W) 2 Jun 03, 2012 09:02 AM
Found Looking for cheap 7~10A Brushed ESC cutty01 Aircraft - Electric - Power Systems (FS/W) 4 May 05, 2012 12:27 AM
Found Looking for a brushed ESC for a crawler project harikay Cars - Cars and Parts (FS/W) 4 Aug 04, 2009 09:31 PM
Wanted Looking for a 35-45 amp brushed esc for a graupner speed 600 chirogid Aircraft - Electric - Power Systems (FS/W) 3 Dec 14, 2008 09:57 PM
Found Looking for a brushed 25A ESC for Unicorn millerhill Aircraft - Electric - Power Systems (FS/W) 10 May 20, 2007 03:13 PM
